Jan 09, 2004, 01:52 PM
Big gov never Works
St. Martin's Avatar
Build Log
200% Earl Stahl Hurricane
I started this on another thread. It looks as tho it may be quite long. So, instead of the risk of losing it in a long thread( thanks Brian) I'll do it in it's own.
I know Martin is going to read this, so... You have got me thinking about flaps and retracts, after reading seeing your threads on the hurri.
Enlarged Earls plans to 41.5" WS/31" LOA. I started with the laminations for the tail & wing tip bows. Used 1/32" balsa for the lams.
Jan 09, 2004, 01:54 PM
Big gov never Works
St. Martin's Avatar
Laminating the 4 keels for the fuselage
Jan 09, 2004, 01:58 PM
Big gov never Works
St. Martin's Avatar
Bulkheads and stringers The nose stringers are not drawn into the nose. This would cause warpage of the keels. The rear stringers are 1/16" bass, and draw very little pressure in bending.
Jan 09, 2004, 02:00 PM
Big gov never Works
St. Martin's Avatar
Off the board and adding other side
Jan 09, 2004, 02:02 PM
Big gov never Works
St. Martin's Avatar
Laying out the vertical tail blank
Jan 09, 2004, 02:04 PM
Big gov never Works
St. Martin's Avatar
While thats drying.. time to do a little "scalloping"
Jan 09, 2004, 02:05 PM
Big gov never Works
St. Martin's Avatar
The finished blank
Jan 09, 2004, 02:08 PM
Big gov never Works
St. Martin's Avatar
And the finish vert. assem.
Jan 09, 2004, 02:12 PM
Big gov never Works
St. Martin's Avatar
I have a mega 16/25/6 coming for it. This will swing a 10-11" prop on 8-1050Kans.
Robart 1/2A hinges used
Jan 09, 2004, 02:19 PM
G G Ghost Pirates !!!
Vyceroy's Avatar
looking good steve
Jan 09, 2004, 02:22 PM
Leave me alone!
Martin Hunter's Avatar
Fantastic, Steve! Go for flaps and retracts. You know you want to
Martin
Jan 09, 2004, 02:48 PM
JIMA's Avatar
Steve,
That rudder looks fantastic. Your Hurricane is going to make my P-40 look plain-jane. Oh-well. When you raise the bar, you inspire all the rest of us to get better. Keep it up.
Jim
Jan 09, 2004, 02:53 PM
Leave me alone!
By the way, what do the fuselage and fin/rudder weigh so far?
Martin
Jan 09, 2004, 04:08 PM
Big gov never Works
St. Martin's Avatar
Thanx guy's(big head)
I don't have a scale to weigh things this light. All wood is contest 6-7# except in certain areas. The scale I do have is saying 1oz.
Does GWS make a retract to fit this size plane? If not I'll get a set of Robart 1/2. Then I can make my decision. There really is no place for me to fly a small plane with gear. I fly at a turf farm that has a road, but pretty rough one. It would do the gear in fast.
The flaps are real inviting. If I do them, I'll most likely make them from 1/64"ply & glass laminate. With the scale ribs it would be light and stiff.
I decided to add the trim tabs also, after figuring something was missing...
Steve
Jan 09, 2004, 07:58 PM
Big gov never Works
St. Martin's Avatar
Horz. tail outline being formed, using 1/8"sq and tip lams
