This thread is privately moderated by MavBot, who may elect to delete unwanted replies.
Apr 09, 2013, 10:44 PM
MavBot's Avatar
Build Log
Upgrade your FlySky TH9X to the FrSky DJT module
The FlySky TH9X transmitter is a great value in a 2.4 GHz radio. As explained previously, it’s also sold rebranded as the Turnigy 9X, and the Imax 9X, and these radios have proven extremely popular and reliable over the years. The 9X radios do have some drawbacks, but most of them can be addressed with a few easy and cheap upgrades. In this build log we show you how to replace the 9X’s stock RF module with FrSky’s DJT FHSS system.
The stock module from FlySky is OK if you’re just controlling park fliers short-range (out to about 500 meters or so), but its Automatic Frequency Hopping Digital System (AFHDS) technology is fairly lacking if you want better range and robustness to interference. The AFHDS basically just searches for a free channel and uses that. Which usually works fine, but it could go disastrously wrong, for example if a new source of external interference arrives after the system has already started up and chosen its transmit channels.
The DJT module (Figure 1) by FrSky (pronounced “Free Sky”) is a true Frequency Hopping Spread Spectrum (FHSS) system that continuously jumps between channels so that it cannot be affected by interference on any particular set of channels. With this system and one of FrSky’s “full range” receivers you can expect to get about 1.5 km of range.
Figure 1: The FrSky DJT two-way telemetry FHSS module
The DJT is also a two-way telemetry system, which means it not only transmits an RC control signal to the aircraft, it also receives telemetry data back, as long as you are using one of FrSky’s telemetry receivers. The telemetry data would normally come from sensors connected through a sensor hub to your receiver, such as altitude, GPS position, compass, accelerometer, RPM, temperature, battery level, etc.
But if you get a FrSky receiver with Received Signal Strength Indication (RSSI), such the D8R-XP (Figure 2), you can make good use of the two-way telemetry feature even without any sensors attached: The DJT module on your Tx will start beeping to warn you when your radio signal is getting low. That way you’ll know when you’re starting to fly too far away, and it’s time to turn back!
Figure 2: FrSky D8R-XP telemetry receiver
Installation Steps
The FlySky Tx almost fits modules designed to be compatible with JR radios, but unfortunately not quite: in order to change to a non-stock module, you’ll first have to cut down the raised area of plastic that supports the five module pins. This supporting area will need to be cut back until it’s no more than 2.0 mm high (or just cut it away altogether, because once it’s cut back it won’t be doing anything to support the pins anyway).
1. Unplug and remove the battery, and remove the stock module. Once the stock module is out, you’ll see the five pins at the lower right of the module compartment, supported by the raised plastic area. This raised plastic is the only thing getting in the way of installing a new module.
2. Get the pins out of the way. When you’re cutting the raised area of plastic, you’ll want to move the pins themselves out of the way, so as not to damage them. First open the case of your Tx by removing the six screws at the back (Figure 3).
Figure 3: Remove 6 screws to open case of FlySky TH9X radio
Spread the two halves of the case apart carefully and not too far, so you don’t break any wires connecting them (Figure 4). At this point it may be a good idea to take some photos of the circuit boards inside, just in case you do break a wire and need to know where to solder it back again.
Figure 4: FlySky TH9X with case open
Now locate the back circuit board, and remove the four screws holding it in place (Figure 5).
Figure 5: Remove 4 screws from FlySky TH9X back circuit board
Pull the circuit board back gently, just enough so the five module pins are clear of the back of the radio. The wires that connect it to various switches will prevent you from moving it back very far (Figure 6).
Figure 6: Pull back circuit board to clear module pins away from area you'll be cutting.
3. Cut the plastic support to 2.0 mm high or less. With the module pins completely out of the way, use a very sharp knife, wire cutters, or a power tool like a Dremel to cut back the plastic support area until it is protruding no more than 2.0 mm into the module compartment (Figure 7).
Figure 7: Cut plastic support for module pins down to 2.0 mm high or less
4. Replace the back circuit board and tighten the screws (Figure 8). Only tighten the screws very loosely at first, so the circuit board has some wiggle room to allow you to get the precise alignment for fitting the modules.
Figure 8: Replace the back circuit board but don't tighten screws yet
Test insertion of both the stock module and the FrSky module (Figure 9) to make sure they seat easily and without any resistance. If either doesn’t fit, don’t force it, or you could bend or break the pins. The cause is either that the back circuit board is slightly out of alignment, or that you’ve slightly bent one of the pins.
Figure 9: FlySky Tx with FrSky DJT telemetry module installed
Make sure you repeatedly test the fit of both modules as you gradually tighten the four screws, because the board alignment will shift slightly as the screws tighten. If at any point you find that one or both modules won’t seat completely without resistance, then you’ll have to back the screws out again and start over to get the alignment perfectly correct.
5. Put the Tx case back together again, replacing the six screws. You’ll probably want to blow all the plastic dust you’ve generated out of the unit first though. Again, make sure both modules seat perfectly before putting the case back together.
Using the FrSky DJT System
We trust the FrSky DJT module and D8R-XP receiver will work great for you. You’ll get about 1.5 km range, telemetry, including RSSI, as well as a range check mode to make your pre-flight range check easier. I love the fact that the module beeps to tell you when the signal is getting weak, as it gives me great peace of mind to know I always have a strong signal while flying.
Using the DJT module and D8R-XP receiver is pretty straightforward. Binding, failsafe, range check, and setting for high-speed or regular servos is explained in the manual. But let us know if you have any questions.
Enjoy using your FlySky TH9X radio, now upgraded to the true FHSS system!
Aug 16, 2013, 09:14 AM
module change
Will changing the module requires using FrSky receivers?
Aug 18, 2013, 11:02 PM
MAV Coder
david_hz's Avatar
Yes, it will need to be one of the FrSky receivers that's compatible with the DJT module. I like the non-telemetry receivers, such as V8R7-II, because I use separate 433MHz or 900MHz telemetry radio modules for telemetry to my groundstation.
Oct 26, 2013, 04:06 PM
I think you will find the flysky B version is FHSS. See here.
http://www.rcmodelreviews.com/turnigy9xv2review4.shtml
Oct 27, 2013, 09:54 PM
MAV Coder
david_hz's Avatar
Nice, looks quite good. The article you linked does say it still isn't quite as resilient as FrSky though.
Jan 05, 2015, 03:16 PM
dagob's Avatar
Will the DFT model ( FrSky DFT 2.4G Two Way Compatible Futaba Telemetry Module ) work as well with the TH9X?
Jan 07, 2015, 05:31 PM
MAV Coder
david_hz's Avatar
No, you need the DJT module. I would not buy a TH9X now that the FrSky Taranis is out though, as the Taranis is a much better radio, and once you do all the needed upgrades to the TH9X you will have spent about as much as you would pay for the Taranis anyway.
Jan 27, 2015, 08:26 AM
FA3PR9WM79
Oldgazer's Avatar
I just upgraded my TH9x with a XJT module, and replaced the R9B Rx with a dual antenna X8R.
The XJT fits and functions properly without modifying the radio, but I think I'll do the mod anyway so the module sits flush like it should.
Since it is snowing, today will be a good day to get this done...
Jan 27, 2015, 09:24 AM
FA3PR9WM79
Oldgazer's Avatar
Just finished cutting out the pin support. I really don't like using a Dremel, so I used a disposable knife to score the support and then I used a pair of duck billed pliers to snap it out... No muss, no fuss.
Jan 27, 2015, 02:01 PM
How can I use telemetry with th9x
Jan 27, 2015, 03:23 PM
FA3PR9WM79
Oldgazer's Avatar
Buy the various FrSky sensors, a sensor hub, and the FLD-02 display screen.
I'm going a different way. I'm waiting on an APM 2.6 and a set of telemetry radios. One radio plugs into the APM, and the other plugs into a laptop, or I've heard you can use a tablet with an OTG USB cable..
The APM side transmits to the laptop and the data shows up in Mission Planner....
Then if you go FPV you can add a MinimOSD and tap into the telemetry stream and use MinimOSD to feed that data into your FPV video stream....
That way your ground station operator will see the same telemetry that you do....
I just found this: FrSky Telemetry
Jan 27, 2015, 04:45 PM
FA3PR9WM79
Oldgazer's Avatar
I've learned there are some other caveats.
1. The FLD-02 will only display RSSI from an X8R receiver.
2. An X8R receiver can only use Smart Port sensors.
3. Smart port sensor data is only displayed on Taranis, or Smartie Parts/Open 9x modified radios.
4. FrSky was supposed to release a "Smart Dashboard" display to replace the FLD-02 some time in 2013.. As this has yet to materialize, it appears that FrSky would prefer users upgrade to a Taranis...
Here's my opinion...
I bought the XJT and X8R so I could have a working fail safe, working range check, RX signal strength warning and longer range, so from that perspective I'm good to go.
The APM 2.6 and 3DR telemetry radios that I'm waiting for will give me every thing else I need...
Feb 09, 2015, 04:13 PM
Rchelistuff
issue with th9x+djt module
Hi Guys
I'm preety desperate since I got a FS TH9X-B radio and a DJT module kit. After binding it kept blinking and finally the module didnt blink at all...With this video evidence HK send me a replacement kit ! I could keep the receiver...Just now I opened the package and surprize, when I connect it to the back of the radio, there is no led blinking, no nothing...am I doing something wrong here???
tx
Feb 09, 2015, 04:37 PM
FA3PR9WM79
Oldgazer's Avatar
Originally Posted by cofl10011
Hi Guys
tx
Bent or broken connector pin in the radio maybe?
Did you modify the module well where the pins protrude?
I had to do that to get an XJT module to seat all of the way..
http://openrcforums.com/forum/viewtopic.php?f=23&t=1059
Feb 12, 2015, 05:39 PM
Rchelistuff
Yes, plugged in, opened the djt and got correct voltage on the pins, see here:
FS TH9x with DJT module not binding with D8R-II rx (7 min 16 sec)
Sold JR 9303 w/ Frsky telemetry DJT module and D4R-II RX DaMaDo Aircraft - General - Radio Equipment (FS/W) 0 Apr 05, 2013 10:47 AM
Sold FLYSKY FS-TH9X with a Frsky ( V8HT) module installed hurleycycle Aircraft - General - Radio Equipment (FS/W) 6 Jan 19, 2013 08:55 PM
Found Flysky TH9X-B with Module, Upgraded Firmware Arr0wHead Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2013 03:04 PM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 07:08 PM
