High Performance FPV Pusher/Twin Boom Pulsar Pro 3E FPV
Would somebody be interested in high quality 3m FPV sailplane? If you take model apart it fits easily to 1m Long Box!!! We were asked for precision, high altitude, fast sailplane and we are trying to find interested customers.
Zb/Esprit Model You can see details here: http://www.espritmodel.com/search.aspx?find=pulsar+pro |
Absolute, enigma and experience pro e are faster and way more fun fpv ![]() Really slow gliders get boring very fast It's more fun with planes that have large fuse and carry big batteries Thin fuse gliders not really great for fpv Experience pro e is bomb of a plane for fpv But enigma is rock solid and tight plane, great fpv set up Bullet is too small for decent fpv Bigger is for sure better but it has to have room for business inside fuse And unbreakable in the air with heavy load |
Looks wonderful, but $$$ ouch! |
Zb/Esprit Model |
I would be very interested, but I couldn't find this particular product anywhere on your site.
I disagree that sailplanes can be boring. It depends on what you're doing. Roberto Monteil (https://www.rcgroups.com/forums/show....php?t=1543631) did a 110KM out and return with an Esprit Facination glider. To me, that's completely not boring. It takes a lot of technical know-how, planning, skill and of course luck to get a flight like that done. I doubt if anything other than a sailplane could have done the job. Please direct me to the product page / link, I'd really like to check it out. -Peter |
The wing is a balsa built-up Carbon Fiber and Kevlar D-box design that utilizes carbon fiber faced balsa ribs and carbon fiber trailing edge. The open section of the wing, as well as the tail parts, are covered with UltraCote. The fuselage is made of white gel-coated 2.4GHz friendly fiberglass/Kevlar with carbon fiber tapered boom and removable carbon fiber canopy. The three piece wing with little bit of dihedral on the central panel and 2-piece conventional tail are each easily removable for transport and storage. The rudder as well as elevator servos install in the vertical fin. The careful use of composites, combined with an underlying wood structure in the wing, ensures a good light structure that will hold its shape for a long time. This is an extremely light, high performance model. Zb/Esprit Model ![]() ![]() |
Put it into production! I'd buy one! I owned an AVA a few years ago, very similar and very high quality construction and I'm guessing the Pulsar line is as good or better. |
Looks like we will go for it, please helps us with your ideas. We expect first pieces in 2-3 monts.
Zb/Esprit Model |
Make sure you provide enough room for all the fpv gear. Sail planes have skinny fuses in general.
I would like to see someone provide preplanned positions in the wings for gps, transmitter and antenna, receiver and antenna, etc. Anything that needs good seperation to work properly and avoid rf conflicts. If you put everything in the fuse, it can get crowded and problematic. If there's one place on a sailplane with tons of room, it is the wings. If you thought about it in the design process you could provide hatches for these electronics and avoid most of the drag that surface mounting can cause. And you could leave the fuse skinny. |
Zb -
Excellent news! If you're still in the design phase, I'd like to offer some suggestions: 1) For the fuselage layout, it looks like you've got a substantial pod configured. That's a good step. If you all haven't had much experience with FPV I'd suggest looking at the typical gear we have to shoehorn into our models. It's quite a bit and goes beyond conventional R/C gear. I've been searching high and low for a roomy enough airframe that retains glider characteristics. For me you're on to something. You might want to gather a suite of typical FPV gear and design around it: Conventional gear: Servos, motor, ESC + BEC (a lot of us use a motor controller + a small castle BEC to run the radio and other electronics), thermal sniffer. FPV Gear: OSD, Camera and we generally use unconventional UHF receivers, e.g. EzUHF, Dragon Link, etc, video transmitters,. A well designed model in my mind would be built around this type of typical layout and wouldn't force a builder to shoehorn everything in. 2) Should strive to maintain good aerodynamics. One of the big things with FPV is that we're forced to have a lot of junk hanging out in the slipstream, e.g. antennas, transmitters. I'd love to see a design that helps us "tuck" some of that gear away. That might be pockets in the wings, pre-routed wiring, mount points etc. 3) One of the unique problems with FPV is the necessity (in most cases) to get the transmitting stuff as far away from the receiving stuff as possible. In a lot of cases, this is much easier said than done. It would be great if a new design could address these concerns (see point #2). In a nutshell, you want all the stuff that receives a signal (GPS, R/C receiver) as far away physically as possible from the transmitting stuff (video transmitter, telemeter, other...) 4) Design for a lot of inherent stability. Most of the best FPV planes are naturally stable. Some competition level TD sailplanes that I've flown are definitively unstable. I think it's important to retain the good stuff that a TD airframe has to offer (great L/D, great thermalling, good energy retention, etc.) while eliminating the bad, typical TD airframe stuff (sensitive CG, stall sensitive, lots of care and feeding in turns). 5) If you're considering housing the camera in the pod, looking through a plastic canopy, be cautious. That's been tried a lot with mixed results. Distortion is a problem, they tend to get scratched up during landings. I've used this (from a 3D printer service) with good success: http://www.shapeways.com/model/54823...=62&li=ostatus Can't wait to see the finished product! Count on at least 1 pre-order!! ![]() |
Oh! And one other thing! Be VERY VERY careful with too much carbon! Video and the UHF radio signals DO NOT LIKE being in front or behind a layer of carbon!!!!!! This comes into play with regard to pockets and nooks in the wing and other places on the plane. I know this style of plane uses strategic carbon in the wing D tube and as booms.
This pulsar looks like the big brother of my garnet dlg
Same manufacturer and very high quality Extreme high quality Built for very light set up to glide for very long time I recommend the straight up pulsar e version It has motor in front and enough space in fuse for fpv stuff I see on website Albatross sport glider it looks great for fpv Also f5b enigma This plane I fly fpv and it is very fun fpv No need for large motor but just one that goes like 1000 watts or less Enigma from this guy who sells them is perfect fpv plane that does it all 2 hours flight time no problem if you just want to glide around Pulsar would be slow and only just thermal hunter as no large battery could fit into,it Bird of time for 120$ from great planes will fill your needs for thermal hunting I highly recommend enigma for pure fpv fun It glides very well and not need to be flown f5b at all This guys sells enigma and well worth the money Don't worry about carbon if you set up the plane correctly Carbon has very little effect if you set up plane well |
Thread Tools | |
Similar Threads | |||||
Discussion | Yes or No? FPV Pusher/Twin Boom Pulsar 3m | Esprit Model | Electric Sailplanes | 13 | Mar 17, 2014 10:46 AM |
Build Log | Twin boom pusher Depron 75" 13.4 oz A/P platform | CactusJackSlade | Aerial Photography | 30 | Mar 05, 2006 03:49 AM |
Maiden success on twin boom pusher. | Myron | Aerial Photography | 22 | Jan 12, 2005 12:32 PM | |
"Beginners" (Depron) twin boom pusher: flys GREAT and SLOW!!! | CactusJackSlade | Beginner Training Area (Aircraft-Electric) | 1 | Dec 21, 2004 01:08 AM | |
Another Twin-Boom Foamy Pusher from Foamflyer | foamflyer | Foamies (Kits) | 16 | Oct 28, 2004 09:59 AM |
