Nov 02, 2018, 08:55 AM
Originally Posted by TooJung2Die
Looks like an example of dynamic soaring but that can't be. It's only a foam DLG. Those are some large fast altitude changes.
Interesting thought. I was just circling a thermal. And not very well.
When conditions are good it is very easy to thermal.
Nov 02, 2018, 09:38 AM
Too old to rock-n-roll...
TooJung2Die's Avatar
When I lived in Las Vegas there were constant thermals rising off the desert. Some would suck the hat off your head. Now I live in Pennsylvania. I've learned to watch for circling vultures. They know where to find lift!
Nov 02, 2018, 02:49 PM
right - it doesn't really match what you would expect for a DLG flight and doesn't seem to show clear altitude values for the start, launch or descent. there also seems to be some odd interaction between the green temperature trace and the yellow altitude trace where every yellow spike shows a small green drop? wondering if maybe there's an issue with power to the altimeter or interference from the radio or servo electronics?
Nov 02, 2018, 03:54 PM
The temperature change made perfect sense to me. I lived in same type of desert. As the airplane ascended the temperature dropped, as it descended the temperature rose. I looks about 90F that flight, a nice cool desert morning?
Nov 02, 2018, 04:50 PM
I noticed the same thing. I think the thermals were popping that morning but I was still learning to thermal.
Thanks for pointing that out. I didn't want to appear as a know it all.
This is a more recent flight. You can see how I circle when in a thermal.
Nov 02, 2018, 06:14 PM
The temperature change made perfect sense to me.. as the airplane ascended the temperature dropped, as it descended the temperature rose
aaahhhhh, of COURSE!! thanks! the altimeter trace is still a mystery though... no idea what it's showing
Nov 02, 2018, 06:25 PM
NICE!! especially with that hawk in the mix! looks like that super-low AUW really makes your design a terrific thermal bird
Nov 03, 2018, 07:29 AM
A thermal is like a column of air. In the middle of the column there is rising air and sometimes sinking air outside the column. My plane had a hard time entering that column of air and got bounced out. If a plane is too light sometimes it has a hard time penetrating strong wind.
In short the altitude graph shows changes that were caused by the thermal I was circling.
Cheers
Nov 03, 2018, 08:05 AM
Cheers
The altimeter uses air pressure. There might be a relatively large pressure difference in and out of a thermal.
Nov 03, 2018, 08:16 AM
Good point, I don’t remember the plane changing altitude that much.
Latest blog entry: DLG builds
Nov 03, 2018, 08:58 AM
right, and the graph is showing huge altitude changes of 100+ feet every 5 seconds so the altimeter's sensitivity is being impacted somehow by a pretty large factor - 2x? 10x? seems we can read relative direction of the plane during flight, but not sure how to understand much more?
Nov 04, 2018, 01:50 PM
Calm and 73 degrees today. Love the year round flying here.
Nov 05, 2018, 03:15 PM
Foamy and Glider fanatic
Blacky's Boy's Avatar
nice hang time!
We had nice weather for gliding here yesterday. It works out to once a month we get a day where I can fly. LOL!
Nov 29, 2018, 02:23 PM
I was tired of taping the nose cone on before flying so I hot glued a magnet for easy removal.
1.5m DTFB glider (5 min 5 sec)
Nov 29, 2018, 02:43 PM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
That’s so COOL !!!
Latest blog entry: Lost plans
Question Aus - Where to find cheap foam? Stew_822 The Builders Workshop 24 Oct 01, 2013 09:53 PM
Build Log Carrying a GoPro on a homemade plane: simple and cheap, foam + depron, 1200mm wingspa tecdux FPV Talk 4 May 08, 2013 07:41 AM
Discussion Simple/Cheap/Small meter to ONLY measure mAH used rohdem Batteries and Chargers 21 Apr 15, 2013 08:15 AM
Yippee! Very Cheap & Simple Entry Level DLG – KFerret wingnutt Hand Launch 1 Nov 26, 2007 11:46 AM
Cheap,simple build DLG Knife3dge Hand Launch 18 Jul 18, 2004 01:56 PM
