Dec 13, 2017, 07:29 AM
Too old to rock-n-roll...
TooJung2Die's Avatar
Originally Posted by boa2110
The compressibility of foam is a weak point when using foam board. I have found an easy way to strengthen the foam. Add hot glue to the score lines. Let glue in the split and wipe off while still hot. This fills the crack with glue and helps prevent the foam from compressing.
I bought a cheap $10 clothes iron that works great for smoothing out hot glue seams and filets. Often the hot glue cools before I can wipe it smooth with a foam scrap on long seams. I found the iron will smooth out seams and remove excess glue from filets. A heat setting between silk and wool seems about right. Have a towel handy to wipe the face of the iron clean between passes over the glue. It works great for fixing all kinds of hot glue joints I didn't get quite right the first time.
Dec 13, 2017, 12:45 PM
Maiden flight of the light weight DLG. Launches easy and floats really good in calm conditions. I ordered some tungsten weights for ballast, It should help in more turbulent conditions.
I was getting some good consistent launches but not hooking any thermals. Then I noticed some buzzards come by and looked like they were teasing me. Finally caught a nice thermal and stayed up 5 min.
Jan 04, 2018, 08:00 AM
bmblb's Avatar
......that is mesmerizing ! the AUW you have achieved and the simplicity of the design is superb !
Jan 09, 2018, 09:27 AM
bmblb's Avatar
....I just had to make one...so here's my 48in version....just have to set up the controls...WL is just shy of 3.75 Oz/sft...maiden soon
Jan 09, 2018, 03:06 PM
skumgummi dave
bmblb:
Looking forward to your flight report.
Dave-
Jan 09, 2018, 06:37 PM
I built this 1m today. Rudder/Elevator only. AUW 125g.
Jan 09, 2018, 07:07 PM
skumgummi dave
Boa2110:
May I assume that your foam spar is tapered? Also what is the measured chord at center and ends of the wing?
Thanks. Dave-
Jan 09, 2018, 07:33 PM
Originally Posted by foamdave
Boa2110:
Thanks. Dave-
Yes, foam spar is tapered. Root cord is 6.5” and tip is 2.75”.
Short maiden tonight. Wind was up so I couldn't really check it out. I did notice the wing did produce some nice lift.
Jan 09, 2018, 10:07 PM
skumgummi dave
The airfoil looks great on that one. Your info really helps me.
Best to you;
Dave-
Jan 09, 2018, 10:16 PM
Best to you;
Dave-
I found out it is better not to sand much off the LE fold so it is not as sharp. Still have to sand a lot off to get a nice trailing edge.
Jan 18, 2018, 12:52 PM
bmblb's Avatar
bmblb:
Dave-
...had to redo the tail as i decided to go with wire instead of string for the elev. control ....and a damaged fin due to hangar rash. Yet, I was too keen to test the new airfoil, light-er wing loading and reduced drag.....despite the fact that the ailerons were not neutral, it just floated...curiosity satisfied
....with pushrods etc it stands at 3.68oz/sft...another gram or two for taping the belly.
...may just go with a 2mm coro fin with a cf tube so that I get more launches,,,,and fewer repairs...
Jan 18, 2018, 12:59 PM
bmblb's Avatar
sailplane calc
boa....have you tried plugging in your specs on the the sailplane calc? what values do you get?
Jan 18, 2018, 03:16 PM
I don't check but someone ran my specs on my 2m UMX motor glider and said about 2.5oz/sq ft
Mar 09, 2018, 01:35 PM
1.5m DLG
Temperature was just starting to rise and I got this nice flight in.
Mar 09, 2018, 01:41 PM
Slope-a-Dope
Steve 0's Avatar
Always nice to launch right into lift! Great flight. You have really got the DTF DLG down.
Question Aus - Where to find cheap foam? Stew_822 The Builders Workshop 24 Oct 01, 2013 09:53 PM
Build Log Carrying a GoPro on a homemade plane: simple and cheap, foam + depron, 1200mm wingspa tecdux FPV Talk 4 May 08, 2013 07:41 AM
Discussion Simple/Cheap/Small meter to ONLY measure mAH used rohdem Batteries and Chargers 21 Apr 15, 2013 08:15 AM
Yippee! Very Cheap & Simple Entry Level DLG KFerret wingnutt Hand Launch 1 Nov 26, 2007 11:46 AM
Cheap,simple build DLG Knife3dge Hand Launch 18 Jul 18, 2004 01:56 PM
