Nov 20, 2017, 01:04 AM
This one is made with Ross foam board. AUW 215g aileron and elevator only. Maiden flight was really nice. Wind was calm and the plane just floated. Unfortunately my ballasted nose cone flew off and I could not find it.
Nov 21, 2017, 08:21 PM
Replaced nose cone and ballast. Did some more trim flights. Will need to set the elevator linkage with some CA so it wont slip anymore.
Nov 25, 2017, 12:52 PM
another trim flight this morning.
Nov 27, 2017, 05:29 AM
Hi Boa
Very nice.
Could you provide a bit more information on the building process please?
Wings are cut with hot wire right? airfoil? what reinforcements do you have in the wing?
is the whole wing covered with packing tape?
Nov 27, 2017, 06:05 AM
Originally Posted by midrian
Hi Boa
Very nice.
I cut the foam board wing then sand the inside to get the airfoil shape. Wing top and bottom are taped together at the leading edge with a 1/8" wood dowl to protect the leading edge. No spar used but I do add a piece of foam spacer near the root to make a thicker air foil shape(12 mm instead of 8mm when folded). Electronics are placed in wing before folding and hot glueing.
Latest blog entry: DLG builds
Dec 03, 2017, 08:51 AM
RichKat58
RichKat58's Avatar
So cool
You said you sand the inside to get airfoil, how do you mean? Can you post pictures please
Dec 03, 2017, 09:00 AM
Originally Posted by RichKat58
So cool
Yes it is inside the fold The top fold also gets some score cuts (inside) to help give it the airfoil curve.
In the picture above the wing on the left is the outside. The right shows how the inside looks with the score lines cut.
Dec 04, 2017, 04:00 AM
This wing has a thinner profile. Horizontal stabilizer under boom.
Dec 05, 2017, 11:40 AM
bmblb's Avatar
...it flies so well! Congratulations and thanks for sharing.
Would you be able to post close ups of the finished airfoil?
Dec 05, 2017, 12:46 PM
It has an airfoil top and flat bottom.
Dec 10, 2017, 11:21 AM
New 1m DLG is 105g AUW and rudder elevator only.
Dec 10, 2017, 02:39 PM
The compressibility of foam is a weak point when using foam board. I have found an easy way to strengthen the foam. Add hot glue to the score lines. Let glue in the split and wipe off while still hot. This fills the crack with glue and helps prevent the foam from compressing.
Dec 12, 2017, 05:35 PM
New 1.5m came in at 170g AUW.
Dec 12, 2017, 11:11 PM
Slope-a-Dope
Steve 0's Avatar
170 gr. AUW is crazy light! It appears to have ailerons also? Is the nose all balancing weight and the rest is in the wing?
Can it take much of a discus launch?
Dec 13, 2017, 05:29 AM
Yes, everything in the wing. Very clean design. 3 servos(aileron/elevator). Nose cone for ballast.
Question Aus - Where to find cheap foam? Stew_822 The Builders Workshop 24 Oct 01, 2013 09:53 PM
Build Log Carrying a GoPro on a homemade plane: simple and cheap, foam + depron, 1200mm wingspa tecdux FPV Talk 4 May 08, 2013 07:41 AM
Discussion Simple/Cheap/Small meter to ONLY measure mAH used rohdem Batteries and Chargers 21 Apr 15, 2013 08:15 AM
Yippee! Very Cheap & Simple Entry Level DLG KFerret wingnutt Hand Launch 1 Nov 26, 2007 11:46 AM
Cheap,simple build DLG Knife3dge Hand Launch 18 Jul 18, 2004 01:56 PM
