Apr 11, 2013, 10:40 PM
Old Prop Buster
Sir Dumb Thumb's Avatar
Originally Posted by dz1sfb
Very nice and interesting model. DLGs kind of interest me, but the price tag is a bit steep, unless your competing. I have carbon arrow shafts that are 8mm OD that should work.
Ken
dz1sfb: I did a pod and boom glider body for a wrecked Swift glider wing that was left over from a dumb thumb adventure. I used a carbon golf club shaft that worked well also. They are tapered and I paid a few bucks at the thrift shop for a driver.
Gary
Apr 12, 2013, 08:16 AM
was geht , müssen unten kommen
Keenan smith's Avatar
Im Gonna Go all out on mine... (small Redesign on the Wing full span *1.5m*, Glassed Wing and tails, and carbon Golf shaft Boom)
Apr 12, 2013, 02:15 PM
Im looking forward to seeing your build, Ive been thinking about scaling it to 1,5m and glass the wing. Please document the build and post it here.
Apr 12, 2013, 05:30 PM
Will do ..
Apr 15, 2013, 10:00 PM
slebetman's Avatar
That should work out great. Mountain Models sells one of the cheapest full span DLGs around - the DL50 (http://www.mountainmodels.com/produc...roducts_id=212)
It's a cut foam core wing glassed with very light glass but not bagged. It's targeted to people who would like to try out a DLG but can't afford a bagged wing or don't have the tools to do bagging themselves. Click on the page above and read the manual on how to glass the DL50 wings. It's a great starting point for a home made DLG.
Apr 16, 2013, 03:19 PM
Andres Lu
joker24458's Avatar
Ok, I want to build one of these when I get my hotwire set up (not right away though....gonna take a while to get everything for it ) so I can hotwire an airfoiled wing. What type of airfoil would you guys recommend? Thanks!
-Andres
Apr 16, 2013, 03:28 PM
Custom User Name Title
bhoov128's Avatar
Man, now I want one of those DL50s... very nice I've been looking at DLGs for a while but again the expense and the fact that I have no hot wire cutter make it difficult. I can't see justifying building a hot wire cutter at nearly the expense of a kit DLG, because I just don't think I'd make wings that way very often.
Apr 16, 2013, 07:15 PM
Rusty
Rusty Nail's Avatar
Hot wire cutting does not have to be expensive. Most modellers have all needed on hand.
See recent post.
The DL50 is not full span. DLG's around one metre are structurally easy with light glass or laminating film covering over foam. At 1.5m things are much more expensive.
A well known forgiving foil is the HM51 derivative of a RG14 foil. It has the advantage of having a thicker trailing edge and requires only a single template for a pivot cut.
A common two foil wing is the AG3/AG11 combination as used in the Apogee and later MiMi. Smaller wings can also be sanded in balsa or foam board sheets.
G_T on the HLG forum has a one metre and a poly foil that are both suitable for smaller gliders.
Apr 16, 2013, 07:39 PM
Andres Lu
joker24458's Avatar
Thanks Rusty, I'll try out the HM51 when I get the chance.
-Andres
Feb 24, 2017, 12:48 PM
here is my cheap simple foam DLG. AUW 195gr
Mar 04, 2017, 01:09 PM
and just finished another.
Mar 04, 2017, 07:16 PM
Ken's CAD Models
dz1sfb's Avatar
https://youtu.be/25brekJMH78
Just love how you nursed that baby keeping it off the ground.
Ken
Mar 09, 2017, 11:37 AM
1m DLG
Maiden flight. AUW 120gr.
Mar 17, 2017, 04:20 PM
1m
1.5m DLG. Two layered foam.
Nov 16, 2017, 03:49 AM
1.5 m DLG. This one is 211g AUW. Great flyer.
Question Aus - Where to find cheap foam? Stew_822 The Builders Workshop 24 Oct 01, 2013 09:53 PM
Build Log Carrying a GoPro on a homemade plane: simple and cheap, foam + depron, 1200mm wingspa tecdux FPV Talk 4 May 08, 2013 07:41 AM
Discussion Simple/Cheap/Small meter to ONLY measure mAH used rohdem Batteries and Chargers 21 Apr 15, 2013 08:15 AM
Yippee! Very Cheap & Simple Entry Level DLG – KFerret wingnutt Hand Launch 1 Nov 26, 2007 11:46 AM
Cheap,simple build DLG Knife3dge Hand Launch 18 Jul 18, 2004 01:56 PM
