Apr 04, 2013, 03:03 PM
Mini-HowTo
Simple FrSKY Receiver Flash How To with COM Port
This is a short simple tutorial to flash your d8R-IIPLUS FrSky Receiver For CPPM 27ms
I've had a couple of requests for this.
There are so many conflicting answers found in hundred page long threads so, Here is how I figured out to do mine directly from a PC's serial port.
Bridge Signal Pins 7 and 8 to enter programming mode
Description:
Description:
Connect as above, easy using a female to female servo lead with the one ground pin removed from the servo plug.
There are different firmwares available, possibly new ones since I did mine.
I used this version (d8rxp_cppm 27_build120926) The D8RXP Firmware works on the D8R-2PLUS Receiver
Run The FRSky Update tool
Choose the correct COM Port
Click the File button to load the firmware.frk file
Description:
Description:
Then apply power to the Receiver to a servo connector where you would normally with a BEC or battery. I just use my old school 4 cell NiCad for this stuff.
Some numbers will show at the bottom of the window, that indicates you have a connection to the RX. Then Click Download. Your RX should Update
Remove the Jumper on Pins 7 and 8
Yes I also could hardly believe how simple the solution is.
I hope this clarifies the confusion
Apr 04, 2013, 03:16 PM
This is the Jumper position for the above firmware which enables CPPM out on channel 1 and RSSI on channel 2
Bridge Signal Pins 3 and 4
Description:
Apr 05, 2013, 12:54 AM
Thank you, added to Frsky mega-index.
Apr 12, 2013, 11:38 AM
Before you start the process, the signal pins of channel 7 and 8 need to be linked.
This puts the RX into Bootloader Programming Mode.
Then proceed as described above.
Apr 12, 2013, 02:35 PM
Thanks. Completely forgot that. Ill add it in
Jun 25, 2013, 01:28 PM
Thank you.
This thread helped me alot!
Oct 30, 2013, 03:59 AM
Quadaholic
--Oz--'s Avatar
Attachment 5775523
Attachment 5672024
Attachment 5672025
Attachment 5672026
Will this work on the D4R-II?
What is maximum voltage on the RS-232 Tx/Rx can be applied to the Rx pins ?(there is many RS-232 voltages, EG +/- 3.3v, 5v, 9v, 12v).
I read some where (DIYdrones) the signals need to be inverted, is this true for the D8R-II plus and or the D4R-II?
TIA
Nov 01, 2013, 05:56 AM
How would I tell if the CPPM signal was ok as I've completed the firmware update, the receiver needed rebinding so I assuming it went ok, it reported as ok in the application. I'm using a FrSky D8R 2.
Afterwards I took the jumper out and then plugged in a servo into each channel and it worked as before. I was expecting channel 8 to be the CPPM output and so not drive a servo or at least not drive a servo in a controlled way from the transmitter but I can assign a switch on the transmitter to channel 8 and control it in the same way as before.
Tim.
Nov 01, 2013, 09:39 AM
There are two CPPM firmwares, the older, without RSSI and output CPPM on ch8, and the new, as in D8RXP, which outputs CPPM/RSSI on ch1/2 and let unchanged channels 5-8.
The later is known to address also the short 18ms frame issue, and named 27ms CPPM.
Nov 01, 2013, 05:06 PM
The XP firmware is recomended. Is this what you flashed? Then did you use the jumper on pins 3 and 4 as above to enable cppm on channel 1.
This jumper remains in place when in use as a switch. So you dont need to reflash when you want to use servos directly again.
Tim.
Dec 13, 2013, 02:20 PM
To upgrade the firmware of my D8R-II plus Rx, I see on the FrSky site two firmwares available:
-One for the XP version that dates from 2012
-A more recent one for the D8R-II plus dated 2013-06-05:
Firmware for D8R-II/D8R-II plus
Compatiblity : D8R-II plus / D8R-II(discontinued) /
UpdateTime : 2013-06-05
File Size : 4.96MB
MD5 : 49065291A4DDA3734C7560BEF9993672
Which of these two firmwares is best ? (I want CPPM of course but also the posibility to keep my 8 channels separately in PWM if needed)
Is this most recent D8R-II firmware still using a 18ms frame in CPPM ? (or is it corrected?)
Jan 16, 2014, 07:58 PM
Does anyone have tried this method with a serial to USB adapter?
I don't have any pc with serial ports anymore
Jan 22, 2014, 01:11 PM
Attachment 5775523
Attachment 5672024
Attachment 5672025
Attachment 5672026
Thanks a lot for such simple procedure. As I'm planning to follow these steps just one thing is that I can't understand, which is:
"Connect as above, easy using a female to female servo lead with the one ground pin removed from the servo plug."
But in the diagram there are 3 cables going from COM to Frsky. Can you please highlight where this ground pin has to be removed? Thanks.
Jan 22, 2014, 01:22 PM
Anyone successfully upgrade the X8R? The S.port software sees my com port fine, but it never finds my receiver. I even tried using diode shown in the diagram for the TX signal and still nothing.
Update: I finally got the X8R to upgrade through the S.port software by using Windows XP. I had to use the diode on the TX as shown in the upgrade PDF. It would not work for me in Win 7 or Win 8.
Feb 09, 2014, 03:22 AM
Can someone please point me in the direction of the documentation on how to flash x8r with a com port.
Dave
Question 9rx with Frsky module .. should I upgrade to DIY Frsky Tx? CyberCrash Radios 5 Jul 07, 2013 02:59 AM
Sold Futaba 7c 2.4GhZ with FRSKY TFR6 - 7 CHANNEL FASST COMPATIBLE RECEIVER Mikey 68 Aircraft - General - Radio Equipment (FS/W) 1 Jan 07, 2013 06:25 PM
For Sale Frsky d4r-ii - 4 channel receiver w/ data port, cppm, rssi jy0933 Aircraft - General - Radio Equipment (FS/W) 0 Sep 03, 2012 12:23 AM
