Apr 02, 2013, 03:23 PM
John
jk6672's Avatar
Covering
This is my first kit, my other balsa planes have been ARF with monokote.
I have covered the rudder with ultracote and that seemed fairly easy, I just used one piece on each side, overlapped the edge and sealed. With the wings, how may pieces should be used to complete the covering? I was thinking that I would need to cover the tips with one piece and the body of the wing with another piece wrapped from the TE up and over the LE and back to the TE.
Apr 02, 2013, 10:41 PM
Everyone has a different method, it depends on what works best for them.
here's a decent youtube of covering with Monokote and you'll see a part II on the side.
Monokote 101 Part I.mov (5 min 43 sec)
Hope it helps
Apr 02, 2013, 10:44 PM
Monokote 101 Part II.mov (4 min 6 sec)
Apr 02, 2013, 10:45 PM
Monokote 101 Part III.mov (6 min 55 sec)
hope these help
Apr 10, 2013, 08:09 PM
John
jk6672's Avatar
Thanks. Haven't done the wing yet, but I have finished the tail:
Apr 14, 2013, 09:24 AM
what setting was your heat gun on. i tend to burn holes on high and don't have enough heat on low.
Apr 14, 2013, 09:54 AM
John
jk6672's Avatar
I started out around 225 tacking and worked up to around 300. I've burnt holes too, but with monokote and heat gun on high.
Apr 14, 2013, 10:14 AM
John
jk6672's Avatar
I’m almost finished with the wing. I originally wanted to put LED lights, but then I changed my mind because I've never soldered something this small before (a servo lead or two, but that's different). I Since decided to go for it, because I knew if I didn't give it a try I'd be kicking myself in the butt latter.
I know the directions state to cover first, before putting the wing halves together, but I bonded them already so there wouldn't be a seam in the middle.
Apr 16, 2013, 09:32 PM
John
jk6672's Avatar
Soldering the LED's turn out not to be the difficult task I thought it would be. I finished one row tonight and tested, looks nice. I'll post a video once I'm finished.
Apr 18, 2013, 10:02 AM
John
jk6672's Avatar
finished the LED's and covered, but this photo is before covering.
Dec 28, 2013, 01:05 AM
MigLovin'
did you ever get the video you mentioned in the previous post?
For Sale Eflite extra 260 balsa version CUSTOM COVER xtremetoyz Aircraft - Electric - Airplanes (FS/W) 1 Jun 16, 2013 03:06 PM
Sold fairings, servo covers w/bumps & fairings, bump covers dhauch Aircraft - Sailplanes (FS/W) 11 Feb 02, 2013 06:51 PM
Discussion 18" Albatros covering question richb77uk Scratchbuilt Indoor and Micro Models 2 Jan 07, 2013 04:46 PM
Found Aspire covers J. Wydronek Aircraft - Sailplanes (FS/W) 4 Jan 05, 2013 04:05 PM
Question Covering Irons jim19 The Builders Workshop 2 Jan 02, 2013 10:30 PM
