Apr 03, 2013, 11:18 PM
DBlum's Avatar
Pat, that's a great idea using the foam leading edges on your flaps. I may have to try that sometime.
Apr 04, 2013, 12:44 AM
It's a fine fiddly business.
Robert R's Avatar
Whoa! What is this? 30 years ago one of the great free things we did with our preschool and grade school kids was wander around Kenmore Air Harbor looking at the planes. Back then the Beavers had round engines but a few years later along came the turbine conversions. This brings back good memories of little guys splashing through puddles in moon boots.
What a great idea for a build subject. Thanks Pat.
Robert
Apr 04, 2013, 11:46 PM
options?
I suggest that the Beaver be offered in both radial-engined and PT6 versions. Airframe's gonna be the same and some of us are partial to round engines. I admit that the turboprop engine makes an enormous amount of sense for the fullsize beaver's utility, but it's gonna be hard to paint up a Beaver in US Army colors. Or the amphibious Beaver I flew in out of Sydney harbor in Oz.
Apr 05, 2013, 07:34 AM
philipa_240sx's Avatar
It wouldn't be that hard to convert. Shorten the fuse forward of the wing and revert to the rounded tail design. The biggest challenge is the cowl though. I had quite a bit of fun VAC forming one for my 48" Berkeley Beaver.
I don't wish to take away from Pat's thread... Please continue.
Apr 08, 2013, 08:55 AM
P. Tritle's Avatar
Building the Tail Section
The vertical and Horizontal tails are built up in the typical fashion using a symmetrical airfoil section. Hinging is done with 5/32" wide bits of thin Cya hinge cut from Great Planes hinge stock.
Apr 08, 2013, 09:00 AM
P. Tritle's Avatar
Getting Started on the Fuselage
The side frames were done directly over the plans. Both are the same, so the same side view drawing was used for both. Then before starting to join the frames, the landing gear and float mounts were set up on the appropriate bottom formers. All of the parts for both the main gear and the float mounts will be provided in the kit so that the 32" floats can be mounted without the need for modification.
More to come soon. . . . PAT
Apr 09, 2013, 09:01 AM
P. Tritle's Avatar
Joining the Sides Frames
Joining the sides begins at the top of the cabin. The frames were pinned in place over the top view and aligned with machinists squares. The 3 middle formers are notches so will self align. Once those were in place they were tacked with thin Cya. Next up were the front and rear cabin formers and the IP former. With those in place and glued securely, the frame is stiff enough to lift from the board and add the bottom formers with the LG and Float strut mounts.
With the cabin area done, the front end came next with the firewall and middle formers, then it was aft to pull the tail together and glue in the aft formers. From here, the stringers will go in, then we'll get the servos and elevator control guides in and set up.
PAT
Apr 09, 2013, 09:12 AM
Robert R's Avatar
It is so much fun to watch this build come together. This one must go in my building queue.
Robert
Apr 09, 2013, 11:58 AM
I had to do a double take when I saw the last few build photos. I was expecting an Mk III Turbo Beaver... but it appears this is a Mk1 with a turbine conversion. The Mk I style empennage and the apparent lack of the 28" fuselage extension foward of the wing gave it away.
A very interesting build subject Pat. I don't know if I have ever seen a Mk I Turbo Beaver modeled before.
Apr 09, 2013, 12:06 PM
I think I can glue that..
bob_suruncle's Avatar
I have been away from RCG for a long long time.... Pat Tritle building a beaver is certainly something that would bring me back for a look! I am watching!
Apr 10, 2013, 05:43 AM
DLG Bug Bit Me
Tim Harbour's Avatar
What plans are you building from?
Apr 10, 2013, 05:47 AM
I eat glue
Mine
Apr 10, 2013, 09:17 AM
P. Tritle's Avatar
TL, the Beaver is a brand new design. Once the p-type is finished and flown I'll be offering it as a Short kit. The kit will go out as the Turbo version, but the fuselage is designed such that for those who prefer the radial version, all you'll need to come up with is a cowl. The firewall is in the original location, so it'll just be a matter of eliminating the front former bay when framing the fuselage.
PAT
Apr 10, 2013, 09:19 AM
DLG Bug Bit Me
Where do we find some info about them?
Apr 10, 2013, 09:22 AM
vonJaerschky's Avatar
About Beavers or Pat's models? Pat has a "few" designs already. http://www.patscustom-models.com/
For Sale Flyzone deHavilland DHC-2 Beaver Raehm Aircraft - Electric - Airplanes (FS/W) 10 Sep 09, 2013 05:44 PM
Sold CRAZY PRICE DROP **HHS Dehavilland Beaver 72'' w/s ** with fiberglass cowl !!! Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 1 Jan 27, 2013 05:07 PM
Discussion Unionville Dehavilland Beaver - 8' Turbo methanolmaniac Scale Fuel Planes 8 Jan 26, 2012 01:04 AM
For Sale Unionville Hobbies DeHavilland Turbo Beaver doctord Aircraft - Fuel - Airplanes (FS/W) 3 May 10, 2010 09:12 AM
Discussion 60" electric Turbo Beaver availability? benski Scale Kit/Scratch Built 0 Jan 18, 2010 03:31 PM
