Apr 02, 2013, 06:02 AM
P. Tritle's Avatar
Build Log
DeHavilland Turbo Beaver @ 60"
It's been a long time coming, but I have finally started construction on the 60" Beaver. She'll be set up on wheels, skis, and floats once it's all said and done.
Construction begins with the flaps. This time, rather then going with the typical flat faced lower hinge arrangement, these will be set up Fowler style using robart pin hinges which requires a little different construction style. The basic flap assembly is wood with a blue foam leading edge so that the flap can be shaped to the required airfoil. The basic assembly is done, will fill in the foam bits in a bit.
Apr 02, 2013, 06:04 AM
P. Tritle's Avatar
Building the Ailerons
Nothing fancy here, just the typical top hinge style -- simle, and it always works.
Apr 02, 2013, 06:11 AM
P. Tritle's Avatar
Building the Wings
Construction begins with the main and rear spars. Since the parts are cut on 24" sheets, they are done in 2 parts that are joined with a scarf joint at the outboard end. The sections were pinned in place over the plan and glued together.
Once the spars are done the basic assembly was laid out and glued up. The egg-crate style of construction brings things together quickly.
Apr 02, 2013, 06:16 AM
P. Tritle's Avatar
Finishing the Wings
The panels were sanded to shape and the joiner tubes added. Once that was done, the foam flap leading edges were glued in place abd trhe final sanding and shaping done on both the flaps and ailerons. From there the hinges were inserted to complet the process.
Next up we'll get started on the tail section.
PAT
Apr 02, 2013, 06:59 AM
I eat glue
Oh yeah, can't complain about a Canadian Beaver!!
Any chances of the radial option on it as well?
Apr 02, 2013, 09:51 AM
vonJaerschky's Avatar
The turbine version? Interesting choice. At least with an electric motor it will sound more scale. Everybody that watches a Beaver from the ground likes the radial version. Anybody that has to fly or ride in them on a regular basis much prefers the turbine!
Apr 02, 2013, 09:55 AM
Joe Pierson's Avatar
Hi Pat,
Now That will be a nice DeHavilland Turbo Beaver @ 60" Wow thats large Airplane for you
Joe
Apr 02, 2013, 12:17 PM
This is gonna be awesome! Can't wait to see it finished, because hopefully that means I can buy one!
Apr 02, 2013, 05:12 PM
Yankeeone's Avatar
Hey Pat, you're using the same type of hinge system hat was used on my Top Flite P-47. I was a little dubious at first but the first time I used the flaps - WOW!! I also used a LITTLE more flap than recommended. I used approx. 75 degrees versus the 40-45 degrees per the plan. I looked at the real plane and this used a BUNCH of flap. What the heck - I tried it and it worked. I was able to do 45 degree landing approaches with no problems. With flaps down it flew like a trainer. Did need about 5% down elevator but that was all. On this light of a model you should be almost able to stop in mid-air. Great touch, can't wait to see the results.
TTFN The Yank
Apr 02, 2013, 05:15 PM
IWC
IWC
subscribed
Apr 02, 2013, 06:57 PM
Ohh boy!!!!!!!!
Apr 03, 2013, 08:32 AM
Doug Bartley's Avatar
The Turbo Beaver is my favorite plane of all. At your typical weights, she will be a super flyer. Looking forward to seeing the build progress. Doug B
Apr 03, 2013, 09:06 AM
I've been awaiting this build for some time now since I heard you had it in the works!
Absolutely Subscribed..........
Apr 03, 2013, 10:00 AM
Dangit!! I might have to get this one too! I'm used to seeing lots of regular beavers where I live, so the turbo is definitely something different.
Apr 03, 2013, 12:46 PM
philipa_240sx's Avatar
Yay! I was looking forward to this build.
For Sale Flyzone deHavilland DHC-2 Beaver Raehm Aircraft - Electric - Airplanes (FS/W) 10 Sep 09, 2013 05:44 PM
Sold CRAZY PRICE DROP **HHS Dehavilland Beaver 72'' w/s ** with fiberglass cowl !!! Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 1 Jan 27, 2013 05:07 PM
Discussion Unionville Dehavilland Beaver - 8' Turbo methanolmaniac Scale Fuel Planes 8 Jan 26, 2012 01:04 AM
For Sale Unionville Hobbies DeHavilland Turbo Beaver doctord Aircraft - Fuel - Airplanes (FS/W) 3 May 10, 2010 09:12 AM
Discussion 60" electric Turbo Beaver availability? benski Scale Kit/Scratch Built 0 Jan 18, 2010 03:31 PM
