I think you may have the wrong model set in your TX, FBL90 is fixed pitch and should have no (or very little) swash travel during throttle changes. I verified this on my V955 (=HFP80(fka FBL70) =FBL90's little brother) Looking at the bird tail to nose you should get the following servo actions (MODE2): Left stick; nothing at all Right stick (aileron) to the left; left servo down - swash lean left Right stick (aileron) to the right; left servo up - swash lean right Right stick (elevator) forward: rear servo up - swash lean froward Right stick (elevator) back: rear servo down - swash lean back |
1 turn on transmitter 2 connect battery ,then immediately place on a level surface 3 wait until the blades twitch 3 times 4 now you are ready , hop it off the ground , do not attempt a slow rise . the giro needs to learn its orientation each time a battery is connected , if you hold it in you'r hand the chances are it wont be level so when you throttle up the swash will try to move to the wrong orientation , when taking off the flybarless heli's need to take off quickly not a gentle rise , at least not till you get the hang of it . on the x6s try these settings for a nice docile flight D/R AILE1 E 20 R 70 D/R ELEV1 E20 R70 then switch to position 1 on the dual rate switch |
Regarding the interest in a good flight timer, here are some features that I have on my Deviated DEVO 10 that I really like:
- Timer starts and stops based on whether the throttle is zero (including if throttle hold is set) - It has an audible beep, but it also has a haptic vibrator so I can feel the beep in case I don't hear it for some reason. - I can have two different timers that count down and count up which can be started by different events or buttons. Now I don't use the third feature that often, so if I had to prioritize, I'd say the first one is really very, very useful and the second one is a really nice feature to have. |
This is mode 2, throttle on left correct? I'm pretty new to helis myself but it sounds like there is some sort of a mixer set in the Tx. Like for a CP bird?
If HiSky wants to do something with the deviation devs they should contact FracturedBlue. He is already started work on a deviation version for the FrSky Taranis as the next platform. Although the Taranis has some really cool features the use of PPM in some of the modules makes it no better than some of the cheaper TXs. PXX seems more robust and faster than using PPM. Look at the way Deviation uses the Devo SPI bus to select different TX modules, faster communications between MPU and TX module. Also like the global variables and programmability of the OpenTX firmware, something a little lacking in DeviationTX.
Man id really like to know if the hcp130 will be out by February, found a awesome deal on a 130x with hop ups...and maybe we could use some more pictures too...lol
I would also like more news on the 130 but it is quite reassuring that they have not just made a cad model, got some parts together & put it on sale.
I have also been following the t-rex 150 thread & they have been having some problems with it, I hope Hisky are working out any issues & will release a good product |
Hey guys, just came back from an extended road trip a few days ago so my apologies for the lack of involvement lately. Will answer your questions tomorrow when I get back to work.
Merry Christmas to you all from Hisky and me personally. Cheers for all that you guys do to form such a wonderful community. Wouldn't trade it for anything! |
i do like that new canopy colour scheme! and of course the new shape it has is much better also
phil |
Thread Tools | |
Similar Threads | |||||
Cool | The Official Tarheel R/C Flyers "discuss anything" thread | Mike_Then | Tarheel R/C Flyers | 9645 | Feb 22, 2021 01:49 PM |
Discussion | The mSR Discuss anything Thread | bublehead | Micro Helis | 12753 | Nov 04, 2015 09:44 AM |
Discussion | 3d talk thread,Discuss anything 3d | Benjamin Kies | 3D Flying | 7 | Feb 04, 2015 06:41 AM |
Discussion | E-flite Blade SR 120 Discuss Anything Thread | BJ64 | Micro Helis | 694 | Jan 29, 2012 11:21 AM |
Discussion | Blade mCP X Discuss anything thread | A Rdnek | Micro Helis | 457 | Jul 26, 2011 11:34 PM |
