This thread is privately moderated by grmis, who may elect to delete unwanted replies.
Mar 25, 2013, 06:25 PM
grmis's Avatar
CRIUS AIO PRO + ArduplaneNG + Dynam HawkSky
Two days ago I did the maiden flight of my autopilot system:
- Plane: Dynam Hawk Sky
- Flight controller: CRIUS AIO Pro (v1, first batch sold by HobbyKing)
- Software: ArduPlaneNG (r268). I found a lot of useful informations on the blog of Jean-Louis Naudin.
- For the PID parameters, I took those given here for the bixler. However, because the plane is somewhat overpowered, I reduced to 50% the max throttle in auto mode, and set to 35% the cruising throttle.
- GPS: uBlox LEA6H
- Receiver: FrSky D4R-II in CPPM (PPM SUM) mode (single wire going to the CRIUS board). One just has to add ' #define SERIAL_PPM ENABLE ' in APM_Config.h, and the PPM_SUM line goes to the throttle input of the Crius board.
I tested the stabilize, fly-by-wire-A (FBWA), return to launch (RTL) and Loiter modes with success . With some wind blowing at 10-20km/h the loiter trajectory was not quite a circle, but ok. Otherwise the plane was stable and ArduplaneNG nicely managed the throttle to maintain the speed and altitude.
I am now waiting for a minimOSD to install the FPV gear back in the plane.
Dec 20, 2013, 01:42 PM
Please have ready ArduPlaneNG for aircraft not flying wing?
Dec 20, 2013, 02:43 PM
grmis's Avatar
Hi. I am not sure I understood your question... but, yes, ArduplaneNG works for aircrafts and flying wings.
Dec 21, 2013, 04:59 AM
Hello Give download ArduplaneNG.zip (rar) on Bixler? I can not https://code.google.com
Dec 21, 2013, 09:21 AM
It seems understood, ROLL and YAW must move together as did the firmware?
Discussion Disarm motors CRIUS AIO Pro Arducopter "MegaPirateNG V2.8 R2" Polleke Multirotor Drone Electronics 3 Jan 06, 2013 01:35 PM
Discussion APM2.5 vs CRIUS aio pro little nellie Multirotor Drone Talk 43 Dec 12, 2012 12:39 PM
Discussion crius aio pro or multiwii 2.0 pro? SPCustoms Multirotor Drone Talk 4 Dec 12, 2012 11:11 AM
Discussion Rabbit or Crius AiO Pro janekx Multirotor Drone Electronics 15 Sep 11, 2012 07:51 AM
Help! Crius MW AIO Pro Tx, Rx flash but no up-dates Flying Canuck Multirotor Drone Electronics 3 Aug 23, 2012 04:38 PM
