Mar 18, 2013, 09:01 AM
Isaiah 40:31
Clickety's Avatar
YF-23 Black Widow, Grey Ghost
Hello,
Welcome to my YF-23 discussion / build blog.
Here you will find over a year of development, from my very first flights, experiments with prop-shafts, stabilizers, EDF and Pusher powered versions.
Here are a few 'staged' photo's of the design.
I've posted a complete set of plans on my blog too (you have to click 'continue reading' to reveal the plans at the bottom of the page) :-
https://www.rcgroups.com/forums/member.php?u=435614
PLEASE NOTE : I'VE REMOVED SUPERSEDED DRAWINGS FROM THIS DEVELOPMENT THREAD. The final plans are on my blog.
If you build one please post pics!
PUSHER PROP in Grey Ghost scheme :-
YF-23 Grey Ghost Parkjet (4 min 15 sec)
EDF version in Black widow II scheme :-
Black widow II Twin 50mm EDF Parkjet (5 min 10 sec)
Cheers
Clickety
Mar 18, 2013, 11:37 AM
f1wanabe's Avatar
Hello Clickety, looks very nice! In fact, it is the most scale looking model I've seen to date. Excellent work! We have a score and fold model on our site www.frcfoamies.com for download. Jay has a knack for getting score and fold to look scale. The nacelles are not scale since we need to leave a clean path for the prop wash on the midmount motor. But with a rear mount it would be possible to add do scale nacelles. 2 night build time!
Here's mine with all moving vtails :
Description:
Description:
Flight video:
Boxermad84 YF23 With All-Moving Surfaces (5 min 13 sec)
and all moving surfaces:
YF23 All Moving Surface Set Up (4 min 24 sec)
Mar 18, 2013, 01:20 PM
Dont forget the velcro straps
corsair nut's Avatar
looks awesome! i did a scale profile edf version to verify cg and throws, flew good once i got the cg right, which is around the half way mark on the le, between the fuse and wing tip! crazy far forward to get stable flight. i also had full flying stabs, took alot of throw to get the desired flying qualities, once i was at that point, it was a blast to fly, and it looked awesome in the air! i might have to use your plans to build a twin 90mm version!
Mar 18, 2013, 02:54 PM
Isaiah 40:31
Clickety's Avatar
Yf-23
Thanks Guys, That,s really helpful. On my plans, I've got the C.O.G a long way forward to match Vicentel's design. I'm looking at trying it again off the dolly this coming Saturday.
The 90mm fan version would be awesome - and give some room for retracts.
In fact I had been toying with the same idea of using some 9mm Depron and 9mm Carbon Rods - a simple scale-up! Then I could fit some decent retracts and that really would be an impressive airplane!!
I wanted to get this design bullet-proof first before I took it further though. Please let me know how you get on with that.
Cheers
Clickety
Mar 19, 2013, 08:40 AM
Crash-safe
lessram's Avatar
Congrats ! Looks great.
I tried for about half a year to get a decent construction for a yf-23. Then I gave up
I will definitely add this to my build list.
Over lunch, I browsed through your plans/guide (and already finished the widow in my head )
I have a few questions regarding the construction guide:
Step 4: Where exactly to glue the turtledeck bulkhead
Step 12,14,15: I couldn't find any of the 3mm depron parts, did I miss something ?
Thanx a lot for the plans
Mar 19, 2013, 12:01 PM
unclecrash's Avatar
Here is a link to my blog. I am building a twin 90mm yf23 it is on hold for a while. Scoll down the page to see it. https://www.rcgroups.com/forums/member.php?u=44257
Mar 19, 2013, 06:00 PM
Isaiah 40:31
Clickety's Avatar
Yf-23
Great Stuff Unclecrash! I've been having a good look at your posts and am really Impressed! That is a PROPER model YF-23 - Much respect!!. When will it fly? Please take videos etc.
My approach was to try and keep it cheap and fun, and able to be built pretty quickly. It would be just too painful for me seeing something so lovely as your bird crash. Although I think it's fabulous. I wish I understood more about the airfoils and how to calculate Aerodynamic CofG etc. I think the laymans approach is to make one and throw it until it works!!
Lessram, Well spotted! I've now uploaded a partsheet for printing out at A3 size - I had forgotten this!
Also the Turtledeck bulkhead locates at the intersection of the two Turtledeck top pieces. The forward face is 108mm back from the intersection of the Leading edge of the wing/fuselage. I've made a mental note to update the drawings!
Mar 19, 2013, 06:13 PM
Classic jets rule
AIR SALLY's Avatar
click is yours a pusher prop or do you have edf's in it ?
Mar 19, 2013, 10:12 PM
Isaiah 40:31
Clickety's Avatar
Pusher or edf ?
Hi Air Sally,
My plans allow for both!
Cheers
Clickety
Mar 20, 2013, 06:18 PM
Classic jets rule
AIR SALLY's Avatar
shes a looker
Mar 21, 2013, 12:08 AM
unclecrash's Avatar
I hope to start back on mine soon. It would be nice to get it in the air sometime later in this year. I might have to build a smaller one to play around with at the local college. It would be cool to put a small set of retracts in one as there is a short tar parking lot we fly park flyers from. good luck with your Maiden. Are you planning on flying the one in the pic's on edf if so what size 50mm twin
Mar 21, 2013, 02:49 AM
Isaiah 40:31
Clickety's Avatar
Yf23
Thanks Air Sally.
Yes Unclecrash,I am looking to fly the EDF one this weekend off the dolly. It's got twin 4S 55 mm PDF units in it. I found them on hobby king they're pretty powerful little units. In hindsight I wish I'd built the pusher first as I think it would have been a lower risk exercise, I think the trick with EDF is making sure it has enough take-off speed because as they don't tend to have much torque. I liken it to riding a bicycle and setting off in third gear!
I've printed out a set of plans to build the pusher soon.
I'm test launching using a 1.4mh battery and then try the 1.8mh battery. Of course it's a trade off I don't expect much flight time.
I'll keep you posted!!!
Mar 22, 2013, 05:20 PM
unclecrash's Avatar
Sound's good, how does your dolly work is it pulled by bungee or under the power of the plane.
Mar 23, 2013, 12:04 AM
Awesome work! Thanks for sharing & the many hours it must have taken to complete this project-
Mar 23, 2013, 07:21 AM
Isaiah 40:31
Clickety's Avatar
Yf23
Thanks Fred!
Unclecrash - the Dolly is a lightweight depron one (untested) which I want the plane to push under its own weight. I've not had a lot of success with bungees. I thought it might be a gentler approach. (My second launch was with a bungee - but my COG was too far back and it pulled the underbelly off!)
I've got large wheels on it, so that it may work off grass.
New Product YF-23 Northrop Grey Ghost 2 x 70mm mopetista Foamy EDFs 47 Nov 09, 2014 09:08 AM
The Start of my YF-23 Black Widow II Project RCWorks Foamies (Kits) 39 Jul 14, 2009 07:24 PM
Discussion YF 23 Black Widow Eaglehawk752 Pusher Prop Jet Models 2 Sep 28, 2006 01:50 AM
Northrop/McDonnell Douglas YF-23 Black Widow II Esprit440 Pusher Prop Jet Models 12 Jul 31, 2006 12:47 AM
Yf-23 Black Widow Twin Midi Plane Crazy Electric Ducted Fan Jet Talk 23 Feb 08, 2005 04:25 PM
