Mar 15, 2013, 04:11 AM
P is Back.
Piery's Avatar
New Product
The best testers from RCG, thank you... (CobraHD RC Transmitter control way) CSA come
CobraHD
The manual of CobraHD is in the attached file
Thunderbolt
Cloud Spirit
Testers Chosen for New FPV Gear (news link by awagar)
https://www.rcgroups.com/forums/show....php?t=1855001
Boscam Cobra HD FPV Camera (test result show by whakahere)
https://www.rcgroups.com/forums/show....php?t=1870641
20130402Update
Arrangement and specifications:
CobraHD
BOSCAM HD39 _ A snack-shaped FPV purpose full HD video piloting camera
Features:
* FPV firmware adopted, just show a red dot when recording, very clear, good to word with OSD (pilot OSD);
* Record full HD video to the micro SD card with audio (audio can be off), and give a live VGA signal for Tx to send back to ground;
* Nice shielded parts for FPV purpose, limited RF noise and limited interruption for flying;
* With 20cm flat cable to connect the main unit and the camera unit;
* Very light and yet very powerful, just 40 grams;
* Video/Photo trigger from radio transmitter;
* Power from the planes batteries, use 5pin cables.
Thunderbolt
BOSCAM TS5833 _ A ultra-powerful 5.8GHz 2000mW Tx
* 7-24V input, 2S-6S
* with a channel display and switcher
* about 52 grams (turn out to be 37 grams, we even have 33grams one, but it is not the final one)
* 8 ch, 2000mW
Cloud Spirit
BOSCAM Circular Polarization Antenna _ Cloverleaf Antenna
* nice designed antenna
* easy to distinguish the Tx and Rx antenna
And now, the CobraHD is here. And I have to point it out, that, it is still not the perfect, need your advices to get it better.
Notice:
The red glue at the both sides of the flat cable
Flat cable connect camera unit and the main unit, can not be opposite. We will print the flat cables after your test in production.
The CobraHD was designed to packed with main unit and camera unit separated, and put the flat cable inside the gift box, but we can only connect and glued them together for testing.
For Thunderbolt and Cloud Spirit
We modify their cases.
20130417Update
About the Start/Stop control (Boscam RC Transmitter Control / RCTC)
We here post the way to connect the CobraHD with FUTABA Radio Rx, to have the Remote start/stop function, so you can control the CobraHD when your planes are flying hight up there.
First, Connect the everything with the multi-functional cable:
Power up
Then, choose a channel of Futaba Rx for CobraHD, I use ch 5 as example:
Set the ch 5 to SC 3 way switcher:
Up, take a photo
Middle, stop taking a photo/video
Down, take a video
We will post a video of how to do this soon.
Cloud Spirit Antennas (CSA)
(Tuned Pair TxA and RxA set)
Product:
Cloud Spirit Antennas (TxA and RxA, a tuned pair in one set)
* TxA is a circular-polarized omni antenna with three lobes
* RxA is a circular-polarized omni antenna with four lobes
Gain:
* TxA 1.1dBi
* RxA 1.4dBi
SWR:
* 1.2.:1, Tuned for 5645 5945 MHz
Polarization:
* RHCP, Right Hand Circular Polarization
Connector:
* Straight RP-SMA Male
Length:
* TxA 78.5mm
* RxA 98.8mm
Weight:
* TxA 10.3g
* RxA 11.5g
Package
* Size: 135mm*85mm*45mm
* Weight: 63.3g
Why Cloud Spirit Antennas?
1. CSA is a special tuned 5.8GHz antenna fit all frequencies, with great result on stable video receiving and expand your video cover range.
2. Nice design covers to protect the inner parts from damage and keep it work always in same good way.
3. Colour and leg length distinguish the Rx and Tx Antennas, orange for Tx, and blue for Rx.
4. RF friendly materials is adapted for the covers.
5. With tooling to make sure all antennas with same shape and angles for the inner parts, unlike those hand-made.
6. Experienced engineer ensure every antenna tuned to a great level.
7. Almost double the range of 10mW 5.8GHz VidTxRx compare to original antennas
8. Last but not the less important, this is a base antennas for us, we will bring even much better ANTENNAS from it.
Thunderbolt 2000
(Thunderbolt 1000 coming by the end of this month)
Thunderbolt 2000 (TS5833) is:
5.GHz with 2000mW,
33dB +-1dB,
37grams,
with nice heatsink and fan,
power on work,
with channel display and switcher,
size very small,
RP-SMA female connector,
with a 2.0dBi omni antenna.
A special multi function cable,
power by 2-6S battery, in fact, 7-28v even 7-30V wide voltage adapted.
Thunderbolt 1000 (TS5830) is:
5.GHz with 1000mW,
30dB +-1dB,
about 30grams with case.
with all fr (IFtron/Fat Shark band, Boscam A B E band)
And a special Boscam RC Transmitter Control / RCTC function
Now, we worry about that the Thunderbolt 2000 (TS5833) is even too power than we first think, with more than two channel showed 34dBi. It is truly a beast level Tx.
Specification of Thunderbolt 2000
Product: Thunderbolt 2000mW 5.8GHz
Model No.: TS5833
Frequencies: 8 channels from 5.645 to 5.945 GHz
CH1 5705 CH2 5685
CH3 5665 CH4 5645
CH5 5885 CH6 5905
CH7 5925 CH8 5945
Power: 2000mW (33dB +-1dB) of certified output power
Power On Working: Plug and Play
Input Voltage: 7-24V DC, 2-6 cells battery via input connector,
Cooling System: whole body heat sink and cooling fan
Channel Switching: channel button and channel display
Antenna: RP-SMA female 50 ohm connector
Accessories: one original omni antenna, one multi function 5pin cable
Size and Weight: 62mm*42mm*20mm, 37g
Package Size and Weight: 135mm*85mm*45mm, 82g
Thunderbolt 32ch Tx and Rx:
They work on A B E and F bands:
1 2 3 4 5 6 7 8
A: 5865 5845 5825 5805 5785 5765 5745 5725
B: 5733 5752 5771 5790 5809 5828 5847 5866
E: 5705 5685 5665 5645 5885 5905 5925 5945
F: 5740 5760 5780 5800 5820 5840 5860 5880
Mar 15, 2013, 04:33 AM
P is Back.
Piery's Avatar
We want to bring in something really cool. Your experience is the first thing we care. TESTER WANTED!! To help us get all these ready for you.
Let me introduce:
CobraHD, a snack-shaped light weight FPV purpose camera;
Thunderbolt, a extreme powerful 5.8GHz Tx, with channel display and switcher, small and light, and her another part is a 24ch high-sensitive Rx coming a little bit latter;
Cloud Spirit, improved Clover-Leaves Antenna, Now, orange for Tx, blue for Rx.
Mar 15, 2013, 04:51 AM
P is Back.
Piery's Avatar
Test contents:
1. To check if there are any interference from CobraHD to RC, or other devices on the planes;
2. To check is the thunderbolt, the range it cover, and how powerful it is;
3. Two version of Cloud Spirit are coming, and we want to test the first one, the coming one is still under developing, and will come with hi-sensitiveness.
Mar 15, 2013, 04:57 AM
P is Back.
Piery's Avatar
What you get and what you need to do:
Free items for testing;
Need your review on the tests.
You need to be experienced hobbyists in the RCG, and you should be just and give the honest advice for us.
Mar 15, 2013, 10:58 AM
Galantly bodging away
I don't believe I have the experience to test for you and give the answers you need so I will have to pass (I would love to help but feel others would be better suited to this task) One thing I can say Is I often test things to destruction (not intentionally but I often find myself repairing things for some reason or another) I would be a good reliability tester lol.
I do have one thing I would like to say after looking at your product (camera/recorder)
Please do not be tempted to glue the (FFC/FC) ribbon cable connecting the camera to the recorder!!!! (or at the camera board end!)
Use a sturdy, high quality connector on the boards instead, if possible.
FPV-ers are people who tinker with things, replacing the ribbon cable should be made easy in case of any accidents. If it is glued the cable may ruin the connector if it needs to be removed.
Replacement ribbon cable availability will be a necessity for continued use of this product IMHO.
I'm sure you will be aware as the manufacturers of this product that a good (class 6 or above) TF card is essential for HD recording
Mar 15, 2013, 12:33 PM
Mitamar's Avatar
It will be pleasure for me to give full review for your product with full range check. Video record from your camera as flight camera recorded with my dvr. I live in Israel. Please let me know if you are interested . Here is one of my videos
(4 min 4 sec)
(it's not a review) I have some more In my channel.
Itamar
Mar 15, 2013, 01:18 PM
USA: LakeGeorge, New York
Cool Product,
Hope it goes well....I like this "gum stick' HD Camera.....
What 'mW' (specs) of the 5.8ghz VidTx.?
Give it to Markus123456.....
He knows' his stuff
https://www.rcgroups.com/forums/member.php?u=112092
Mar 15, 2013, 02:03 PM
Crashaffinity on youtube
CrashAffinity's Avatar
i'd certainly be interested in reviewing it, since i use 5.8.
Here's a comparison vid i did 900 vs 5.8
FPV Video Comparison 5 8 vs 900 (3 min 10 sec)
and some of my general flying
F550 FPV hex january 2013 highlights (6 min 58 sec)
edit: of course i do long range on my super sky surfer as well, didn't post any of those videos, they're on my channel though
Mar 15, 2013, 02:23 PM
throw new IOPilotException();
IceWind's Avatar
Can you share some details on the Thunderbolt?
I've been spending quite some time trying to fix range issues on my FPV Multicopters, mostly due to the RC radio system been severelly affected by my 900Mhz FPV gear.
So it would be interesting to check how that would behave.
Mar 15, 2013, 04:55 PM
Zwyser's Avatar
I could do some testing, but I would need to know more about the products.
Here is my channel: www.youtube.com/user/Zwyser/videos
Mar 15, 2013, 05:38 PM
Registered FPVer :)
markus123456's Avatar
Originally Posted by Piery
Test contents:
Hi Pierry,
I will test this cam/tx if you want me to. You can rest assured to get a complete and objective feedback on it. Send a PM if you are interested.
Markus
Mar 15, 2013, 06:11 PM
Kiwi in Germany
whakahere's Avatar
Well I have been testing 5.8ghz gear for a few years now. (see the 5.8ghz 200mw distance record thread)
If you are looking for people experienced in testing 5.8ghz then this thread has many of the guys that have pushed the limits of the gear. Myself included of course. done the 10km 200mw test.
Mar 15, 2013, 08:03 PM
Piery
What country do you reside in?
Markus and Whakahere are my TOP 2 Choices....
PLEASE SEND THEM THESE,,,,,they know what there doing'....
If your really CONFIDENT about your product, these 2 guys will "KNOW"....
If it passes', you'll SELL a lot of your products WorldWIDE.!!!!
Look up there 'TESTINGS/and REVIEWS' of 5.8ghz Video RangeTests' and
how VidTx are Made.......etc......
Mar 15, 2013, 11:54 PM
P is Back.
Piery's Avatar
Originally Posted by markus123456
Hi Pierry,
Markus
Sure, Markus, it is GREAT that you can do it!!
Mar 15, 2013, 11:56 PM
P is Back.
Piery's Avatar
Whakahere, we can trust you for the test in your homeland! Great to have you join us.
Help! I would like to know how this heli ESC works for airplane use Rhondas Coaxial Helicopters 14 Jan 23, 2013 12:14 AM
Discussion What sort of camera and software would I need to produce something like this? lovegroove FPV Talk 4 Jun 22, 2011 08:22 PM
Discussion Would like a confirmation that I can charge like this before I try it... get dustd Batteries and Chargers 11 Jan 21, 2011 05:01 PM
Discussion E-bay Parkzone: Would you buy something like this? K4RT80Y Micro Ready-to-Fly 2 Mar 23, 2008 05:23 PM
Yippee! What if AXI made a prop hub that would drive GWS props? Maybe something like this. power Power Systems 19 Mar 11, 2004 08:10 AM
