Mar 12, 2013, 10:55 AM
Castle ESC throttle calibration question.
Ive sold my trex 500 with Castle ESC but the buyer doesn't have a castle link.
The castle is in governer mode with fixed endpoints. Initially when I switched this on after configuration I was forced to calibrate the throttle on my DX8.
The buyer has a DX6i
Any ideas whats the best thing to do? Do I need to switch off governer mode and back on before posting or can the buyer set his DX6i to the same throttle settings as my DX8?
Cheers
Christian
Mar 13, 2013, 05:06 AM
RS Rogers's Avatar
The mode the esc is in won't matter if that's the mode he intends to fly in. All he needs to do is put a temporary linear curv in his Tx, do the throttle calibration on his Tx then put the necissary curves for the gov back in the Tx.
If he is using the same gyro / FBL unit I would give him your gain settings for the tail, those should be pretty much the same. If that is off he may not know if he is fighting gyro or gov gain if he has tail issues.
Steve
Mini-HowTo Castle Quick Tip: Throttle Calibration Part 1 of 2 Clintstone Castle Creations 45 Dec 03, 2013 11:37 PM
Discussion Throttle Cut and Castle ESC - Weird behavior ryanbe15 Electric Plane Talk 3 Feb 17, 2013 10:05 AM
Discussion How Do You Throttle Calibrate an ESC with Red Wire Cut daskim Multirotor Drone Electronics 1 Jan 14, 2013 02:05 PM
Discussion Elogger throttle monitor calibration elliott000 Eagle Tree Systems 0 Jan 07, 2013 11:08 PM
Discussion Devo TX ESC/Throttle calibration scub Radios 1 Jan 05, 2013 09:32 PM
