Thread Tools |
This thread is privately moderated by IceManPro, who may elect to delete unwanted replies. |
New Product
BL-3GRC ICE MAN Gyro
The newest and most advanced RC Airplane Gyro Stabilizer / Controller on the market is HERE.
![]() For expert and novice pilots alike, with Quick Start and Advanced features anything is possible. Here are just some reasons why you might want to buy one: I fly fast and want fast gyro response but my RC Tx only outputs pulses at 15ms. Would be good to increase to say 6ms to support my fast digital servos -with the BL-3GRC YOU CAN Would be good to fly my delta wing slowly on landing to save on runway length - With the BL-3GRC YOU CAN add flaperon function even for delta wing I have a big aircraft which needs lots of runway to land. Some sort of speed brake would be good - with the BL-3GRC YOU CAN with two stage flaps, third stage ailerons up for air-brake / ‘crow’ function I have a big beast of a plane with dual wing servos, even two opposing servos for the rudder. Would be good to have just one controller - With the BL-3GRC YOU CAN with two configurable outputs per axis I like to teach my novice friend how to fly but he has a habit of veering off to the side of the runway on take-off. Would be good to have very large gyro rudder gain just at take off - with the BL-3GRC YOU CAN Would be good not to have to re-trim my aircraft after a long time or remember which RC Tx has the trim saved. Great if the gyro can automatically save the trim settings - with the BL-3GRC YOU CAN just pick up any RC transmitter and set all trims to zero I like to fly fast but want good stability during slow landings with flaps or flaperons - with the BL-3GRC YOU CAN set real time two gain switch for fast / slow flying. Or just let the AGC (Automatic Gain Control) handle for you - available independently for each axis I am a bit of a novice and only have a small area to fly in, would be good to find a way to keep the turns tight and stop flying away so far. I’m still a bit nervous about using the rudder myself, would be good if some rudder could be applied during my turns - with the BL-3GRC YOU CAN I have a foamie flying wing aircraft would be good to hide a controller inside the wing - with the BL-3GMod YOU CAN. The MOD version is a small 35mm square, thin PCB, you can cut off or de-solder the pins, connect (solder) only the inputs and outputs you want, and have a flying wing with controller/flaperon function/gyro buried inside. Such a low price too, talk about a game changer! I work for Bluelight so don’t take my word for it, check out the user manual and PC set up s/w before you buy. www.bluelight-tech.com Check out what others are saying on RCGroups forum here And on Youtube.. Setting up
Get yours today.. V3.0 just announced. Adds the following features: · Increased internal processing speed, to now support up to 500Hz Electronic Speed controllers. This for multi-copter stabilization. · Support for Tri and Bi copters (as well as quad and hex) · Gyro function invert with POTs option (no need for PC connection) · Multi servo aircraft can have reduced range on the secondary servo outputs on all 3 axes · Differential Aileron is now supported (to reduce induced yaw during turns due to down aileron drag). This also implemented for delta wing aircraft · Pass through mode. Each input (6 in all) can pass through directly to the outputs with only the addition of the gyro action to each output. 2 pitch, and/ or 2 roll and / or 2 yaw can be set to pass through. In this mode the gyro is no longer in rate mode, but rather in un-commanded mode. Gyro action can be inverted as required · PC tool read back all parameter from Gyro function · Some bug fixes, changes to default aircraft and PC tool, and internal filter improvements. · Updated user manual (now called Advanced User Manual) |
Please see here for help and support on this product:
https://www.rcgroups.com/forums/show...722138&page=36 |
Latest blog entry: BL-3G Independent review
Is the BL-IM10RC available yet? One place on your website it states 2nd quarter of 2014 another place - 3rd quarter. Is there a 'guesstimate' on a release date and just a 'ballpark' figure on cost? I suspect it will be less than the Ice Man ...eh¿ I'm so funny.
Reason: add an eh
Thread Tools | |
Similar Threads | |||||
Discussion | BL-3GRC Amazing new Gyro / Controller with Delta and V-tail support | IceManPro | Flying Wings | 1 | Mar 22, 2015 02:26 PM |
New Product | BL-3GRC Gyro | IceManPro | Product Announcements | 5 | Feb 16, 2015 07:54 PM |
Discussion | BL-3GRC Amazing new Gyro / Controller for airplane and multi-copter | IceManPro | Beginner Training Area (Aircraft-Electric) | 0 | Sep 27, 2012 01:49 AM |
Discussion | BL-3GRC Gyro for multi-copter and airplane | IceManPro | Multirotor Drone Electronics | 0 | Sep 03, 2012 06:48 AM |
