Mar 09, 2013, 09:04 PM
Question
How big of a battery do you need for servos
How large of a battery do you need for futaba S9402 and S9001 servos? I want to use lipo or life battery. Futaba says both of these servos can draw alot of amps, but they dont say how many. Thanks Mike
Mar 09, 2013, 10:09 PM
characters welcome!
Mark Wood's Avatar
How many servos, how big are the control surfaces they will control, how many flights do you want to get out of the battery, etc. You get the idea.
mw
Mar 10, 2013, 12:09 PM
Is there a calculation table or something like that ? This is in my 1/3 scale Pitts 50cc. There are 4,S9001s in the wing, 2, S9001s on the elevator, and 1, S9001 on the throttle. 1, S9402 on the rudder.
Mar 10, 2013, 01:01 PM
Bear in mind also that servo (and battery) plugs have a limit to how many amps they will carry. Most people with 50cc planes us a second rx battery, i use a li po battery and a regulator that has two outlets so i can power the rx with two seperate plugs (and on/off switches)
If you are using a life or lipo battery through a regulator i would imagine you will have plenty of power for high draw servos.
Mar 10, 2013, 01:12 PM
characters welcome!
Mark Wood's Avatar
Might wanna poke around the Giant Planes forum too.
https://www.rcgroups.com/giant-electric-planes-477/
mw
Mar 11, 2013, 04:49 PM
Go Hawks!
cryhavoc38's Avatar
Those servo's aren't very powerfull.
What sort of flying do you plan to do with your 33% Pitts?
Mar 12, 2013, 10:04 PM
Just sport flying. For now.
Mar 13, 2013, 12:56 PM
Go Hawks!
cryhavoc38's Avatar
ok
BUT, if those servo's are new and you can return them or retask them, I'd suggest some servo's that are in the 200+ oz torque range for the ailerons and in the 300+ range for the elevators and rudder.
Thats if you plan to go all crazy 3d with it eventually.
Mar 15, 2013, 08:29 PM
Thanks for all the good advice and info guys !!!!
What servos do I need for my escapade PilotPatrick Aircraft - Fuel - Airplanes (FS/W) 1 Feb 19, 2013 12:35 AM
Discussion See how the big boys do it Prins Willem Dock Talk 3 Feb 02, 2013 10:11 AM
Discussion Do you need separate battery for your LED lights?! DYORD Multirotor Drone Talk 8 Jan 15, 2013 09:29 AM
Question How big of battery do you need for 46 glow plane? rlfgary Fuel Plane Talk 36 Apr 06, 2012 08:45 AM
Discussion How big a UBEC do I need to run 6 servos in an E-Flite Ultra Stick? Treker-1701 Power Systems 6 Mar 01, 2007 11:55 AM
