This thread is privately moderated by garyholland, who may elect to delete unwanted replies.
Mar 08, 2013, 04:28 AM
Foam alone.
garyholland's Avatar
Blejzyk Tom
My good friend Rob at Flying-Dog asked me if I would build one of these to display at this years EIM. A little more work than the usual mouldies I'm used to, but shouldn't present a problem to anyone with a modicum of building skills. The wings are nicely finished and the fuselage is exquisitely moulded and everything fitted together very well.
Because I planned to fit a reasonably high power set-up, I did elect to remake some of the components supplied. Namely the tailplane, which I thought a little flimsy.
As soon as I've got the time to finish it, I'll include a flight report and video.
Video is now here:
Blejzyk Tom (3 min 45 sec)
May 06, 2013, 02:59 AM
Soaring Fanatic!
8thelephant's Avatar
Great Photos
What power setup are you using?
Sep 02, 2013, 02:29 PM
Foam alone.
This one: https://www.hobbyking.com/hobbyking/s...dProduct=32819
Sep 27, 2013, 08:02 AM
What propeller do you have in the model?
Oct 17, 2013, 09:37 AM
Foam alone.
10x7" Aeronaut Carbon folder
Oct 26, 2013, 05:15 PM
Soaring Fanatic!
Thanks so much Gary, this info really helps a lot :-)
Nov 05, 2013, 01:40 AM
Soaring Fanatic!
Oops, one more question... Did you apply any thrust angle to the firewall/nose ring?
Nov 05, 2013, 06:07 AM
Originally Posted by garyholland View Post
10x7" aeronaut carbon folder
3s, 4s? What battery capacity?
Are you using the flaps for landing?
Thank you in advance for your reply.
Nov 11, 2013, 03:20 AM
Foam alone.
No, just made gap between the end of the fuz and the motor ring constant. Don't know if Artur has included any side or down angle into the nose cut, or whether I just got lucky, but seems to fly pretty straight.
Nov 11, 2013, 03:25 AM
Foam alone.
I'm using an old 4s 2500 FlightPower Evo light. Would probably go a bit better with a nice new Gens Ace pack
No flaps for landing.
Mar 31, 2016, 11:28 AM
Very helpful info... I'm also building Tom now
Do you remember any numbers (ie. CG, dihedral et c.) ?
Build Log Hammer 2.4 - by Blejzyk from Aloft Hobbies macinr Slope 114 Jan 31, 2018 08:03 PM
Question Blejzyk Fox 2.2mtr, 198! Rosscopk Slope 7 Feb 04, 2013 01:31 PM
New Product blejzyk Tom 1.5 and 1.7m Stuntman High Performance 5 Nov 18, 2009 08:49 AM
