Jan 01, 2004, 08:38 PM
Free Palm Size Heli Plans
Free MIA Palm Size Drawing Template. The template can be printed to any scale by sizing in your printer program or bringing it into a GIF viewer program and scaling to what ever size you want.
The plans are Copyrighted, which means it can not be duplicated, reproduced, modified, reposted or sold without my approval. You are free to make as many copies for yourself and friends only.
Note the original scale provides an 8.5" rotor, this was done to allow anyone to make this helicopter and work from this size down, if desired, remember that the smaller it gets the more challenging it will be to work with small parts like the rotor bearing and hook.
The plan is adaptable to other means of propulsion, using ultra micro electronics and power systems. Start with Rubber first then you can experiment further with IR or RC equipment.
The drawing is straight forward but I will detail its assembly with additional photos.
Materials:
1) Paper: You can use regular 20# printing 8.5"x11" white sheets
but lighter will work better for models under 8" rotor diameter.
2) 1mm Carbon rod cut to lengths shown on drawing
3) small pieces of 0.020 plastic or fiberglass, or carbon for the
rotor bearing support plate, the triagular brace and the main blade tip weight (shaped like the end tips)
4) Brass tubing 1/16" OD x 1/32" ID
5) Brass 2mm bead
6) 1/32" OD piano wire for the hook
7) Small Diameter 1/8" OD light tubing (coffe stirrers) for skids
8) Rubber band material (these comes in all shapes and sizes, the best one I have used is called Micro High Torque (25) grey rubber or sometimes called contest rubber. It is 1mm wide. There are other alternatives also.
Adhesives and Tools:
Small bottle of CA glue and Accelerator Spray, 5 minute Epoxie
Scissors
Exacto Hobby Knife
Ruler
Small Neddle Nose Pliers
Button Thread
1" OD Pipe
Small plastic bags
Mario I. Arguello
www.micro-flight.com
Jan 01, 2004, 09:14 PM
The model ready for flight.
Jan 02, 2004, 12:43 AM
Foam rules
Thatovalguy's Avatar
If no one else is going to step up and say this, I will.
I can't believe it, free and all, just like you said. Few days late.
Cute little heli Mario.
Jan 02, 2004, 01:57 AM
Very cool
Can't wait to start building, just need a few more instructions.
Thanks Mario
Jan 02, 2004, 03:37 AM
Canopy Assembly
Just follow the Key in the attached drawing.
Red Line: Cuting
Blue Line: Folding
Grey Area: Glue
Yellow Area: Flap over Glue
Jan 02, 2004, 03:40 AM
Mario, thanks for the awsome plans i'll be making that heli in the morning.
I'll try putting micro motorbike RX in and what would you suggest for a main motor? just a 6mm pagermotor? I have a 145mah lipo is that too big?
Tim.
Jan 02, 2004, 04:31 AM
Guys,
I appreciate it, I will explain later on which motors you can use and how to make a simple control system for it if you want to experiment with IR or RC control.
Let me just finish uploading some more instructions for it for Rubber Power first, since it is the mosts simplest form.
Attached is a better Blade Pattern. It has "tip weight and root reinforcement" details.
Mario
Jan 02, 2004, 04:56 AM
Suggested Construction Sequence:
Canopy
Blades
Tail/Boom
Main Frame
Landing Gear
Motor
Jan 02, 2004, 05:00 AM
canopy2
Jan 02, 2004, 05:02 AM
Ah instructions,
that will always make life easyer
tim.
Jan 02, 2004, 05:09 AM
canopy3
canopy4
Jan 02, 2004, 05:10 AM
canopy5
Jan 02, 2004, 05:11 AM
canopy6
canopy7
~~~ Free Palm-size Heli Plans ~~~ Mario Scratchbuilt Indoor and Micro Models 9 Dec 04, 2003 04:05 PM
