May 09, 2014, 01:10 PM
The Mad and the Wicked
4bladeflyingfish's Avatar
True, Sorry
Originally Posted by WAM74
What the hell are you guys talking about? The subject was number of thread pages on RCG quadcopter threads.
May 09, 2014, 01:27 PM
Wandering IT geek
ronin4740's Avatar
Originally Posted by Raider1284
If I remeber correctly those are just "nylon m3 spacers" which you can usually find in almost all hardware stores. Or here on hobbyking: http://hobbyking.com/hobbyking/store...arehouse_.html
They wont have the nice feet that Chris' have though.
Well, none of the local hardware stores have nylon threaded spacers in metric nor does the local screw and bolt suppliers.
Guess I'm grounded until the order from Chris shows up... Back to fixed wing for a week or so
May 09, 2014, 01:35 PM
You could get imperial nylon spacers and just get some imperial bolts for them for the time being.
May 09, 2014, 02:39 PM
Mcmaster.com will get it to you overnite. Or maybe second day. Look around the website for lots of choices. Stick "threaded spacer" in their search box.
Here's a plastic hex 4-40 spacer 1.25" long. 92319A286
Here's some aluminum hex 3mm x 37 that might make good legs. 92319A286
May 09, 2014, 03:21 PM
ttabbal's Avatar
Still trying to see what these connector are called and hopefully a place to buy more of them. The white 4-8pin connectors in this picture
Molex is a brand/manufacturer. Unfortunately, it's name is used for various connector types.
The picture, without a size reference, is a bit hard to tell for sure, but they look like JST-XH plugs. Commonly used for balance plugs on LiPos.
I probably missed the first post you made on this, what are you trying to plug into, and which side of the connector do you need?
Oh, and what pin count?
May 09, 2014, 03:30 PM
These will work 30mm long aluminum with M3 thread on both ends so you can still use the stock plastic feet.
http://www.rc-drones.com/Phoenix-Fli...ar-_p_477.html
Or these they're the same but 60mm long
http://www.rc-drones.com/Phoenix-Fli...ear_p_478.html
May 09, 2014, 03:48 PM
Board is toasted.
Originally Posted by bobepine
Put in in the oven on high heat for 40 minutes. Remove plastic bits from the headers first.
Best,
Chris
Well Chris, I put it in the oven not even at max temp because I was afraid, well, she is cooked, the solder started to melt, it was a diaster, and this is less than 30mins.
May 09, 2014, 03:56 PM
Best,
Chris
Here she is
May 09, 2014, 04:56 PM
Let try this!
Yazz's Avatar
Originally Posted by dynam
Here she is
That looks well done, try loading it again now.
May 09, 2014, 05:03 PM
Dreamer
Ummm, no. DJI Phantom 1700 pages, Flame Wheel over 1000. But Armattan is still very high in the rankings.
Difference is that those are 1700 and 1000 pages of complaints ... lol
May 09, 2014, 05:10 PM
Dreamer
ya? Because 4 pin molex connectors are what you use to plug in devices into your desktop computer.
This is a "4 pin molex connector"
They share the exact same name? Performing a search for molex on RMRC doesnt look to be returning the right results: http://www.readymaderc.com/store/ind...=molex&x=0&y=0
Try this link.
From your pic, they are also known as micro JST and they come in different pin spacing and pin size and pin number. A lot of video transmitters and fpv cameras use this type and its as simple as lift the little tab and swap the wires around in the plug to get the color sequence right if need be. http://www.ebay.com.au/itm/251223133...84.m1439.l2649
http://www.ebay.com.au/itm/230922778...84.m1439.l2649
May 09, 2014, 05:26 PM
Let try this!
Yazz's Avatar
Where can i get a mix bag of various metric black nylon standoffs, spacers and nuts used in my Armattans? I need to stock up on this stuff!
May 09, 2014, 05:53 PM
black nylon is pretty rare, looks like ebay may be your best bet? http://www.ebay.com/itm/M3-Nylon-Bla...-/371049036339
You can also buy parts from Chris directly from here: http://www.armattanquads.com/parts-&-accessories
May 09, 2014, 06:02 PM
... Always Learning
eBoon's Avatar
I got that kit of spacers from eBay..work great
May 09, 2014, 09:44 PM
Team Armattan
Rob2160's Avatar
A small mod to my CNC258, Using all black props now so I need something to help with orientation at a distance.
Improving orientation with my Quad (1 min 13 sec)
Sold FS: Armattan 355 Package $250 initials Aircraft - Electric - Multirotor (FS/W) 0 Jan 12, 2013 06:21 PM
Sold Armattan M355 RTF Creepy1 Aircraft - Electric - Multirotor (FS/W) 1 Jan 09, 2013 01:54 PM
Sold New flight tested CNC Armattan 355 littlepiston Aircraft - Electric - Multirotor (FS/W) 2 Jan 06, 2013 08:52 PM
Sold Armattan M500 Custom Build Bryan's Flyin Aircraft - Electric - Multirotor (FS/W) 5 Jan 06, 2013 07:55 PM
Sold Armattan V3 CNC 355 RXR (The first one!) bobepine Aircraft - Electric - Multirotor (FS/W) 4 Jan 05, 2013 03:48 PM
