Skywalker X8 FPV - RC Groups
This thread is privately moderated by smoothvirus, who may elect to delete unwanted replies.
Feb 26, 2013, 01:43 PM
smoothvirus's Avatar
Build Log
Skywalker X8 FPV
I fell in love with this plane almost a year ago. Since then I have slowly been acquiring the pieces needed to put this project together. As I build her I'll update this thread.
Parts List:
Skywalker X8 airframe
http://www.hobbyking.com/mobile/view...dparentcat=437
Turnigy G32
http://www.hobbyking.com/hobbyking/s...er_770kv_.html
Aeronaut CAM Folding Prop 12x6.5
http://www.espritmodel.com/aeronaut-...denthaler.aspx
Turnigy 65A ESC
http://www.hobbyking.com/hobbyking/s...dProduct=35675
5.8ghz 600mw video transmitter
http://www.futurehobbies.com/details...smitter-5-8ghz
Blue Beam antenna set
http://www.futurehobbies.com/details...blue-beam-whip
custom decals
http://www.signspecialist.com/lettering/lettering.html
EzUHF
http://www.readymaderc.com/store/ind...roducts_id=927
2 x Hitec HS-322 HD Servos
http://www.servocity.com/html/hs-322...rd_deluxe.html
Design Master Colortool #714
http://www.dmcolor.com/products/
Minwax Polycrylic
http://www.minwax.com/wood-products/...tective-finish
RVOSD5
http://www.rangevideo.com/index.php/...n-display.html
RVOSD Airspeed Kit
http://www.rangevideo.com/index.php/...speed-kit.html
Dubro 2-56 Mini Nylon Steel Pushrod (pair)
http://www3.towerhobbies.com/cgi-bin...?&I=LXD855&P=6
Dubro Control Horns Nylon 1/2A (2)
http://www3.towerhobbies.com/cgi-bin...?&I=LXD934&P=0
SONY Super HAD CCD II 600TVL D-WDR DNR Mini Board Camera
http://www.securitycamera2000.com/pr...a-DIY-FPV.html
Ground Station:
Fatshark Dominators
http://www.hobbyking.com/hobbyking/s...dProduct=19445
Fatshark 5.8ghz receiver
http://www.futurehobbies.com/details...eceiver-module
5.8 Ghz Uno receiver
http://www.readymaderc.com/store/ind...roducts_id=877
5.8 GHz HELIAXIAL58 (5645-5945 MHz) RCHP 12dBic Helical Antenna
http://www.readymaderc.com/store/ind...oducts_id=1026
RVOSD Antenna Tracker
http://www.rangevideo.com/index.php/...a-tracker.html
References:
List of power setups for Skywalker X8:
http://stefan.gofferje.net/projects/.../x8-setup-list
Skywalker X8 assembly manual:
http://www.raygrauberger.com/DOWNLOA...X8Assembly.pdf
Openpilot build log for X8:
http://wiki.openpilot.org/display/Doc/X8+Flying+Wing
Another build log, with RVOSD5 and the pitot tube:
http://fpvworkshop.wordpress.com/2012/10/30/x8-build/
X8 Review from Flite Test
http://flitetest.com/articles/skywalker-x-8
SUAS News article on X8:
http://www.suasnews.com/2012/12/2032...-game-changer/
Jul 14, 2013, 10:32 PM
Most people are stupid!
dambit's Avatar
I Just got mine today. I'm painting mine RLM 76 on top and RLM 75 on the bottom. EPO is great to paint as it doesn't really react to much. Most general spray paints are fine, but to be sure do a test patch somewhere. My paint happens to be in tins, so I'm just using a sponge brush out of convenience.
Jul 23, 2013, 09:04 AM
Well, after spending the past few months building my FPV quad and having a blast with it, I am back into this project again. I have been trying to paint it for the past few weeks but have been having issues because I paint in my backyard and we are having a very wet summer. It pretty much rains every single day, typically in the evenings right when I get home from work.
That said the fuselage is about completely painted and I should be able to start on the wings soon. I am using Design Master Colortool #714, Holiday Red, to paint the X8. It's perfectly safe for use on EPO. I also found that the Tamiya TS-8 Italian Red was safe to use as well, but it's expensive, the Design Master is much cheaper. The paint came from the local Michael's craft store.
After painting I am sealing everything with Minwax Polycrylic, in the spray bottle. It's water based and safe for the foam. I grabbed that from Wal-Mart.
I'm still planning on using 5.8ghz for the FPV and will probably use 2.4 Spektrum for the initial flights. I have an EzUHF transmitter/reciever on order but RMRC doesn't know when that will be in.
One thing I'll probably do is reinforce the wings with carbon fiber strips, as detailed in this post from the X8 thread:
https://www.rcgroups.com/forums/show...postcount=1146
Carbon fiber strips available from here:
http://www.hobbyking.com/hobbyking/s...dproduct=15387
and here:
http://www.ebay.com/itm/Midwest-Carb...#ht_1844wt_834
I read this post over on FPVLAB which got me thinking:
http://fpvlab.com/forums/showthread....l=1#post282729
4.8 miles is more than enough range for the kinds of things I'd like to do. I found that the antenna tracker for my OSD, the RVGS was in stock so I pulled the trigger on one. I have yet to get the Uno reciever, pan & tilt, or helical antenna yet though.
Jul 24, 2013, 11:43 AM
My build log and notes for the X8 would not be complete without this link:
Jul 29, 2013, 09:59 AM
Just stumbled across a nice assembly manual for the X8, this is going to save me a lot of time!
Aug 16, 2013, 08:18 AM
Got the connectors for the motor and ESC all soldered up. Of course, the very next day the Hakko soldering station I ordered shows up.
Aug 24, 2013, 08:13 PM
Airframe is pretty much done. On to installing the electronics.
Feb 17, 2015, 09:27 AM
X8 Skywalker - lost canopy, then receiver then crash
Hi
Sadly I lost my last X8 Skwalker, well when I say lost I smashed it too bits after many flying hours.
I was flying at full speed and level, the canopy flew off, and then it pulled the receiver out and I therefore had no control.
Next time I will secure this better, any suggestion ?
Also any thoughts on replacements canopys and how to reproduce as have lost 2 now.
Apr 23, 2015, 08:56 AM
Originally Posted by M277HEW
Hi
I'm worried about this myself. I added a hatch latch to my canopy to try and hold it down but I wonder if even that is enough.
Of course, the simplest answer is to just tape it down, that ought to work just fine.
However I'm considering adding a couple of nylon bolts to hold it down. That ought to keep it very secure.
May 26, 2015, 10:05 AM
After spending over two years sitting in the hangar collecting dust the X8 is going to have a maiden flight this season. I'm working on the final electronics install now. I put my RVOSD 5 in place last night.
The plan is to maiden it at the Pecan Patch FPV Fly-In in Griffin GA in a week and a half.
Jun 03, 2015, 09:38 AM
I am rushing to finish the build before Pecan Patch tomorrow. Stayed up late last night, it's mostly complete aside from some wiring, programming the RVOSD, and binding the EzUHF receiver.
Jun 09, 2015, 05:43 PM
I attempted a maiden today and it did not go well. I tried to launch with the RVOSD stabilization turned on but things quickly went wrong when it pulled up sharply, stalled, went inverted and into the ground before I could save it.
It's probably repairable but I don't know if I want to bother. The RVOSD is only transmitting a blank screen now, so it's broken.
I'm not sure if I want to continue this project. The X8 turned out to be more trouble than it's worth.
Discussion Skywalker X8 catapult brettbb Flying Wings 575 Aug 07, 2017 12:07 AM
Discussion Best FPV Platform : Skywalker V5 vs Skywalker X8 Wing asaak FPV Talk 15 Oct 22, 2016 02:19 AM
For Sale 20 unit Skywalker x8 and 12 unit Skywalker 1680 shipped in 12hours delivery RC4YFPV FPV Equipment (FS/W) 11 Feb 04, 2013 07:34 PM
Poll Skywalker X5. Or X8 BladeRex Flying Wings 3 Jan 22, 2013 11:04 PM
Sold NIB Skywalker X8 and FPV gear flashted FPV Equipment (FS/W) 0 Nov 18, 2012 01:42 PM
