Mar 04, 2013, 02:39 AM
Vladimir
tkach's Avatar
Thank you very much for your quick and good response, Marcel!
Many thanks to all!
Try to repeat this project, but a bit smaller. Probable-800 mm wingspan. Perfectly attuned size for transportation in a car ...
Mar 04, 2013, 04:01 AM
Vladimir
tkach's Avatar
Joe, hey!
You do not have a drawing of wing?
Or send profile number in the catalog of NASA.
Thank you, Vladimir.
Mar 04, 2013, 02:40 PM
Vladimir
tkach's Avatar
Hi! Sorry, but I can not understand how the wing is made of the model.
If it is made of a single layer of foam thickness of 6 mm, a carbon rod is inserted, the same having a diameter of 6 mm? I do not understand something, or use two layers of foam? But the gap in the fuselage for the wing the same size is 6 mm. And can you do km2 wing?
Really need your advice and a more detailed explanation. It is better to draw a ...
PS Do you think that if I reduce the scale of the model under the wing span of 900 mm, this will greatly affect the performance letnue model.
Yours sincerely, Vladimir.
Mar 04, 2013, 02:57 PM
Ken's CAD Models
dz1sfb's Avatar
Vladimir,
I have probably caused some confusion by showing my model of Marcel's design with the KFm2 wing. attached is the picture of the cut file for my version of this project showing the layout of parts for cnc operation on 2 sheets of foam.
Ken
Mar 04, 2013, 04:36 PM
Vleisie I am coming up with a fair amount of dihedral in the wings. How much should there be for a wing tip from a horizonal plane?
Mar 04, 2013, 07:47 PM
Retired CAD guy
birdofplay's Avatar
There are wing braces in the parts.
They should SET the dihedral.
With the BLOW going over the tail there shouldn't be much need for a lot of Dihedral.
The Bracing is very slight, maybe 3 deg tops.
Mar 04, 2013, 08:40 PM
Ken's CAD Models
dz1sfb's Avatar
Bob,
Your right. I have mine set to 5 degrees and knew that was more than Marcels plans. Just went and measured his at 2.5 degrees.
Ken
Mar 04, 2013, 08:49 PM
I tried to be careful with cuts on the wing braces and motor mounts. It doesn't take much of a bad cut or a bad glue up to make a couple of degrees difference. I fought the motor angle on the Mako a good while before I got it right by test flying. Drongo right on from the start.
What is the angle on the motor for the Mermaid where I can check.
Mar 05, 2013, 01:00 AM
boerie roll
vleisie's Avatar
Hi Vladimir,
The original plans are for a wing made from a single layer of foam with a 6mm diameter carbon tube wing spar. Put the tube in the slot and glue with epoxy to fill up the gaps between the tube and the foam.
I think the performance will still be acceptable with a 900mm wing.
The dihedral angle is 3, accuracy is not critical.
Motor angle is 5.
All the best
Marcel
Mar 05, 2013, 06:37 AM
Build, Fly, Rebuild!!
Ghost who walks's Avatar
Originally Posted by Lockey
Looks great Marcel
Another Aussie sea plane nut cant wait to see your flight video Marcel Hi Aus . Hi Ghost and thanks for sending me the link Joe
Lockey
Hi Lockey how are you? have you started to build this one yet?
Ghost
Mar 05, 2013, 07:35 AM
Thank you for the response Marcel. Your planes are great.
Mar 05, 2013, 07:48 AM
Vladimir
tkach's Avatar
Hi, Ken! Hi, Marcel!
Thanks for the detailed answers. A special thank you for the drawing.
Most likely I will do my profile KFm2, as in the drawing.
Thank you again! Vladimir.
Mar 05, 2013, 08:08 AM
SONICX's Avatar
Baie mooi vliegtuig ontwerp vleisie, hou van jou ander ontwerpe ook veral die F1.
Hou so voort en hou SA se naam hoog.
Mar 05, 2013, 08:41 AM
boerie roll
vleisie's Avatar
Dankie man
Mar 05, 2013, 09:57 AM
Ken's CAD Models
dz1sfb's Avatar
Got started
Got my kit cut last night. Brrrr! it was cold in the garage.
Anyway, jumped on it this morning. Here's the progress so far.
Ken
Build Log DRONGO: Depron pusher water plane/park flyer *PLANS* vleisie Foamies (Scratchbuilt) 582 Oct 06, 2018 02:30 PM
Build Log F-22 Depron Detailed Build, Plans and Video. Super easy F22 restie Foamies (Scratchbuilt) 409 Nov 29, 2017 08:13 PM
Disassembled Raptor 50 v2 for Electric Park Flyer Planes kirt7183 Non R/C Items (FS/W) 7 Jan 24, 2013 03:53 PM
Sold NIP - MX DSM2 Compatible 6ch Microlite Park Flyer Receivers modestmagi Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2013 10:57 AM
