May 04, 2017, 04:07 PM
DF95, DF65, & Victoria Skipper
gards's Avatar
When I ordered the v6 package it came with a new and different switch. The original switch was not enclosed in a case but open underneath with the board showing and just silicon covering the contacts. The new switch (v6) is in a case and is more robust. Now I still but corrosion x on it and then put liquid tape around the bottom but it is a much more substantial switch than prevously.
May 04, 2017, 08:24 PM
DF65/No Excuses, Just Sailing!
Windward RC's Avatar
DF65 Version 5 PNP Clearance Sale!!
Need to get rid of the last few white version 5 DF65s we have in stock!
Now available at $99.95 USD / Plug and Play ( no radio) / limited quantity
https://radiosailing.net/products/dr...ss-rc-sailboat
May 05, 2017, 02:34 AM
Fantastic value - there is no perfomance difference at all between the V5 and V6 - indeed at our club the V5s are stronger than the V6 - shame you are not in the UK and that we have all those horrid import tarrifs and taxes
May 06, 2017, 07:05 AM
Steve Landeau IOM USA 21
There are now 4 less in stock... going to Savannah!
May 08, 2017, 01:13 AM
v6 Airshipment arrives tomorrow USA
I know some of you have been looking for the new v6 DF65, we've had an overwhelming response for the Version 6 DragonForce 65 since it came out in February. We sold our original 300 in 2 months. we have 50 coming in via air , and another 300 by ocean ship in about 3 weeks.
Thank you for your support of the DF65 both here in the USA and of course worldwide... there is a reason this is the most popular boat in the world... its the people who sail it, and love the boat!
May 10, 2017, 05:39 PM
DragonSailing NA's Avatar
DF 65 Apparel now available!
We have partnered with the Pirates Lair sailing gear outfitter to bring you some great item for your DragonForce!
Check out the soon to be expanded collection at: https://radiosailing.net/collections...el-merchandise
May 13, 2017, 07:36 PM
Murray C's Avatar
Vang Bolts
Does anyone know the size bolts and nuts for the vang fitting on the DF65. Imperial or Metric?
Seems loctite is not good enough to secure these threads, so need to replace a missing nut or two.
May 14, 2017, 01:14 AM
Bolt M2 x 8mm
Nut M2
If you have to source some more maybe go to a bolt that is M2 x 10 to give a bit more thread out side of nut to add some locking fluid.
May 14, 2017, 07:19 AM
I'd suggest doing a double check of exactly what you've got.
I have some original Mk 1 vang fittings, one Mk 5 and some of the lovely new Mk 6's.
I've just checked and all of my fittings use a metric, M3 thread.
The old plastic Mk 1's are so tight they don't need a lock nut!
The Mk 5 definitely needs a lock nut but are very fiddly to use. If you could get hold of some of the Mk 6 style knurled thumb screws I think that'd make the Mk 5 version much easier to use.
I have to say the new Mk 6 vang fitting is absolutely superb. It's so easy to adjust, either for very fine tuning or longer travel, and lock very simply and securely.
Cheers
Phil
May 14, 2017, 07:30 PM
Murray C's Avatar
Thanks tugboat and Phil,
Boat is V5. Looks like it is M2.
A spot of CA on the end of the bolt sufficed as a temp fix but will have to source some spares.
Cheers,
Murray
May 15, 2017, 05:38 AM
Sorry Murray and Tugboat
My mistake, I was thinking about the other threaded parts. Those nuts and bolts, as Tugboat quite correctly pointed out, are M2
Phil
May 20, 2017, 01:24 AM
"consumerwil"
denisoni1's Avatar
Swag!!
I got some swag!!
New Swag - Dragon Force 65 and Dragon Flite 95 shirts!! (3 min 35 sec)
May 20, 2017, 05:57 AM
Originally Posted by tugboat2011
Bolt M2 x 8mm
Nut M2
Check McMaster-Carr, they have them.
Sold Dragon OSD V2 and Dragon Commander Bryan's Flyin FPV Equipment (FS/W) 10 Feb 19, 2013 07:36 PM
For Sale .28 Ofna Force in near new,not broken in with extras redlined_b16a Cars - Trucks and Parts (FS/W) 1 Jan 18, 2013 10:16 AM
Discussion How long does it take to train a military force ? radix2 Life, The Universe, and Politics 25 Jan 16, 2013 09:05 PM
Sold Seawind AMYA Class Yacht!!! $400 OBO PingChandlerPong Boats (FS/W) 0 Jan 03, 2013 06:18 PM
Sold ***SOLD***Turnigy 100A K-Force with 2 in 1 box gregory.da Aircraft - Electric - Power Systems (FS/W) 1 Jan 02, 2013 12:22 AM
