Thread Tools |
This thread is privately moderated by ohsnap, who may elect to delete unwanted replies. |
Blade 130x Mods
Here are the upgrades to my 130x. Great little heli out of the box however does require some much needed attention on certain components to improve overall flight performance. The major area for improvement was the tail, specifically the tail pitch slider which has a tremendous amount of slop and prone to breaking off the pin in normal flight. I found the stock inrunner a bit underpowered, ran quite hot and pretty inefficient compared to most outrunners.
Anyways here are the modifications otherwise upgrades. I will note I'm not a fan of "bling", can't stand it actually. With that said, all mods competed were for function not fashion. Motor: HP08S 8000kv w/ 10t pinion - lighter, way more power over stock, efficient and pretty hard to bog. Doesn't come down hot and can run packs back to back without the sag. Using stock esc running 90% flat TC. Swapped stock motor/esc connectors with micro 3-pin oversky and mini jst. Head: Lynx Ultra Dampeners - POM bushing and elastomer combo. Really improved cyclic response. Also swapped stock rubber o-rings with silicone o-rings on swash and main grip ball links. This mod alone will remove all the slop on the swash resulting in the loss of those annoying head shakes in FFF with higher head speeds. Tail: DS35 servo, 4G6 tail pitch lever, Lynx tail case, pitch slider and CF TT, straight CF tail rod - Used the MH DS35 mount with a 4G6 pitch lever and relocated the tail control rod to the top of the boom. Used 1mm CF for the tail rod with the stock ball links and flipped the pushrod support guide to the top. Also extended the stock tail support rods to 118mm using 2mm sold CF. Lynx CF TT is awesome, big improvement losing the resonating over the stock metal TT. The tail upgrades have been the best improvement by far and now have a twitch/wag free tail. Ended up reducing the tail gain down 4 from the stock setting. Bearings: Bocas on main/tail grips, mainshaft, and tt. Stock bearings are quite sloppy especially the ones in the tail grips resulting in a lot of lateral slop on the tail grips. Blades: Stock bullets and Lynx tails - Have tried a number of different mains and keep going back to the stock bullets, they are the best at higher head speeds hands down. Lynx tails are amazing, better then the KBDDs and dont require you to sand down the root which is a plus. Wiring: Moved all servo and motor wiring to the left outer frame. This allows for easy access to the frame and internals for maintenance. |
Update:
Lynx CF torque tube rod broke shortly after the second flight. Splintered and broke right at the root of the B gear. Ended up blowing out the front tt bearing during the process. Tried the second tt rod and same results. CF is too weak to handle the torque so best to save your money and stick with the stock metal tt rod. |
Thread Tools | |
Similar Threads | |||||
Discussion | Blade 130X Tail Grip Flip Mod. | t-rexn8 | Micro Helis | 3 | Apr 08, 2013 01:57 PM |
Discussion | HK-250 With Trex 250SE Electronics, is it possible to trade for a Blade 130x? | BladeScraper | Micro Helis | 5 | Jan 07, 2013 04:29 PM |
Sold | Blade 130X w upgrades, new canopy, & lipos | Bill2005 | Aircraft - Electric - Helis (FS/W) | 4 | Jan 03, 2013 12:27 PM |
Discussion | Blade 130x or Align Trex 450 Pro | BladeScraper | Micro Helis | 4 | Jan 02, 2013 11:13 AM |
Discussion | Blade 130x mod? | Wanaero | Micro Helis | 0 | Jul 20, 2012 04:37 PM |
