This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Feb 21, 2013, 05:01 AM
Jack Crossfire's Avatar
Optical flow notes
So the next vehicle needs to use optical flow + sonar & the last board needs to be scrapped. The PX4FLOW module would be the best solution, but it's probably too heavy, necessitating a new board with smaller camera, motor control, IMU, & radio.
There are some optical flow algorithms on
https://github.com/ArduEye/ArduEyeLi...rduEye_OFO.cpp
They're algorithms from 1984 intended for movement of 1 pixel. The wisdom of the time said your best bet is to scan every pixel in the image for movement of 1 pixel so any ideas about logarithmic macroblock searches, blob detection, or edge detection probably won't work.
PX4FLOW says it scans a binned 188x120 image at 250hz. The algorithm in the PX4FLOW is described in
https://pixhawk.ethz.ch/px4/_media/m...flow_paper.pdf
It's assembly language intensive. Their camera supports greyscale, allowing the fastest DMA capture.
It does basic, exhaustive absolute difference comparisons of 8x8 macroblocks in a search radius of 4 pixels. It scans 64 8x8 macroblocks, so only 1/5 of the entire image is scanned, but the scanned regions are at high enough resolutions to resolve textures.
Instead of averaging all 64 motion vectors, it takes the most frequently occurring vector. Then it does a subpixel absolute difference comparison using the closest macroblock to the final result to get subpixel motion.
The trick is using a gyro to cancel out picture movement from banking & turning, yielding only movement from horizontal motion.
The PX4Flow source code would be nice, especially for the assembly language routines. Using the smaller, easily obtained TCM8230, the nearest resolution drops to 160x120, but it needs software to output greyscale & it can't go higher than some 70fps.
Sold Old School Flow Through Muffler Generic Member Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 06, 2013 09:35 PM
For Sale Multicopter Extras: Optical Flow, Magnetometer, KK Multicopter, AND MORE! Ecibob Aircraft - Electric - Multirotor (FS/W) 2 Nov 29, 2012 03:47 PM
Cool Optical Flow Stabilization + GPS stabilization = stay put quadcopter, Arducopter daign Multirotor Drone Talk 5 Jan 26, 2012 12:53 PM
Discussion 3D Optical Flow Motion Tracking of Aerial Video Photoship One Aerial Photography 3 Dec 26, 2009 10:50 AM
DIY Optic Flow Sensor for autolanding (using a cheap Optical Mouse) Bg~ DIY Electronics 3 Oct 01, 2005 06:27 PM
