Oct 13, 2019, 10:05 AM
R_G
R_G
UFO Driver
R_G's Avatar
Originally Posted by doxilia
On that note, I couldn't help myself and had to dig up Ralph's OP quote:
After dealing with the complexity of my UFO Build I feel the need to build something simple. By simple I mean your basic 4-channel airplane with no paint, no pipe and no retracts.
A simple classic that should go together relatively quickly i.e....less than three years!
I was wondering when someone was going to bring that up!
Like fine wine, it takes time!
Ralph
Oct 13, 2019, 10:13 AM
R_G
R_G
UFO Driver
R_G's Avatar
I might be going a bit overboard with the tri-stock! But back in the day I flew a few SF's & VF's in helis and they proved to be shakers that would actually cause aluminum main frames to crack. Since the Super Kaos doesn't have plywood fuselage doublers I decided a few extra pieces of tri-stock would help to stiffen things up a bit!
Ralph
Oct 13, 2019, 10:44 AM
jpurcha's Avatar
Nothing like an old fashion build. Plenty of tri-stock. Not these light plywood, fall apart on first hard landing builds.
Latest blog entry: MAAC Wings
Oct 13, 2019, 11:35 AM
AMA 32832 - SPA L27-VRCS 1138
Dave Swanson's Avatar
Very nice work!!! I have one of these kits stashed away along with the 40 sized, but instead I built one of Laser Cut USA Kaos' from BAC. Either path will end up with a nice Kaos, but I think your original kit will result in a stronger fuselage. Mine ended up at 5.3 lbs, less fuel. I will be interested in your final weight.
As you know I favored the original Joe Bridi scheme for mine.
Oct 13, 2019, 07:23 PM
R_G
R_G
UFO Driver
R_G's Avatar
Thanks Dave! That's one really nice looking Kaos!
Ralph
Oct 14, 2019, 06:39 PM
I just want to go fly!
walter3rd's Avatar
Wow! That’s a looker! Gorgeous...
Oct 15, 2019, 04:54 AM
Master Procrastinator
Tango Juliet's Avatar
I wish I had the ability to finish an airplane as well as that one! Beautiful! I love the Classic look of the scheme.
Nov 03, 2019, 03:24 PM
R_G
R_G
UFO Driver
R_G's Avatar
All the tri-stock in the engine & tank compartments have been sanded flush with the top and bottom of the fuselage sides. The chin block has also been attached.
The chin block had cupped over time and wouldn't sit flat on the fuselage without rocking left & right. Being of the same density as most of the wood in this kit it was a bugger trying to sand it flat. So to cut down on the area that would have to be sanded I rigged up a high tech dust collection system and had at it with my Dremel tool. It's not real pretty but doing that made it much easier to sand flat and also lightened the block a bit.
Ralph
Nov 03, 2019, 10:27 PM
Wear a mask
Nov 03, 2019, 10:53 PM
dhal22's Avatar
Originally Posted by RC YEAGER
Wear a mask
Balsa dust tastes great.
Nov 29, 2019, 08:06 PM
R_G
R_G
UFO Driver
R_G's Avatar
Not much progress, but progress nonetheless!
Carved & rough sanded the chin block flush with the fuselage sides.
Turns out I won't be able to use the 14oz. DuBro fuel tank that I was planning to install. It's too long and will interfere with the steering linkage. Their 12oz. tank is also too long. So, I'll be using a 12oz. Sullivan slant tank which is about 3/8" shorter than the DuBro tanks.
Anyone have any idea how long a muffled SF will run on 12 ounces of fuel?
Ralph
Nov 29, 2019, 09:51 PM
Depends on prop and throttle use, but 8-10 minutes.
Nov 30, 2019, 04:31 PM
R_G
R_G
UFO Driver
R_G's Avatar
Thanks! I can live with 8-10 minutes!
Ralph
Aug 23, 2020, 01:53 PM
R_G
R_G
UFO Driver
R_G's Avatar
OK, I've been dragging my feet on this build for quite a while now and I finally figured out why! The more I fly my electric models the less interest I have in anything glow or gas powered. It seems at this point in my modeling career e-power make the most sense for me. So with that epiphany I've made the decision to go exclusively with e-power.
As far as this Super Kaos is concerned I kicked around the idea of abandoning this project altogether and getting rid of it. But the more I thought about it and considering that the wing and tail feathers are pretty much done I'd hate for all that work to go to waste. So I thought about converting the current fuselage to e-power but that would have involved a LOT of extra work plus the fuselage is not the lightest thing you'll ever pick up. So I made another decision and I'll be building an all new dedicated e-power fuselage!
For power I'll be using a Scorpion 4020-540KV motor with a Castle Talon 90 speed control. According to the Scorpion prop chart it looks like this motor with an APC 11x8.5E or 11x10E prop will produce similar numbers to what an O.S. .61 SF with a stock muffler puts out.
Ralph
Aug 23, 2020, 02:05 PM
R_G
R_G
UFO Driver
R_G's Avatar
I started the new fuselage by making the parts & pieces for the motor crutch. Because of the nose gear and the forces it might generate I stayed with 1/4" birch plywood for the firewall as per the plans. I dropped back to 3/16" birch plywood for bulkhead number 2. The nose ring is from the kit which is 1/16" birch ply. Everything else is 1/8" light ply.
It doesn't look it but this structure is surprisingly ridged!
Ralph
Build Log .60 sized Bridi Super Kaos Build Mode One The Builders Workshop 373 Mar 13, 2015 08:57 PM
Found Bridi/Great Planes Super Kaos 60 or 40 Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 5 Jul 19, 2012 10:08 PM
Sold Classic Pattern Aircraft Bridi Utter Kaos 60, LPU jetflyr Aircraft - Fuel - Airplanes (FS/W) 4 Apr 07, 2012 01:23 PM
Discussion Original Bridi Kaos .60 Conversion erkq Glow to Electric Conversions 5 Jul 24, 2011 10:36 AM
For Sale Original Bridi Super KAOS 60, OS FSR 60, Futaba radio Alorek Aircraft - Fuel - Airplanes (FS/W) 5 Jul 16, 2008 12:40 PM
