Nano Master/Slave - RC Groups
Feb 14, 2013, 11:37 AM
Nano Master/Slave
I understand that when you bind 2 Nanos together as Master/Slave the slave Nano remaps to channels 7-12. Can you remap then back to channels 1-6 using the device programmer?
Jim
Feb 14, 2013, 11:51 AM
↓↘→ + (punch)
theKM's Avatar
Jim
yup... the automatic 7-12 was just to make things a little easier for the common case, but with the programmer you can set any output pin to be any channel from 1-16 including duplicates (more than one pin outputting the same channel, etc).
if you want channels 1-6 again so you can use the receiver in another plane, just re-bind it on its own and it will go back to channels 1-6.
Feb 14, 2013, 07:22 PM
What he said!
Feb 14, 2013, 11:55 PM
Thanks, KM and Jim. I was able to configure the Nanos to work together as I need them to.
Jim
Feb 18, 2013, 02:55 PM
So how does one go about binding two Nano receivers together as Master/Slave? Do you put them both in bind mode, then turn on the transmitter with the button pushed?
Feb 18, 2013, 03:12 PM
Stress Be Gone
GBR2's Avatar
Yes but there are two procedures to put a nano in either a slave or master bind mode. Plus the master receiver has to be put into bind mode LAST and then you proceed with binding with the transmitter. It is all explained in the manual.
Feb 18, 2013, 03:59 PM
I'm slow but I'm expensive
Ken Lilja's Avatar
When using a master - slave setup does each receive the RF signal?
Does the master receive and decode the signal for ch. 1-6 and the slave receive and decode the signals for ch. 7-12?
Or the master receives the RF signal and feeds a data steam to the slave?
Ken
Feb 18, 2013, 05:42 PM
Fly inverted, it's more fun.
tholmes345's Avatar
Ken
And what is the best way to power them? "Y" from the battery?
Feb 18, 2013, 09:01 PM
↓↘→ + (punch)
theKM's Avatar
they are both independent. the only difference is that the "slave" receivers aren't bothering to sent back the downstream data (ack packets, telemetry, etc).
...so, as such, they independently need the consideration that you would give a single receiver... need to make sure that the servos are getting all the power they need, the receiver gets the power it needs, nothing being choked by a servo plug that can only do 3amps of load, etc etc.
You can "y" the power connections, but just be mindful of your application... if you're driving large servos, you will want more than servo plugs to power six high powered full size digital servos for example. I've soldered larger wire pigtails to the servo buses, even connected two receivers with 14-16awg wire with a similar gauge pigtail on one of the receivers so I only had to plug the packs into one end. there's plenty of ways you can do it, but ultimately you need to make sure that you're taking care of power distribution to the servos...
Dec 27, 2016, 07:10 PM
Hello, I am considering buying a Taranis Plus transmitter which has a place in back for a module. Does X-tream Power systems have a module to fit the Taranus transmitter that would allow me to use my X-tream "Nano" receivers? I have a module in my Futaba 9C transmitter that is designed for the X-tream Nanos that works fine but I would like to get a transmitter that has more channels. I have around 20 airplanes with "Nano" receivers and do not want the expense of replacing them all to buy a new brand of transmitter. Please advise
Dec 27, 2016, 08:50 PM
PGR
PGR
Low AltiDude
PGR's Avatar
Yup. Get the XPS JR module.. I've been using one in a Taranis for years and now I'm using the same one in my Horus.
Pete
Dec 28, 2016, 05:58 PM
Hello PGR, You are saying that the JR module for X-tream Link will work with my "Nano" receivers in the Taranis Transmitter. I suppose that I would have to re-bind all of my receivers if I did that. Is there any other things that I would have to do? I am finding out that the Taranis transmitters are cheaply made with requirements of frequent repair and that the Horus is better. Should I wait until the new Horus transmitter is available?
Dec 28, 2016, 09:42 PM
PGR
PGR
Low AltiDude
PGR's Avatar
That's what I'm saying. I have at least a dozen slope planes, several powered planes, and several rotorcraft with either Nanos or RFU Diversity Receivers in them and I've flown them all with an XPS JR module in either my Taranis or Horus. I'll add that the Horus is already available to the general public, so it's not necessary to wait if you want one. I've had mine for about 3 months and I really like it.
Pete
Dec 29, 2016, 08:48 AM
I am finding out that the Taranis transmitters are cheaply made with requirements of frequent repair .....I
And where would you be finding that out ??? If you consider the thousands in use without a single issue vs the occasional radio with a legitimate issue . I would venture to say that many of the "problems"
reported are caused by the operator.......
I've had my non plus Taranis for about two years now without a single issue .....
Personally, I would wait a little longer on the Horus.... being that it is just out to the public, there are bound to be issues yet to be identified.....
Dec 29, 2016, 08:29 PM
PGR
PGR
Low AltiDude
PGR's Avatar
But you'd jump on a new XPS3216 transmitter, wouldn't you?
Pete
Discussion Spectrum Dx6i as master with a Dx5E as slave warp45 Radios 2 Jan 26, 2013 09:03 AM
Discussion Master/Slave Nano how to use with XPD? GBR2 Xtreme Power Systems 6 Jul 02, 2012 12:03 PM
Question 8ch Rx Master + Nano-T Slave? FlyingW Xtreme Power Systems 6 Jul 10, 2010 11:14 PM
Futaba TX Master Slave dilema rc capo Power Systems 1 Mar 15, 2002 11:26 AM
Futaba 8U Master to Airtronics Vanguard slave ??? Alan W Electric Plane Talk 3 Oct 26, 2001 08:59 AM
