Sep 04, 2013, 10:52 AM
Hello people I write after read carefully'm wanting to build my PHANTOM settings so that may have the greatest possible stability and autonomy of 1.5 to 2 hours.
HK15148B Digital Servo 19g / 2.8kg
60A ESC 4A UBEC
Turnigy Aerodrive SK3 - 3542-1000kv
APC 10x6 E-prop
3S 4000mAh x 3
APM 2.6
FPV 1,2 GHz
Telemetry DragonLink v2 2.4Ghz
A query to achieve my purpose I hear about battery and servos, which are the best?
tks
Sep 04, 2013, 04:53 PM
New happy Phantom owner here.
Thanks all for the advice. I went for
- Turnigy Aerodrive SK3 - 3542-1250kv
- Graupner folder with Aeronaut Cam Carbon 9.5 x 5
- Plush 60A
- TGY-306G-HV MG digital servos
- 2x 3S 2100mAh 35C in parallel (for now).
Maiden today was simply amazing in its effortlessness. I threw everything at it in the very first flight and found excellent performance including unlimited vertical without any bad surprises. Very well behaved and easy to fly.
Sep 04, 2013, 05:17 PM
Originally Posted by Frank.T
My gains are on 30, for the rest default.
(I use the original foam pad's)
//Frank
Thanks Frank,
Ill add some rods today and try your settings.
Cheers
Sep 04, 2013, 06:20 PM
FPV! and nothing else matters.
guy1a's Avatar
Mine is ready .. tomorrow test :-)
Edit :
Good maiden :-)
Only thing to add is some tape at the bottom for protection.
Sep 05, 2013, 08:55 PM
If anyone is interested I started a group over DiyDrones for APM users to share configs and other goodies, still in it's infancy.
http://www.diydrones.com/group/fx-61-phantom
Sep 05, 2013, 09:04 PM
SimpsonJ's Avatar
Just maiden my first phantom build with success. No complaints, great so far.
-immersion system
-runs 4s and 3s
-1100 kv motor with 9x6 prop
-IBcrazy dipole on rx
-Alum tape skin on top side
So far im getting a strong rx signal and seems to hold together under high speed (over 80). Looking forward to putting this rig through its paces.
Phantom Maiden (4 min 23 sec)
Sep 05, 2013, 11:38 PM
Originally Posted by mille
New happy Phantom owner here...
- Turnigy Aerodrive SK3 - 3542-1250kv...
Gotta love that motor in the phantom Yes you can get away with less but after trying one it's pretty hard to go back..
?? do you realize what that tape will be doing to your radio signals? There's a reason why no one uses aluminum tape on FPV models..
Sep 06, 2013, 01:09 AM
guy1a's Avatar
Here is mine
https://www.youtube.com/watch?v=ttCz...e_gdata_player
Sep 06, 2013, 01:23 AM
Originally Posted by guy1a
This video is private
Sep 06, 2013, 05:14 AM
guy1a's Avatar
No .. i did check and it is marked as 'public' ... strange ...
Sep 06, 2013, 05:43 AM
Rogue User
Mr Krinkle's Avatar
Worked for me
Sep 06, 2013, 06:51 AM
SimpsonJ's Avatar
Did you read my results?
Sep 06, 2013, 08:34 AM
g0t rabb1t?
ABLomas's Avatar
So far i found one post with pics about split rudders. Anyone tested "true" drag rudders on this plane?
I would like to remove vertical surfaces at all, this should eliminate stupid yaw on side wind.
On other hand... Probably my first post in this thread, so i share setup (another one coming soon, for experiments) - flown >> 500km already, so proven and working.
Desk inside (now added mic, some aditional components):
Using AUAV3 autopilot, 2.4GHz unboosted frsky. This wing is good, because it's easy to separate components and have very low interference, for example, i flown 10km with this plane and still had plenty of RSSI (i guess, even with vee - "acro" antennas i can have 15km, will verify later; ignore RSSI on screenshot, forgot to connect wires :P ):
Also, not bad endurance. I can fly 50km with one 4.4Ah 4S battery, but this is still far from 2x50km posted here. Hopefully drag rudders could improve performance a bit.
Even when going > 45 up i can get good range and good performance, for example one flight above skies (still using the same 2.4GHz frsky - clouds are real killers for this frequency):
Above clouds (or "testing 2.4G limits") (2012-2013) (9 min 54 sec)
Some things i dislike:
- stupid, really stupid yaw, esp. with side winds
- flat bottom without washout -> miss CG a bit and you get spin, very easy. I still fly with way too forward CG
- "middle desk" design on phantom sucks a bit (motor covering, middle part with FPV cam mount, etc). This could be improved with some DIY...
If everything OK, with full-size drag rudders i could get rid of current fat rudders and improve sidewinds performance. Anyone tried this?
Sep 07, 2013, 11:16 PM
I liked watching your video, very nice
Sep 07, 2013, 11:17 PM
It works for me now, maybe just a glitch.......
Help! As3x and flying wing airplanes Jyester Scratchbuilt Indoor and Micro Models 20 Mar 02, 2019 10:28 PM
New Product NEW flying wings from HObbyking - good for FPV ? i3dm FPV Talk 16 May 12, 2015 02:29 PM
Discussion Starting FPV with a flying wing? JYVAI UAV - Unmanned Aerial Vehicles 3 Mar 23, 2014 09:49 PM
Discussion The Fury Flyer- 54" Scratch build FPV Flying Wing Bixler13 FPV Talk 7 Mar 10, 2013 11:00 PM
Discussion HobbyKing - Fox 2.32m EPO Glider for FPV Cralis FPV Talk 19 Sep 14, 2011 03:24 AM
