Feb 05, 2013, 12:57 PM
Help!
Getting my head around RTH
In all cases, regardless of the sort of failsafe your Rx has, is the Eagletree is looking for inactivity on one or more inputs to the Rx to engage RTH? In other words, it doesn't truly "know" that the Rx has lost contact the the Tx, right?
As for the testing of RTH, does it always come down to tricking the OSD into seeing a failsafe position on one of the inputs that runs through the OSD (i.e. ailerons, throttle)? Or is there a way to assign another, unused channel? If so, it does not seem like there is any room on the OSD to accommodate an unused channel.
Thanks!
Scott
Feb 06, 2013, 10:01 AM
The OSD is not looking for in-activity, it's looking for a specific throttle position you have made it aware of when you run the Servo Analysis wizard. This relies upon a properly set up Failsafe on Your transmitter. It is widely written about in the FPV ET OSD thread.
Thanks!
Scott
Feb 06, 2013, 12:42 PM
Thanks! So, if this throttle position, as far as the receiver is concerned, is effectively an "off" position, that doesn't matter since the OSD's failsafe throttle position is saved as a level flight, non-zero value which we have assigned during the Servo WIzard, correct?
Feb 06, 2013, 04:14 PM
I still don't get where you "tell" the Eagletree that the negative throttle position is where it should take over. Seems to me that during the servo wizard we are only telling it cruise throttle position and descent throttle positions.
Feb 06, 2013, 06:55 PM
Eureka! I just realized the point at which the OSD is "taught" the Rx's failsafe: it's when it asks you to turn off the Tx during the servo wizard.
Feb 07, 2013, 08:55 AM
yep.
you can use some down trim or program a switch to make the throttle go a bit negative when you set your failsafes. that way its out of the normal range of throttle travel. then run the wizard.
search some et osd threads in the fpv forum to get more detail.
Discussion Getting my head around prop pitch... qacermacer Beginner Training Area (Aircraft-Electric) 7 Feb 18, 2011 11:23 AM
Discussion Two ideas bouncing around in my head - Aileron SkyFly and Flapperon Corsair SgtKashim Beginner Training Area (Aircraft-Electric) 8 May 04, 2009 10:40 PM
Question - Zip charging - getting my head around using a dedicated battery for this.. deswong Batteries and Chargers 11 Apr 24, 2009 07:08 PM
Question Zip charging - getting my head around using a dedicated battery for this... deswong DIY Electronics 1 Apr 19, 2009 07:43 PM
Trying to get my head around this realjumper Batteries and Chargers 17 Jun 12, 2008 08:19 AM
