Dec 27, 2003, 02:00 AM
Goin' Vertical
Tigger's Avatar
COX Viper Conversion
Starting to do a conversion on a Cox Sky Cruiser Viper "p51 Mustang"
Inspired by this thread and basically following qy8flyer's layout. I got mine for $15 at Big 5 and have basically gutted it and gone to work.
Pics to follow.
tIgGeR
Dec 27, 2003, 02:19 AM
Goin' Vertical
Tigger's Avatar
Here's the FF Box
BOX
Dec 27, 2003, 02:27 AM
Goin' Vertical
Tigger's Avatar
Component Layout
Well here's a start...
2 Bluebird BMS-306 servos
Berg Micro Stamp w/ Lightenna
GWS ICS-100 5Amp ESC
GWS IPS DD w/ 3x3 prop
Etech 250 2cell Lipoly
will use Dubro EZ connects on linkages.
Dec 27, 2003, 02:35 AM
Goin' Vertical
Tigger's Avatar
Profile
Here'e half the fuse (sort of like an Xray)with the wing in place. I made a small battery hatch forward of the wing like qy8flyer did.
I'm also going to do the one aileron half/elevator method that he did.
Dec 27, 2003, 02:40 AM
Goin' Vertical
Tigger's Avatar
Closeup
Here's a closer look.
Hopefully finiish her up tomorrow.
Dec 27, 2003, 03:35 AM
Hacker motoren rules :)
Philip Thulin's Avatar
is that a cooling flenge around the motor?
if so I think you can remove it cause it doesent have a good airflow to be eficiant enyway, it is just extra weight
otherwise it looks nice!
/Philip
Dec 27, 2003, 05:13 PM
Goin' Vertical
Tigger's Avatar
All Done
Philip,
That's actually a heat sink. It helps give the motor a little extra support. The other half of the fuse has generous clearance and the battery access hatch will be left uncovered for addittional cooling.
Finished it up late last night and was too tired to take photos.
Here's the elevator linkage...
Dec 27, 2003, 05:14 PM
Goin' Vertical
Tigger's Avatar
Tipping the scales
AUW = 3.5oz.
Dec 27, 2003, 05:18 PM
Goin' Vertical
Tigger's Avatar
Mini Speed Wing Dogfight
Chasing Acer's MSW.
Fun project waiting for weather to fly.
tIgGeR
Dec 27, 2003, 06:14 PM
You may not like the 250ma 2s set up,Matt D said he has tryed the same set up as you have there and then switched to 340ma 2s.The speed and power greatly overcame the extra weight and it would fly much longer.You'll find that the 250ma li/pos will only give about 180ma in this set up where as the 340ma batts will dump all 340ma for you giving a much longer flight even if you fly at full throttle with the 340s compaired to being nice to the 250s.Matt
Dec 27, 2003, 10:12 PM
Goin' Vertical
Tigger's Avatar
340's
Matt,
Thanks for the heads up. I'll check into getting some of the 340's.
tIgGeR
Dec 27, 2003, 11:47 PM
Matt D.'s Avatar
Yeah I don't even bother taking the 250s with me anymore. The only other lipoly I have is the 340 and it only gives me about 10 minutes so I wish I had more flying time. To me it isn't even worth it. I need to get another e-tec 700. That was the best of everything I think. Speed and duration although heavier than the 250s much better amp dump for that motor. It would really haul the Acro-Bipe around better.
Matt
Dec 28, 2003, 01:27 AM
There he is,Hi matt. good to see you.Matt
Dec 28, 2003, 02:44 AM
Goin' Vertical
Tigger's Avatar
All dressed up
with no calm weather in sight...
Added some of the decals. Pretty sharp lookin' little bird.
tIgGeR
Dec 28, 2003, 03:01 AM
Boy,you don't loose that one in a croud!Nice!!Matt
Sold Gaui NX4 to GX4 conver Parts moody885 Aircraft - Fuel - Helis (FS/W) 0 Mar 15, 2017 04:31 PM
For Sale Cox Sky-cruiser “viper” Electric Model Airplane With Charger Cox-5842 innoplastic Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2016 11:53 PM
Wanted Cox Hyper Viper CL plane PGregory Aircraft - Fuel - Airplanes (FS/W) 2 Aug 13, 2016 01:38 PM
Lazy cell. OPtion to conver 4S to 3S jferfre Batteries and Chargers 3 Apr 18, 2016 05:55 AM
Sold Cox Tailwind 40 convered to EP with Floats $400 LPU be69ar Aircraft - Electric - Airplanes (FS/W) 0 May 04, 2012 11:01 AM
