Jan 29, 2013, 02:04 PM
Tricopter spin - yaw problem
Hi all,
I converted my quadcopter into a tricopter.
I made a working yaw mechanism, I set tricopter mod in the KK2 board, I calibrated all ESC, and I calibrated the sensors. all props were mounted as require.
the tri is spinning very fast on the yaw axis, I don't know what to do...
I'm using an old cheap analog servo that I got when i bought a bixler,
can that make problems? maybe it's too slow? btw i defined it as low (servo parameter under mixer settings)
can you think of something else that maybe i did wrong?
I attached a few pictures.
Jan 29, 2013, 02:10 PM
AVR Dude
Go to the "Mixer Editor" and change the channel (number to the upper right) to 4 where the yaw servo is connected. Then change the "rudder" mix value to -100.
Jan 29, 2013, 04:29 PM
it works!!!
the servo was already configured to ch4, but the rudder mix was 100. i changed it to -100 and it fly like a charm!
I think KK should write a note about it in the manual... i would never figure that out alone...
Thanks a lot!!!
Jan 29, 2013, 04:53 PM
Glad you got it going. If you need to fine tune the yaw, play with the offset on that same screen. Mine slowly rotated in one direction so I changed the offset from 50 to like 43 and it was right on.
Jan 30, 2013, 01:40 AM
thanks,
now i have new screen of options to spend time on, and i'm saying it in a good way, i love tuning this piece of flying screws...
Jan 30, 2013, 02:06 AM
AVR Dude
Thanks a lot!!!
It's on the first post of KK's thread (faq #14)
https://www.rcgroups.com/forums/show...1675613&pp=100
Jan 30, 2013, 02:30 AM
yea well i don't understand why it didn't change by itself at the moment i switched layout from quad to tri?
I don't see any reason to keep the Yaw at 100 in a tricopter layout...
Jan 30, 2013, 02:55 AM
jimbob69's Avatar
Different servos require different settings. Some are +100 some are -100 etc.
Jan 30, 2013, 03:10 AM
ok now i get it,
thanks
Feb 02, 2013, 10:27 PM
Quick question since you have done what im doing, what do you connect the yaw servo to? is it one for the motor outputs?
Feb 03, 2013, 11:39 AM
ripmax's Avatar
m4 motor output
Feb 03, 2013, 01:04 PM
figuring it out...sort of!
goodhumormarc's Avatar
servo goes to M4
Mar 02, 2013, 02:16 PM
Martin Andrews
marty7's Avatar
Thank you
You sorted my spinning Tricopter - Many thanks
Mar 14, 2013, 09:40 AM
I am using a Hobbyking V2 board..I am facing the same problem,tricopter didnot lift off,but spins on ground..I have Hobbyking 6 channel radio...Would it be okay if I try out this on my setup? Please help..
Mar 14, 2013, 09:45 AM
Yes, follow the servo reversing instructions. Good luck!
Discussion Blade SR 120 spinning problem yamabiker Electric Heli Talk 3 Jan 29, 2013 01:48 AM
Discussion [tricopter] yaw mechanism KK board problem?(video) abriosi Multirotor Drone Talk 2 Nov 14, 2011 04:13 PM
Discussion yaw gyro reverse problem kkblackboard tricopter v2.3 Daemon Multirotor Drone Talk 9 Oct 30, 2011 11:36 PM
Discussion MCX Ongoing "Yaw Spin Problem" faithalone Coaxial Helicopters 15 Apr 20, 2009 12:06 PM
Help! Save me from insanity - Walkera 5#4 / Venom Ocean Rescue - yaw problems - spinning moonjoose Coaxial Helicopters 4 Oct 24, 2007 11:00 AM
