Jan 25, 2013, 11:32 PM
Nose down, you're gonna stall
rowdyjoe's Avatar
New Projects
What have you got on the bench? Tell us all about it here.
RJ
Jan 25, 2013, 11:33 PM
rowdyjoe's Avatar
New Planes - Projects Compete
Please use this area to brag about and post pictures of your newest bird.
RJ
Jan 26, 2013, 01:13 PM
rowdyjoe's Avatar
New SPA Bird
I recently finished the World Models Intruder I was building and have put about 8 flights on it so far. I'm trying to dial it in for best aerobatic performance but, not having dealt with adjustable incidence before (the horizontal) it's proving to be a challenge. Between moving the horizontal incidence and the CG I'm getting very confused.
Anyway, it flies OK but, lands very hot so, I'm trying to tune that out. The correct CG isi further aft than the factory calls for or it flies nose heavy. I like my birds set up with a neutral CG but, the added complexity of the adjustable incidence makes it difficult to tell which to adjust.
Here's a few pictures ...
Feb 02, 2013, 06:28 PM
rowdyjoe's Avatar
Moved to the completed section.
Garry
While surfing YouTube for RC plane videos I found many vids on scratch building foamies. One of the most prolific and easiest to build is a flying wing and I was impressed with how simple they really are. After watching a couple of "how to" vids, I looked around my "pile" and found that I have all of the makings for a 40" wing with a KF2 airfoil. I found several pieces of Dollar Tree foam and plenty of the pink insulation foam to do the build.
I've done most of the build and am trying to decide if I want to install an EDF or a brushless motor and prop. The EDF would be the easiest but, I think the brushless would perform better (????). I need to make a motor mount for the 28-30-9 motor I intend to use but, haven't figured that out yet.
Here's a picture of where I am so far. The EDF is tack glued in the approx. position for experimental purposes. The electronics and battery will mount on top but, I have them dangling from the bottom for test purposes.
Feb 03, 2013, 05:25 PM
rowdyjoe's Avatar
I'm so excited about these scratch built wings that I've started another one before getting the first one flying good.
This new one is a 60" wing and will be powered by a 2814/8 @ 1100kv. It will develop approx. 380 watts and should power it nicely. This wing is built with the KFm4 airfoil and built with two sheets of 20"x30" foam board for the wings and two pieces of pink 1/2" foam board to form the KFm section on top and bottom. The KFm4 is supposed to be a bit faster and more aerodynamic with a symetrical airfoil (approx.).
Instead of sanding the leading edge shape by hand, I used my orbital sander and a couple of metal guides on top and bottom to help keep them uniform. I think they came out much better than the first one but, we'll find out when it flies.
I've got her all taped up with the servos and elevons connected and I've programmed the receiver and transmitter for elevon mixing. I still need to fab. the motor mount and get it mounted. I hope to make the first flight early next week.
Garry
Feb 03, 2013, 05:44 PM
rowdyjoe's Avatar
Scratch Built Wing
Here is the finished product ready to fly. I spent a lot more time on it adding cosmetics because I didn't have much else to do. My DX7s won't be back from Horizon until tomorrow (Monday) so, I was killing time. I do have an old DX5 I used to test the servos and motor and all is working well. I'll need to program the 7s for elevons when it gets back.
I'm using a 3 cell 2650mah 30c battery and it fits well. It also balances the wing right on the CG. Total weight is 25 oz. and the specs on the motor tell me I should get 23oz. of thrust with a 9x4.5 prop. Testing shows that it has plenty of thrust to fly. The motor is a 28-30-09 turning 1250kv. It's a great little motor as I had it on a small plane a couple of years ago.
I scratch built this nurflugel wing with material and electrics I have on hand so, this is a no money out of pocket airplane. Hope it flys well.
I have some lights and may add them later after I fly it a few times to get the feel of it.
Garry
Feb 10, 2013, 09:02 PM
rowdyjoe's Avatar
Another Project Bird
I picked up a used bird yesterday that needs repair. A fellow club member had it at a price I couldn't refuse. It's the Great Planes Super Chipmunk and it came with a Zenoah G38 converted to CDI and a smoke system. This is my first smoker and I will probably need help figuring it out.
I spent some time working on it this afternoon and evening. As I understand it, it suffered a rough landing and ripped out the fixed gear. I've been patching that damage and getting it ready to patch the covering.
I forgot to take pictures while I had everything set up in the garage but, here's a link to the Great Planes site where you can see a picture and all of the info on it.
http://www.greatplanes.com/discontinued/gpma1303.html
Garry
Feb 13, 2013, 11:47 PM
rowdyjoe's Avatar
Chipmunk update:
The repair and reconfiguration is coming along fine ...I'm making good progress. I re-plumbed the fuel and oil tanks today, fabricated a new landing gear strut, installed the fuel tank, installed ignition and receiver wiring and switches, re-installed the servo tray, and installed the throttle servo, elevator servos, and rudder servo. I bought a new AR7000 but, until it arrives I am using an old AR6100 for systems tests. Everything checks out fine so far.
I still need to apply the patches on the covering and a flying buddy has offered to help. He has some scrap Monokote of the three colors I need to make the repair.
I also need to install the aileron and flap servos and install the smoke tank
The project is picking up speed. I've removed everything I wanted to change and am now installing it the way I want it. I have two separate electrical systems and have ordered 2 LIFEPo batteries to run them. I have installed a 5v voltage regulator in line with the ignition just to be sure it's not getting more than it's rated for. I'm not familiar with this brand of ignition but, most of the early ones were limited to a max. of 6 volts. I'm glad it's working and want to keep it that way.
I hope to have her ready to fly next week. This is a nice looking old bird and it will be great to see it in the air again.
RJ
Feb 18, 2013, 12:44 AM
rowdyjoe's Avatar
With the help of a friend, who is an expert at applying covering, we applied the correct colors of monokote to the repaired areas of the wings. He did a great job adn they look terrific.
I installed the aileron and flap servos this evening and got everything adjusted to neutral so, when my new receiver gets here all will be ready.
The muffler should be repaired and ready by now so, I can pick it up and install it.
She's getting close to our first flight together and I'm getting more excited. The smoke system won't be active for another week or so because I'm waiting for a couple of check valves to be delivered. I picked up a gallon of smoke oil from my friend today so, when the system is ready I will be too.
While messing around with the engine I noticed it didn't want to rotate in reverse. That's when I discovered it has a starter spring. I watched a couple of pilots starting their engines with spring starters and it appears to work quite well for them. Hope it works the same for me. Although, It should start fine by flipping it forward like we do all of the other gas engines. I hope to find out soon.
Garry
Feb 19, 2013, 09:27 PM
rowdyjoe's Avatar
I assembled the Chipmunk last night just to see how it will look once it's ready for flight. I like it. Here's a couple pics. Don't pay any attention to the itty bitty wheels. They are very temporary.
Feb 21, 2013, 10:44 AM
rowdyjoe's Avatar
Chipmunk update:
I installed the muffler and filled the tank and got the engine started. It ran great for the first 5 min. and then started surging rapidly. I think I have an air leak and the carb needs to be overhauled and cleaned anyway. The plane and engine have been sitting for at least a year and probably more. At least I know it will run and it pulled strong running an 18x8 prop. This will be a fun bird when I get it running right.
The check valves I was waiting for arrived yesterday so, I can complete the plumbing for the smoke system. However, I need to get the engine running well before I can think about smoke.
I have a carb kit on the way.
Garry
Feb 22, 2013, 02:38 AM
rowdyjoe's Avatar
Chipmunk update:
The air leak is resolved and now the engine runs very well. It still needs new gaskets, valves and diaphragm because it won't hold a decent idle. The airplane sat in disrepair for a year or more and the carb components dried out. Now the diaphragm is so stiff it won't pull fuel reliably a low RPM. It will idle for a while at a nice even 1800RPM but, will die after about 30 seconds. The transition and top end are very good. I peaked the high end at 7950RPM swinging an 18x8 Xoar prop. It pulls strong all the way through. However, it will run better after the carb gets overhauled. The kit should be here in a couple of days.
Garry
Feb 23, 2013, 02:16 PM
carb kit
if you cant find one try graves rc had to get one for neals stinger that i built for him!! graves had them in stock when no one else did!! also try b&b specialties!!!
Feb 24, 2013, 02:46 AM
rowdyjoe's Avatar
Thanks Mike but, I ordered one from a place call "Replacement Parts". I haven't found anything they don't have in the way of parts for the Walbro carbs. I have the kit on-hand and will install it soon.
This bird has been bumped to 2nd in line because the USPS has misrouted my new receiver. It was due to be delivered on the 19th but, has not shown up. The last tracking info came from Denton AFTER it had made it to the Ft. Worth PO. I can't figure out why it takes so long to correct their mistake and send it back to Ft. Worth. The longer it takes to get here the more "ticked off" I get. I ordered another new receiver for the Reactor Bipe I just picked up and it arrived today with no problem. Go figure.
Also got my muffler back from JTECH for the 15cc gasser on my H9 Camel. I installed it tonight and I'm ready to crank her up for a flight.
The Reactor is just about ready to fly too. I replaced the small tank with a larger one (didn't like that tiny 10oz tank) and installed the new receiver. Wow, this thing has some wild control surfaces. It has 4 ailerons and they are 4 inches wide each. The rudder looks like a barn door and the elevators look like huge fly swatters. I'll be dialing in mucho expo and tiny control deflections until I get accustomed to this bird. It has a 20cc Zenoah EI gasser on it that I hope to get running tomorrow.
Garry
Feb 24, 2013, 08:32 PM
rowdyjoe's Avatar
BiG Wing:
Here's another one I built one day while bored. Haven't flown it yet. Wing span is 60" and the motor is 2814/8 1100kv. Using a 4 cell it will generate 380 watts with a 9x5 APC.
RJ
Discussion Carrotcake's NEW RC8T"e" project(s). New/Current owners Welcome-tips/info. carrotcake Electric Power Cars 423 Oct 20, 2014 09:54 PM
Discussion New scale boat project jimmy777 Scale Boats 7 Jan 28, 2013 04:37 PM
Discussion My Scale Project Overview Since 2009 catcat Scale Helicopters 4 Jan 17, 2013 01:15 AM
Discussion Im New, Asking some questions about my new project me madjoe 90 1/2A Planes 19 Jun 07, 2011 12:44 AM
Discussion New Project = new problems !! danny_boy Dock Talk 4 Oct 23, 2008 12:38 PM
