Jun 09, 2014, 01:27 PM
hi again, Patolin
As i told it before i use "rctx_0_7" soft (lcd 16 x 2).
On the test circuit i use all the parts including the lcd.
But in the final circuit i don t wanted to use it, is ok to connect A0 to vcc?
And the fields like "guardar" what means?
Jun 09, 2014, 05:36 PM
Originally Posted by emil21
hi again, Patolin
If you remove the LCD you can connect A0 to Vcc, and the keyboard and menus get dissabled.
Also "Guardar" = "Save". It saves the actual settings into the actual model record.
Jun 10, 2014, 02:06 AM
aaaa..ok
Thank you
Jun 19, 2014, 12:09 PM
this is my mod with oled display adafruit connected via i2c, nice because you have a lot More input Pins free, the upper right is a pot ch5 the middle is a rotary enc that i try to get working upper left is TC switch, sry couldnt get a sharp Video with my mobile so made pics
i dont use it at the moment because i must find a solution to trim at least the center position, and im not very good at arduino code
here is my current code
Code:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <EEPROM.h>
#define OLED_RESET 6
Adafruit_SSD1306 display(OLED_RESET);
// config PPM
#define servoCentro 1500       //servo center value (us)
#define ppmLong 22500          //ppm frame
#define ppmPulso 300           //ppm pulse width
#define onState 0              //Polarity: 0 neg / 1 pos
#define sigPin 9               //ppm output pin
#define ppmMin 1000
#define ppmMax 2000
// config TX
#define CANALES 5              //number of channels
#define MODELOS 5              //total model memory
#define canalTh 2              //Throtle channel ID
#define potMin 0               //Pot min value
#define potMax 1023            //Por max value
#define txVer "ArduTX v1.1"
#define numBytesPorModelo 32
#define swTC 5
#define swDR 11
int ppm[CANALES];              //ppm output array
unsigned char sw_status=0x00;  //0:TC 1:DR
unsigned int pots[CANALES];    //ADC data array
unsigned char inPots[CANALES] = {A1, A0, A2, A3, A6};    //Input pins array
unsigned char batPin = A7;
// nothing editable from here :)
unsigned char menuActual=0;
unsigned char menuSubActual=0;
unsigned char submenuActual=0;
unsigned char drSeleccion=0xFF;
unsigned char pantalla=0;
unsigned char menu=0;
unsigned char modeloActual=0;
unsigned char servoReversa;
unsigned char dual_rate_low[CANALES];
unsigned char dual_rate_hi[CANALES];
boolean displayReady=false;
int temporal=0;
int calibracion[CANALES][2];
char msgs[][19] = {
  "Main Menu",
  "Servo Direction",
  "Dual Rates",
  "Model Selection",
  "Save data",
  "Stick Calibration"
// timer1 setup
void configTimer1() {
  cli();
  TCCR1A = 0;
  TCCR1B = 0;
  OCR1A = 100;
  TCCR1B |= (1 << WGM12);
  TCCR1B |= (1 << CS11);  // prescaler 8: 0.5us - 16mhz
  TIMSK1 |= (1 << OCIE1A);
  sei();
// Interrupcion del timer
ISR(TIMER1_COMPA_vect){
  static boolean state = true;
  TCNT1 = 0;
  if(state) {
    digitalWrite(sigPin, onState);
    OCR1A = ppmPulso * 2;
    state = false;
  else{
    static byte cur_chan_numb;
    static unsigned int calc_rest;
    digitalWrite(sigPin, !onState);
    state = true;
    if(cur_chan_numb >= CANALES){
      cur_chan_numb = 0;
      calc_rest = calc_rest + ppmPulso;
      OCR1A = (ppmLong - calc_rest) * 2;
      calc_rest = 0;
    else{
      OCR1A = (ppm[cur_chan_numb] - ppmPulso) * 2;
      calc_rest = calc_rest + ppm[cur_chan_numb];
      cur_chan_numb++;
void setup() {
  unsigned char i;
  // switches setuo
  pinMode(swTC, INPUT_PULLUP);
  pinMode(swDR, INPUT_PULLUP);
  digitalWrite(swTC, HIGH); // pullup
  digitalWrite(swDR, HIGH); // pullup
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  digitalWrite(2, HIGH); // pullup
  digitalWrite(3, HIGH); // pullup
  digitalWrite(4, HIGH); // pullup
  // zero state values for ppm
  ppm[0]=servoCentro;
  ppm[1]=servoCentro;
  ppm[2]=ppmMin;
  ppm[3]=servoCentro;
  ppm[4]=servoCentro;
  ppm[5]=servoCentro;
  //zero state config parameters
  // servo reverse: 0 normal, 1 reverse
  servoReversa=0b00000000;
  // dual rates por defecto
  for (i=0;i<=CANALES;i++) {
    dual_rate_low[i]=75;
    dual_rate_hi[i]=100;
  // load data from eeprom
  //reseteaEeprom();
  modeloActual=cargaDatosEeprom(255);
 // LCD config
  display.begin(SSD1306_SWITCHCAPVCC, 0x3D);
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.print(txVer);
  display.setCursor(0,7);
  display.print("(c) 2014");
  display.display();
  delay(2000);
  // ppm timer config
  pinMode(sigPin, OUTPUT);
  configTimer1();
void loop() {
  int i;
  int j=0;
  unsigned char tecla=0;
  int vBat;
  unsigned char valT;
  while(1) {
    vBat=analogRead(batPin);
    // read potentiometers
    readPots();
    readSwitches();
    // read keyboard value every 10th loop and store it
    // and set the values depending on the menu option
    displayReady=false;
  if (pantalla==0) {
      // info screen
      unsigned char valBar;
      display.setCursor(2,0);
      display.print("M: ");
    display.setCursor(30,0);
    display.print(modeloActual+1);
      // throtle cut switch value
             // throtle cut
          if (bitRead(sw_status,0)==0) {
            display.setCursor(2, 57);
            display.print("TC");
          } else {
            display.print("  ");
          // dual rates
          if (bitRead(sw_status,1)==0) {
             display.setCursor(45, 57);
            display.print("Rate: LO");
          } else {
             display.print("Rate: HI");
      // batery Voltage
      display.setCursor(75, 0);
      display.print("Bat: ");
      int voltajeBat=map(vBat,0,1023,0,100);
      display.setCursor(98, 0);
      display.print(voltajeBat);
      display.setCursor(120, 0);
      display.print("%");
      // draw the bars
      display.drawLine(64,9,64,42, WHITE);
      for (i=0;i<=4;i++) {
        // level bars
        valBar=pots[i]/11,5;
        display.drawRect(15,9+(i*8),98,3, WHITE);
        display.drawPixel(16+valBar,10+(i*8), WHITE);
        display.drawPixel(15+valBar,10+(i*8), WHITE);
        display.drawPixel(17+valBar,10+(i*8), WHITE);
        // servo reverse indicator
        if (bitRead(servoReversa, i)) {
          display.setCursor(8, 8+(i*8));
          display.print("R");
        } else {
          display.print("N");
    else {
      if (pantalla==1) {
         // main menu
         display.setCursor(0, 0);
         display.print(msgs[0]);
          for (i=1;i<=5;i++) {
              if (i==menuSubActual) {
              display.setCursor( 0, i*9);
              display.print("->");
              display.setCursor( 10, i*9);
              display.print(msgs[i]);
              } else {
              display.print("  ");
      if (pantalla==2) {
        if ( menuActual==1) {
          // servo reversing
          display.setCursor( 0, 0);
          display.print(msgs[menuActual]);
          for (i=0;i<=(CANALES-1);i++) {
              display.setCursor( 0, 8+i*8);
            else {
              display.print("  ");
              display.setCursor( 10, 8+i*8);
            display.print("CH: ");
              display.setCursor( 22, 8+i*8);
            display.print(String(i+1));
            if (bitRead(servoReversa,i)) {
              display.setCursor( 26, 8+i*8);
              display.print(" - R");
            else {
              display.print(" - N");
              display.setCursor( 55, 42);
          display.print("Mod: ");
              display.setCursor( 75, 42);
          display.print(String(modeloActual+1));
        if(menuActual==2) {
          // dual rates
          unsigned char contadorTemp=0;
            display.setCursor(0, 8+i*8);
            display.setCursor(18, 8+i*8);
            if (menuSubActual==contadorTemp) {
              if (drSeleccion==contadorTemp) {
                display.setCursor(26, 8+i*8);
                   display.print("*");
              else {
                   display.print(">");
          display.setCursor(30, 8+i*8);
               display.print("L:" );
               display.setCursor(42, 8+i*8);
               display.print(String(dual_rate_low[i]));
               contadorTemp++;
                 display.setCursor( 55, 8+i*8);
                   display.print("*");
                 } else {
                   display.print(">");
               display.setCursor(  60, 8+i*8);
               display.print("H:");
               display.setCursor(  70, 8+i*8);
               display.print(String(dual_rate_hi[i]));
               contadorTemp++;
        if (menuActual==3) {
          // model selection
          for (i=0;i<=(MODELOS-1);i++) {
           display.setCursor(  8, 8+i*8);
                 display.setCursor(  27, 8+i*8);
                 display.print(String(i+1) );
                    display.print("->" );
                 } else {
                    display.print("  ");
                 if (i==modeloActual) {
                   display.setCursor(35, 8+i*8);
                    display.print("*");
        if (menuActual==4) {
          // data save
          int eepromBase;
          eepromBase=numBytesPorModelo*modeloActual;
          unsigned char eepromPos =eepromBase;
          // actual model
          EEPROM.write(511,modeloActual);
          // servo reverse
          EEPROM.write(eepromPos, servoReversa);
          eepromPos++;
          // dual rates
            EEPROM.write(eepromPos, dual_rate_low[i]);
            eepromPos++;
            EEPROM.write(eepromPos, dual_rate_hi[i]);
            eepromPos++;
          display.setCursor(  0, 20);
             display.print("Saving data for");
          display.setCursor(  0, 28);
             display.print("actual model:");
          display.setCursor(  0, 40);
          display.setCursor(  0, 42);
             display.print("...wait");
          pantalla--;
          menuActual=1;
          menuSubActual=1;
             display.display();
          delay(1000);
        if (menuActual==5) {
          // gimbal calibration
          display.display();
          delay(500);
            calibracion[i][0]=512;
            calibracion[i][1]=512;
          tecla=readKeys();
          while (tecla!=1) {
            display.print("Calibration");
            display.setCursor(  0, 8);
            display.print("Move the sitcks");
            display.setCursor(  0, 16);
            display.print("1: ");
            display.setCursor(20, 16);
            display.print(String(analogRead(inPots[0])));
            display.setCursor(  40, 16);
            display.print("2: ");
            display.setCursor(  60, 16);
            display.print(String(analogRead(inPots[1])));
            display.setCursor(  0, 24);
            display.print("3: ");
            display.setCursor(  20, 24);
            display.print(String(analogRead(inPots[2])));
            display.setCursor(  40, 24);
            display.print("4: ");
            display.setCursor(  60, 24);
            display.print(String(analogRead(inPots[3])));
            display.setCursor( 0, 32);
            display.print("5: ");
            display.setCursor( 20, 32);
            display.print(String(analogRead(inPots[4])));
            display.setCursor(   40, 32);
            display.print("6: ");
            display.setCursor(  60, 32);
            display.print(String(analogRead(inPots[5])));
          display.display();
            int lecturaTemporal;
              lecturaTemporal=analogRead(inPots[i]);
              // min values
              if (lecturaTemporal<=calibracion[i][0]) {
                calibracion[i][0]=lecturaTemporal;
              // max values
              if (lecturaTemporal>=calibracion[i][1]) {
                calibracion[i][1]=lecturaTemporal;
              delay(10);
            tecla=readKeys();
          // save calibration data
          int posEeprom=0;
            posEeprom=400+(i*4);
            EEPROMWriteInt(posEeprom, calibracion[i][0]); //min
            posEeprom+=2;
            EEPROMWriteInt(posEeprom, calibracion[i][1]); //max
          display.print("Saving calibration");
          display.print("data");
          display.display();
          delay(1000);
          pantalla=0;
          menuActual=0;
          menuSubActual=0;
    // screen update
    display.display();
    // read keyboard every 2 loops
    if (j>2) {
      tecla=readKeys();
      if (tecla==2) {
        if (pantalla<2) {
          pantalla++;
          menuActual=menuSubActual;
          menuSubActual=0;
        else {
          // options for each menu
          if (menuActual==1) {
            // reversa de servos
            bitWrite(servoReversa, menuSubActual, !bitRead(servoReversa,menuSubActual));
          if (menuActual==2) {
            // dual rates
            if (drSeleccion!=0xFF) {
              drSeleccion=0xFF;
            else {
              drSeleccion=menuSubActual;
            // model selection
            modeloActual=menuSubActual;
            EEPROM.write(511, modeloActual);
            cargaDatosEeprom(modeloActual);
            pantalla=0;
            menuSubActual=0;
            menuActual=0;
      if (tecla==3) {
        switch (menuActual) {
        case 2:
          if (drSeleccion==0xFF) {
            if (menuSubActual<(CANALES*2)) {
              menuSubActual++;
              if (pantalla==0) {
                pantalla++;
          else {
            if ((drSeleccion%2)==0) {
              if (dual_rate_low[drSeleccion/2]>0) {
                dual_rate_low[drSeleccion/2]--;
            else {
              if (dual_rate_hi[drSeleccion/2]>0) {
                dual_rate_hi[drSeleccion/2]--;
          break;
        default:
          if (menuSubActual<6) {
            menuSubActual++;
            if (pantalla==0) {
              pantalla++;
          break;
      if (tecla==1) {
        case 2:
            if (menuSubActual==0) {
              pantalla--;
              menuSubActual=1;
              menuActual=0;
            else {
              menuSubActual--;
          else {
              if (dual_rate_low[drSeleccion/2]<100) {
                dual_rate_low[drSeleccion/2]++;
            else {
              if (dual_rate_hi[drSeleccion/2]<100) {
                dual_rate_hi[drSeleccion/2]++;
          break;
        default:
          if (menuSubActual>0) {
            menuSubActual--;
          else {
            if (pantalla>0) {
              pantalla--;
              menuSubActual=1;
              menuActual=0;
          break;
      j=0;
    j++;
void readPots() {
  unsigned char i,j;
  int temporalPots[CANALES];
    // read the pots
    temporalPots[i]=analogRead(inPots[i]);
    // calibration mapping
    pots[i]=map(temporalPots[i],calibracion[i][0], calibracion[i][1], 0, 1023);
    // servo reversing
    if (bitRead(servoReversa,i)==1) {
      pots[i]=1023-pots[i];
    // Throtle cut
    if (i==canalTh && bitRead(sw_status,0)==0) {
      // TC activado
      pots[i]=0;
    // dual rates
      // low, rates
      pots[i]=ajusteDR(pots[i],dual_rate_low[i],i,canalTh);
    else {
      // hi rates
      pots[i]=ajusteDR(pots[i],dual_rate_hi[i],i,canalTh);
    // map values to PPM
    ppm[i]=map(pots[i],potMin, potMax, ppmMin, ppmMax);
void readSwitches() {
  // read switches and set into the sw_status var
  if (digitalRead(swTC)==HIGH) {
    bitWrite(sw_status,0,1);
  else {
    bitWrite(sw_status,0,0);
  if (digitalRead(swDR)==HIGH) {
    bitWrite(sw_status,1,1);
  else {
    bitWrite(sw_status,1,0);
unsigned char readKeys() {
  unsigned char salida;
  salida = 0;
  if (digitalRead(4)==0) salida=3;
  if (digitalRead(2)==0) salida=2;
  if (digitalRead(3)==0) salida=1;
  // read analog keyboard
  delay(25);
  return salida;
int  freeRam () {
  // returns free ram in avr chip
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
unsigned char cargaDatosEeprom(unsigned char mod) {
  // load data from eeprom, for selected model
  int eepromBase;
  unsigned char i;
  if (mod=255) {
    mod=EEPROM.read(511);
  eepromBase=numBytesPorModelo*mod;
  unsigned char eepromPos=eepromBase;
  // servo reversing
  servoReversa=EEPROM.read(eepromPos);
  eepromPos++;
  // dual rates
  for (i=0;i<=CANALES-1;i++) {
    dual_rate_low[i]=EEPROM.read(eepromPos);
    eepromPos++;
    dual_rate_hi[i]=EEPROM.read(eepromPos);
    eepromPos++;
  int posEeprom;
    calibracion[i][0]=EEPROMReadInt(posEeprom); //minimo
    posEeprom+=2;
    calibracion[i][1]=EEPROMReadInt(posEeprom); //maximo
  return mod;
unsigned char reseteaEeprom() {
  // erases eeprom, just for checking values (unused now)
  int eepromBase, eepromPos;
  unsigned char i,j;
  EEPROM.write(511,0);
  for (j=0;j<=CANALES-1;j++) {
    eepromPos=numBytesPorModelo*j;
    EEPROM.write(eepromPos,0x00);
    eepromPos++;
      EEPROM.write(eepromPos,75);
      eepromPos++;
      EEPROM.write(eepromPos,100);
      eepromPos++;
int ajusteDR(int valor, float dr, unsigned char canal, unsigned char canTh) {
  // dual rate calc
  int salida,temp;
  float mult;
  mult=dr;
  if (canal==canalTh) {
    salida=(int)valor*mult/100;
  else {
    temp=valor-512;
    salida=(int)((temp*mult/100)+512);
  salida=constrain(salida,0,1023);
  return salida;
void EEPROMWriteInt(int p_address, int p_value) {
  // write a 16bit value in eeprom
  byte Byte1 = ((p_value >> 0) & 0xFF);
  byte Byte2 = ((p_value >> 8) & 0xFF);
  EEPROM.write(p_address, Byte1);
  EEPROM.write(p_address + 1, Byte2);
int EEPROMReadInt(int p_address) {
  // read a 16 bit value in eeprom
  byte Byte1 = EEPROM.read(p_address);
  byte Byte2 = EEPROM.read(p_address + 1);
  long firstTwoBytes = ((Byte1 << 0) & 0xFF) + ((Byte2 << 8) & 0xFF00);
  return (firstTwoBytes);
Jun 19, 2014, 12:33 PM
Amazing job! That display fits perfectly in that small transmitter. and may be using an input multiplexer, the digital trims can be used, if you got 4 spare pins in the arduino (3 for mux channel select and 1 for input), after the display upgrade
Jun 19, 2014, 02:07 PM
wrong descision, wrong time
I have all the parts for mine, and I'm starting to put it together. I bought this OLED display:
http://www.banggood.com/0_96-Inch-I2...-p-922246.html
And I can run adafruit test code on it. The odd thing is the top lines (probably top 1/4) of the display are yellow, and the both 3/4 is cyan. I'm running the code for the 128x64 i2c board. I don't know if I have a defective unit, or if that is the way this thing works.
Anyways, I need to get the rest of things put together, and am looking forward to getting this working
Heath
Jun 19, 2014, 02:37 PM
No a defect its the two colour version, Guess mix up at factory.
Jun 19, 2014, 03:11 PM
Ah well. I can make it work
Jun 19, 2014, 03:16 PM
Could even be a bonus if only labels use top line.
Jun 19, 2014, 07:18 PM
well, i just find this thread
i also made a simple transmiter with 8 ch and i use lcd 5110 .It can convert to use a lcd 0LED or lcd ST7565 and develop protocol easy
using for helicopter , airplan and multicopter
Jun 19, 2014, 07:36 PM
We can rebuild it!
djdavies83's Avatar
Nice display code, I like the trim possiton tabs you have around the edges.
Jun 19, 2014, 08:10 PM
sorry ..... double
Jun 19, 2014, 08:11 PM
do you use arduino or other ? Great.
Jun 19, 2014, 11:25 PM
i use two version atmega128 and atmega32 . I will create new thread if everyone care
Jun 20, 2014, 01:09 AM
Looks nice! If you want you can share code and schematics
Sold Airtronics RD 6000 6CH Computer Radio w/ extras hobbyfun100 Aircraft - General - Radio Equipment (FS/W) 2 Feb 06, 2013 08:17 AM
Discussion need help with HobbyKing 2.4Ghz 6Ch Tx & Rx V2 berts Beginner Training Area (Aircraft-Electric) 2 Jan 26, 2013 11:58 PM
Sold Airtronics RD 6000 6CH Computer Radio w/ extras hobbyfun100 Aircraft - General - Radio Equipment (FS/W) 1 Jan 19, 2013 01:37 PM
Discussion Arduino -> FASST TX module ---> receiver codeforge DIY Electronics 1 Jan 02, 2013 01:42 PM
Help! Can't get Hobbyking 6ch tx to work with computer doh2doh Radios 2 Jun 14, 2012 11:07 AM
