Jan 24, 2013, 12:40 AM
old4570's Avatar
V911 with Nano Tech battery mod [ 300mAh ]
Well , been meaning to this one for a long time , actually got motivated today .
A lot of people said it could not be done , should not be done , would kill the V911 and the way it flies ...
Well , who you gona believe , hu ?
Im a firm believer in DIY , Do it yourself - and find out !
So the good or the bad news , it flies very much like Same' o Same' o , very little difference , actually none that I can really tell ..
Just ground away as much of the old battery tray as possible , leaving enough behind for the zip tie ..
Battery is zip ties in place with a small amount of double sided foam tape to stop it [ battery ] sliding about ..
So having worn out my original batteries , I now have a nano-tech 300mAh battery to fly with ... I think I can live with that ...
Jan 24, 2013, 01:10 AM
Hows the run time with this? I modified mine & run a 240mah battery, my original 200mah weighs 6 grams & the 240 weighs 6grams because it doesn't have the hard plastic piece like the originals. Any other mods? & have you thought about using velcro instead of zipties
Videos?
Jan 24, 2013, 02:23 AM
old4570's Avatar
Recharging the battery I get about 200mAh going in ...
Voltage is about 3.7v when there is not enough power to keep the V911 in the air ...
At the start of the battery there is no difference .. The original batteries ran further down [ lower voltage ] So run time is about the same
I did this as I had the batteries on hand , [ Two micros converted to this battery ]
I'll see about a video ..
For Sale 5 TURNIGY NANO-TECH MCPX LIPO 300MAH 35C BATTERY NEW $30 shipped 3drcparts Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 13, 2012 07:46 PM
Found Turnigy Nano-Tech 300mah batteries lawguy14 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 19, 2011 05:34 PM
Sold 100x Nano-tech 300mah MCPx batteries - $3.05 each mmalik4 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 19, 2011 08:30 PM
Sold 100x Nano-tech 300mah MCPx batteries - $3.05 each mmalik4 Aircraft - Electric - Helis (FS/W) 2 Sep 19, 2011 05:43 PM
Alert Hobbyking Buddy Price Code -Nano-tech 300mah MCPx batteries - $3.05 mmalik4 Hot Online Deals 1 Sep 19, 2011 01:42 PM
