Jul 29, 2015, 03:38 PM
Vtol help
I have started my own vtol project and have semi completed the build (pic attached) and used the chimera wiring diagram as a reference. I need help on the coding portion as I am a bit novice at that. thanks for the help
-Ryan
Jul 29, 2015, 03:43 PM
olex's Avatar
Check out OpenAeroVTOL firmware for the KK2.1/KK Mini, it can make it a lot easier: https://www.rcgroups.com/forums/show....php?t=1972686. Needs quite a lot of configuration, but much less work than writing all the code yourself.
Jul 29, 2015, 03:46 PM
Thanks.... I literally just bough that a couple hours ago. We will see how it goes with that!
Jul 29, 2015, 06:10 PM
Ran D. St. Clair's Avatar
You might want to check out the VTOL Trainer build thread.
https://www.rcgroups.com/forums/show....php?t=1814667
Also the Simple VTOL Build thread
https://www.rcgroups.com/forums/show....php?t=1958738
And of course all the great pictures and links in the sticky thread at the top of the VTOL Forum.
https://www.rcgroups.com/forums/show....php?t=2056389
Aug 02, 2015, 08:59 AM
Kit Manufacturer
coreman's Avatar
As for Peter aka Foam and Tape, he is busy working with Flite Test as one of the members
http://flitetest.com/articles/041-wh...ol-foamandtape
Mar 23, 2017, 10:36 AM
rchopper56's Avatar
Bump
Mar 23, 2017, 01:19 PM
update
he is now on his own:
https://www.youtube.com/channel/UC7y...l7q8La_w/about
Mar 23, 2017, 01:23 PM
new
and i wonder how this could be influenced by the new horizons convergence that stops the tail rotor for level flight.
https://www.hobbyzone.com/eflite/air.../EFL11050.html
what kind of electronic components are used? diagram? program?
Mar 23, 2017, 02:10 PM
walk before run
i think that for now i better get a convergence and start flying it. later i may use the components for my own plane, that will be sort of chimera layout: high wing, twin booms. and way larger and lighter. am not after fast but just fun.
then, whenever the competition releases cheaper and maybe better models and/or electronics, may be able to experiment.
when i got into micros indoor i got the sukhoi, that was the only plane available at the time, and used the components for my own designs, and this worked fine. you may search into my blog and see what i was able to do. and had lots of fun in the meantime!
Mar 23, 2017, 07:51 PM
A couple years ago at the Toledo RC show I briefly talked to Dave Thacker at his booth, and mentioned that he should sell a parts kit for the Chimera. Then Peter went to work for FliteTest for a year or so, and FT who I thouhht would run with this, never did.
DAve Thacker said there was a chinese company that was interested in selling a complete model. Maybe they can ressurect this idea? Go up against the Horizon model, with one that frankly looks a lot better.
Discussion Tricopter Rudder Motor tilt vs control surface? dcame002 Multirotor Drone Talk 0 Jan 11, 2013 03:08 PM
Discussion VTOL - Tilting rotor shaft? Tomo8281 VTOLs 11 Aug 11, 2011 11:04 AM
Discussion Various tilt rotor VTOL attempts, full size, but interesting. eflightray VTOLs 1 Jun 16, 2010 08:23 AM
Discussion Full 90 degree tilt rotor VTOL numb_thumb VTOLs 19 Dec 15, 2009 12:45 AM
Discussion twin engine VTOL ( tilt rotor ) persianpatient Coaxial Helicopters 0 May 02, 2008 03:18 AM
