Jan 30, 2013, 09:09 AM
Lets break some props :D
joseico90's Avatar
Bending 6mm Depron foam
Now this one is really easy..
1-Sand its skin on both sides to reduce skin tension and prevent snapping / cracks while bending.
2-Heat up and bend around shape of desired radius (to tape one edge to the bottle helps)
3-Trim and fit
Easy!
This technique has many uses with EDF's and fuselages etc etc..
Jan 31, 2013, 01:08 PM
joseico90's Avatar
Bottom of the JetBall view..
Using extra strong glue sticks here with the glue gun.
Battery will insert and travel in this holder.
Another example of foam bending, rewarding stuff.
How its made video..
Bending square angles with 6mm Depron foam and heat gun (1 min 56 sec)
Feb 11, 2013, 04:25 PM
joseico90's Avatar
progress pics, gear now covered and generally a bit more streamlined
Feb 11, 2013, 07:40 PM
Vertical approach specialist
potshot's Avatar
Wow! I'll bet Gold Guy never thought a Nutball cousin would ever look like that. It looks fast sitting there.
Feb 12, 2013, 06:24 AM
joseico90's Avatar
Hi John!
I have more painting to do on it, its a work in progress..than you
Feb 12, 2013, 09:19 PM
potshot's Avatar
Did I say WOW? Holy details, Batman!
Feb 13, 2013, 05:41 AM
joseico90's Avatar
Lol
Feb 13, 2013, 09:39 AM
joseico90's Avatar
more progress
Weathering tricks for model aircraft (2 min 52 sec)
Feb 13, 2013, 02:56 PM
Flying RC Models for 60 years.
Sixter's Avatar
Jose Thanks for shearing your Weathering process. What Brand and type of paint do you use? Your painting skills are very impressive
Bobby
Feb 14, 2013, 03:53 AM
joseico90's Avatar
Hi Bobby,
I'm using Humbrol acrylic paint in rattle cans. A humble Sharpie black marker and Isopropanol alcohol to dissolve it as in the video.
Feb 14, 2013, 11:19 AM
Sixter's Avatar
Jose, Thanks, who needs a stinking Airbrush Do it with a Rattle Can Paint, Awesome
Bobby
Feb 14, 2013, 12:29 PM
joseico90's Avatar
I have an airbrush, but I find it a pain..having to set it up, clean it, change colors..blah blah....
Nah, reach for the can, spray..put away, easy.
For now I stick to the cans, way more easy and results are good enough for me
Feb 14, 2013, 09:57 PM
Sixter's Avatar
Jose I totally agree with you I have two IWATA Eclipse Airbrushes. I find myself using the Rattle Spray Can paints all the time because of the time involved in the preparation on the paint and the clean up of the Airbrushes And with a little patience you can get very good results, like your results
Bobby
Feb 15, 2013, 05:55 AM
joseico90's Avatar
Indeed
more pics, nearing completion and flight readiness,
Build Log Scratchbuild Full fuse X-31 70mm duct fan RCSquale Foamies (Scratchbuilt) 4 Mar 08, 2013 01:44 PM
Sold Two Turbax Fan systems. Two K&B Ducted fan engines one new and one test run Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 8 Jan 25, 2013 08:51 PM
Sold OS Max ducted fan engine, Turbax fan & pipe Robert-CSD Aircraft - Fuel - Jets (FS/W) 0 Jan 14, 2013 10:36 PM
Sold (2) Kyosho Lemans AP29L Special Ducted Fan Motor & Fan gromitvt10 Aircraft - Electric - Jets (FS/W) 0 Jan 13, 2013 05:34 PM
Discussion 20 To 25 cell lipo set up for ducted fan propulsion? HURRICANE FANS Power Systems 2 Jan 07, 2013 09:30 PM
