This thread is privately moderated by Jyester, who may elect to delete unwanted replies.
Jan 16, 2013, 08:51 PM
Jyester
Jyester's Avatar
first time canard
This past week i've been building from scratch a canard plane. I have always found them to been interesting and unique. So i started out with the main wing. I wanted to keep this plane small and lite weight, as well as able to operate with a AR6400 brick and possibly 2 aileron servos. To operate the elevator out front i will position the brick vertically and place it on the right hand side of the fuse. Looking for a AUW of 30grms with battery. Glide test with 2 pennies have shown me alot and i have figured out that i have to place the brick mid-fuse and battery up front. Motor is mounted in the rear of the plane in a pusher configuration. Weight dry just plane 14.9 grams. Think after i cut some holes into the wing it will bring the weight down by 2grams or more. I used 6mm aerocell 6mm epp and 3mm depron. the epp i used for the canard clued to that is the 3mm spline that runs aft and is part of the motor mount. I also used 3mm for the elevator halves. The main wing and the fuse side are 6mm aerocell. The bottom i will cover with 3mm epp its lite weight and use it for the strip ailerons. Alone its very flexible but joined with tape to a more rigid surface and it stiffens up nicely. I posted some pics along with this entry to give you an idea of size, ws14"3/4 fuse 9'' long 2" wide at the wing tapering to point at the front of fuse. Also the wing is held on with magnets as you will see in pics. will up date regularly as i progress to the first flight. Fly high, Fly fast and crash pretty
Jan 17, 2013, 12:16 AM
Flutter-Bys are fun
Conehead's Avatar
Have you thought about posting this on the Canard Forum under electric planes?
Looks very nice.
Conehead
Orrin Eldred
Link added
https://www.rcgroups.com/forums/show...6#post23808570
Discussion Long Time RC Flyer, First Time FPV'er. daubut FPV Talk 57 May 01, 2014 12:44 PM
Help! Long time viewer, first time poster. Need help with my KKboard Quad... IBeHoey Multirotor Drone Talk 5 Sep 24, 2012 03:11 PM
Discussion My first time "surfing the wind" BrunoD Slope 11 Mar 02, 2012 09:16 AM
Discussion Flying for the First Time: a Question on Control rkenosha Aerial Photography 2 Feb 23, 2012 09:28 PM
