Jan 14, 2013, 09:48 AM
stemo99's Avatar
Do all radios center servos the same
I am programming my DX7 with my programs I have in my DX6i's. I made sure all the program fields are identical ( trims, sub trims, mixes, duel rates and expo etc). When bound, to the DX6i, all control surfaces are perfectly aligned with their respective trailing edges. When I bind the DX7 with the exact same program to the same plane, the surfaces are a bit off, maybe 2 or 3 clicks of trim one way or another. Is this normal? They are not way off but I thought it odd that they weren't the same. Your help is appreciated.
Steve
Jan 14, 2013, 09:59 AM
Surface, Air & Water Rc Toys..
Nope, the difference between my DX8 and DX18 is visible during buddy box / trainer. You can see the change on the servo monitor when the controls are given to the DX8.
Channel pulse for example use 900ms to 2100ms for one end to the other with 1500ms being center, due to variances in pots and what ever you could have radio that center is 1515ms or 1490ms. This would show up when you have a second radio with these values slightly different. In other words VERY NORMAL.
Jan 14, 2013, 10:00 AM
68 years an RC flyer
Daedalus66's Avatar
Steve
Servos don't have a neutral (you probably realize this). They simply go where they are told by the transmitter, via the receiver. So any issues you are having occur at the transmitter. It is likely that the calibration of the two transmitters may be very slightly different (though in my experience Spektrum transmitters are quite accurately calibrated).
To test this, set up a blank model on each transmitter, do a data reset to make sure they are truly blank, and then use each transmitter in turn to drive the same plane. You will quickly see any differences.
A slight variation in calibration is no big deal. All you need to do is note the subtrim adjustment needed for each channel to make it the same as the other transmitter, then apply those amount when setting up a new model or adjusting your current ones.
Question How do I find a servos "center" without using a radio? Kevinfred Electric Plane Talk 14 Jul 26, 2012 05:37 PM
Discussion V911 not all the same but all excellent !! dankar04 Micro Helis 0 Jul 11, 2012 12:55 PM
Help! Aileron Servo not centering at the same position from both directions Bosk The Builders Workshop 13 Jan 10, 2010 02:30 AM
Discussion Do all servo's have the same throw range? lacofdfireman Radios 4 Nov 05, 2009 08:04 AM
Discussion EDF retailers, do all websites offer the same planes from the same manufacturer? f41stryker Electric Ducted Fan Jet Talk 6 Sep 14, 2008 10:10 PM
