Jan 12, 2013, 11:29 AM
flypaper 2's Avatar
If your radio has servo reversing, reverse the #3 channel.
Gord
Jan 12, 2013, 11:31 AM
Hobby King Hater
Kimber's Avatar
Originally Posted by Miniclip12
how to reverse the throttle
Not positive, but there may be a panel behind the battery?
Jan 12, 2013, 11:42 AM
I dont have servo reversing, and there is no panel behind the battery
Jan 12, 2013, 11:50 AM
Hobby King Hater
Kimber's Avatar
Here is a video as to how to do servo reversing. You plug it in
your computer to do it, it tells all about it.
FlySky Fly Sky CT6B 2.4GHz 6ch RC TX/RX Transmitter & Receiver Review (11 min 32 sec)
Jan 12, 2013, 11:51 AM
No bounce, No play.
davidmc36's Avatar
You can probably do servo reversing of that radio with firmware.
https://www.rcgroups.com/forums/show....php?t=1390731
Jan 12, 2013, 12:09 PM
Thanks! ill try these
Jan 12, 2013, 01:04 PM
Retired in NC
Rich in ILM's Avatar
The transmitter has reverse settings for all controls.
Jan 12, 2013, 04:26 PM
E-Challenged's Avatar
The black wire on speed control and servos connectors should be closest to the receiver's circuit board, red wire in middle, yellow or white signal wire farthest from circuit board. The connector from the speed control normally plugs into channel 3 or whatever channel is marked "throttle". Turn on your transmitter first, then power up your receiver ( connect motor battery). Check for broken wire at battery and speed control connector. Are all three wires connected to the brushless motor properly?
Jan 12, 2013, 04:47 PM
yes everything is as you said
Jan 12, 2013, 07:29 PM
Hobby King Hater
Kimber's Avatar
One last thing? Is your battery charged? Most ESC's have a low
voltage cutoff for the motor, but the servos still work. Failsafe.
Jan 12, 2013, 07:39 PM
I have a 3300 mah 3s 20-40c lipo and I put it in storage mode because Im scared it will swell up. Will this matter?
Jan 12, 2013, 07:50 PM
Hobby King Hater
Kimber's Avatar
It might, depending on the ESC, it should be charged for testing.
Jan 12, 2013, 11:34 PM
I'll fully charge it tomorrow and see if that was the matter
Jan 12, 2013, 11:51 PM
rrg
rrg
rrg's Avatar
Is you esc armed? With throttle down plug everything in, wait till it beeps. Then push throttle all the way up, beeps again then throttle back down. That might work. As said, with prop off of the plane.......
Jan 15, 2013, 04:07 PM
That was it! I cant belive I forgot to let the esc arm! now it works! Thank YOU everyone who posted! I really appreciate it
Discussion RC tug Southampton + Spektrum Receiver (ESC not working) fy789 Scale Boats 16 Oct 07, 2012 10:08 PM
Alert Throttle not working Sach Batteries and Chargers 8 Jul 24, 2012 03:51 PM
Discussion My plane will not work... GUSTAV6 Electric Plane Talk 9 Apr 13, 2012 03:02 PM
Question Weird problem with New Y-6... Throttle works, but not Pitch Roll or Yaw Adidas4275 Aerial Photography 4 Apr 02, 2012 11:21 AM
Help! 2 different planes, not getting any throttle ? fltekdiver Power Systems 3 Mar 08, 2012 08:16 PM
