Jan 11, 2013, 10:15 PM
Help!
RC plane throttle not working
Ok, I am a newbie, so something I say might be dumb. I have scratchbuilt a plane, all the servos are working, but when I put the throttle up, nothing happens. Please Help!
Jan 11, 2013, 10:51 PM
Hobby King Hater
Kimber's Avatar
More details, brands of motor, esc, radio. Pictures??
Jan 11, 2013, 11:05 PM
here is my setup:
exeed rc optima 1800kv brushless motor
30a proton esc
4 9g servo (brand not listed)
6 ch rx/tx flysky
also here are some pics:https://www.rcgroups.com/forums/show...2&d=1357963474
Jan 11, 2013, 11:21 PM
Hobby King Hater
Kimber's Avatar
You did plug the esc in channel three with the brown, black wire to
the out side of the rec?
Jan 11, 2013, 11:23 PM
Is your throttle the left or right stick?
Make sure its all the way down before powering up.
Jan 11, 2013, 11:25 PM
My throttle stick is the left stick, and I did put the black wire on the outside
Jan 11, 2013, 11:28 PM
Your right stick looks broken then. It should be centered while resting.
Jan 11, 2013, 11:30 PM
whoops i looked closer.
your picture is a mirror image. the words are backwards.
maybe check the throttle trim settings. make sure to power up with the throttle alllllll the way down.
Jan 11, 2013, 11:54 PM
I tried all of that but nothing seems to work
Jan 12, 2013, 12:20 AM
Hobby King Hater
Kimber's Avatar
The esc is plugged in to channel 3 and not the battery
spot?
Jan 12, 2013, 01:48 AM
AMA 667982 KG7NKY
starcad's Avatar
Corrected the image it was mirrored. As Kimber asked, The esc is it plugged in to channel 3 and not the battery
spot?
Jan 12, 2013, 03:05 AM
Retired in NC
Rich in ILM's Avatar
Take the prop off.
Turn on your radio and push the throttle all the way up.
Connect the battery to your plane.
As soon as you hear 2 beeps close the throttle all the way.
If that works you are in business, if not, reverse the throttle and do he above again.
Jan 12, 2013, 08:14 AM
flypaper 2's Avatar
Another thing you might try is, put the throttle trim all the way to the bottom.
Gord.
Jan 12, 2013, 10:54 AM
my esc is plugged into ch 3, and I will try taking the prop off and do that procedure
Jan 12, 2013, 11:13 AM
how to reverse the throttle
Discussion RC tug Southampton + Spektrum Receiver (ESC not working) fy789 Scale Boats 16 Oct 07, 2012 10:08 PM
Alert Throttle not working Sach Batteries and Chargers 8 Jul 24, 2012 03:51 PM
Discussion My plane will not work... GUSTAV6 Electric Plane Talk 9 Apr 13, 2012 03:02 PM
Question Weird problem with New Y-6... Throttle works, but not Pitch Roll or Yaw Adidas4275 Aerial Photography 4 Apr 02, 2012 11:21 AM
Help! 2 different planes, not getting any throttle ? fltekdiver Power Systems 3 Mar 08, 2012 08:16 PM
