Jan 10, 2013, 06:16 PM
ir3
ir3
Assembling WTC Nose Cone
Hi Submariners,
I have a problem installing the WTC nose cone in the Engel Type VIIC. There are two brass screws that go through bulkhead R5. I can get the spacer, washer and nut on the top screw but I find it almost impossible to get the nut on the bottom screw. I did manage to get the spacer and washer in place but I do not have the tools to get the nut in place. A 1/4" socket does not fit, there is not enough clearance between the nut and the fiberglass hull to get the socket in place. I am almost tempted to consider the top nut and spacer will be sufficient to hold the nose cone in place but it would be nice to bolt it at both the top and bottom.
Any suggestions?
IR3
Jan 12, 2013, 02:31 PM
profesorul's Avatar
HI,
A picture it is possible?.It will be more easy.
Jan 28, 2013, 11:35 AM
ir3
ir3
Finally attached lower nose cone bolt
With the use of a magnet on the end of a flexible shaft, an 8mm box wrench, a small hammer and screwdriver I was able to get the nut and washer on and with the box wrench, I could move the nut just enough to start tightening it and with the long screw driver and hammer I could tap the nut to tighten. Took about 10 minutes but it now secure. With the buildup of fiberglass in that area it was just impossible to get any kind of 8mm socket on the nut.
Now on to the next frustration.
IR3
Jan 29, 2013, 04:55 PM
Horseman's Avatar
Originally Posted by profesorul
HI,
IR2 means this tread at the left side of the photo,
I was able to get the nut on but its indeed a struggle to tighten it
Its not the only difficulty on this kit,
Good job IR2
Regards from Holland,
Jan,
Jan 29, 2013, 06:10 PM
ir3
ir3
WTC Nose Cone
Hi Jan,
You are absolutely right about not the only problem. I see that you have started to post to your thread again. Good news. I will be following closely.
I put the old battery pack back in. I didn't want to do it since I think I have a weak cell in one of the 10 cell sections but I should be able to run the boat for a while until a fix comes in for the newer pack. The new battery pack either had the wrong size adapters for the early Type VIIC or he designed new battery pack bulkheads for the tech rack. I did send an email about this to Engel but received no response. Coincidentally, the new battery pack and the sub kit itself are suddenly not available. I wonder if they see the error and are working to fix it.
Cheers,
Iran
Jan 30, 2013, 05:35 AM
Horseman's Avatar
Hi Iran,
Yes I did start the tread again but I can tell you that I do not use the battery's Engel suggested, because I want to use Lipo's and therefore I had have to make a complete new battery section, but that will be explained in my build.
Then the response of Engel, well I hear more from guys from the states that he not respond on his e-mail and I can not find a reason for that behavior because I met him last year and his English are a lot better than mine, so thats not the problem.
I have no clue
So we need forums like this to help and learn from each other
You may know I was a very long time completely done with this kit and mainly caused by making the flood-holes. Its not normal for this amount of money to do that much of brainwashing repeating work, however I know that when I purchased the kit but it was no fun anymore at the end.
However she looks very nice now.
So the work has pays off well .
Regards,
Jan,
Wanted Acacia 2 nose cone RCRod Aircraft - Sailplanes (FS/W) 3 Apr 15, 2012 07:46 PM
Sold Icon 2 Spare Stab and Nose Cone pmccleave Aircraft - Sailplanes (FS/W) 3 Apr 12, 2012 10:27 PM
Wanted Blaster 3 Nose Cone Mr. Wiz Aircraft - Sailplanes (FS/W) 1 Feb 29, 2012 12:26 PM
Wanted Big Bird nose cone Swoopdown Aircraft - Sailplanes (FS/W) 4 Feb 28, 2012 01:40 AM
Wanted AVA E-Nose Cone Luis Moya Aircraft - Sailplanes (FS/W) 0 Feb 23, 2012 11:15 AM
