Jan 10, 2013, 02:25 AM
HK Radjet 800 problems
Hi guys - not sure I am posting in the right place, so apologies if Im not. I didnt want to hikacj someone elses post either, hence the new one.
I have the radjet 800, but its never managed to get more than 10 metres. Im running stock setup, no expo on ail / elev. Turnigy 1300 3s battery. I launch at full throttle full up elevator and it barely maintains level flight. Prop spins right way and I have tried turning it around. I bench tested it last night and its pulling just over 13amps with stock prop, is that right ?
I just do not know what to try, I have moved battery back as per other posts in here and COG is similar to others who manage to fly it...
Can anybody help ?
Jan 10, 2013, 05:30 AM
Ok providing the prop is on the right way around it should fly. Those amps sound about right to me. With mine I launched full throttle, give it a nice hard level throw and you should not need any elevator I would guess full up elevator is just stalling it out. My cg is just at the front of finger holes. Hope that helps
Jan 10, 2013, 06:31 AM
Hi - Yes mine is about 5mm to the front of those. Is COG particularly important on a pusher ?
The plane doesnt stall as such, but just will not lift. Servo horns are on second hole form the lowermost for the rod to attach to.
Jan 10, 2013, 09:05 PM
Got a picture of the motor/prop you can post?
Jan 11, 2013, 04:30 PM
Hi Yep sorry, couldnt find the cable !!
Description:
Jan 11, 2013, 04:44 PM
lol,,,if thats the front then your sweet!
Jan 11, 2013, 09:50 PM
Prop's on backwards.
Jan 11, 2013, 09:53 PM
3d Master in Training
Mine flew good for about 20 packs till the elevon came detached and caused it to come in at full power uncontrollably into some trees. The foam hinges are junk
Jan 12, 2013, 06:40 AM
Hey - OK will change that around, but I have flown it both ways
Might try launching backwards hehe
Jan 12, 2013, 09:23 AM
DJO
DJO
"Yo, that's a thermal"
DJO's Avatar
Yes CG is sooooo important. I'd say that you need to get yours farther back! Once you do that you shouldn't have any more issues!
Dan
Jan 14, 2013, 02:06 AM
Dan
Dan - Its as far back as it will go without cutting foam out, do you normally have to cut the foam out of them ?
Flew it for the first time this weekend, first flight went really well, but not much elevator, so changed it to 125 % throw and think I bust a servo. It suddenly got stuck in a WTO left hand spin, which didnt end nicely.
Stuck her all back together, but might order another one, as its fairly well busted
Thanks for all your help guys
Jan 14, 2013, 06:15 AM
DJO
DJO
DJO's Avatar
Maybe one my my servos got stuck... I was on 125% too, hmmm that's what it could've been in my video. And yes I had to cut quite a bit of foam out of the back of the fuselage to get the CG right, even with a few coins on the back! Oh well, it flies nicely though
Dan
Jan 14, 2013, 07:31 AM
Dan
Bit tricky as moving the rod down the servo horn moves it nearer the foam and is more likely to catch....
I think thats what it is, I will test it tonight and see how close it is to the wing when on full elevator.
OK - I will push the battery a little more to the rear, it looks simple enough but as mine was pre assembled its hard to get into that part of the fuse.
Dec 05, 2013, 01:12 PM
wga22's Avatar
I have indeed had to cut foam, and push 1300mah batteries pretty far in to get CG good. even still it feels nose heavy.
takeoff almost certainly requires WOT and lots of up elevator.
Dec 30, 2013, 02:45 PM
Keeping them out of the dirt!!
edwinkania's Avatar
RE check everything I have been flying my Radjet two seasons bonestock and love it great plane, fast too.
Discussion Radjet 800 motor help kamoflarj Foamies (Kits) 1 Jul 18, 2012 10:14 AM
Discussion New Radjet 800 setup kamoflarj Flying Wings 0 Jul 17, 2012 08:22 AM
Wanted Wtb hk radjet/hk f-86 lectroglide Aircraft - Electric - Jets (FS/W) 0 Mar 29, 2012 03:36 PM
For Sale Hobbyking Radjet 800 EPO 800mm (PNF) - LPU - Orange County, CA Triptykon Aircraft - Electric - Airplanes (FS/W) 4 Mar 20, 2012 04:56 PM
Discussion anyone flying Hobbyking's Radjet 800? Bjp Electric Plane Talk 3 Mar 01, 2012 06:51 PM
