1S charging lead
So I have this charging lead for three 1S Lipos. I am using a Triton charger and also have a Equinox balancer. Do I connect to the balancer plug with the Equinox or JST plug by itself? Do I charge as a 1S or 3S battery? Do I add up the total milliamps of all three batteries or do I charge at just the milliamps of one battery? Do I even need the Equinox balancer connected? Do I charge at over 1C if batteries can handle it? Any help would be greatly appreciated. Thanks!
That one will require three 1S batteries connected at the same time, it is called in Series, AND the red JST main lead plugged in too.
Basically the same as charging a 3S pack and you may have to convert the red connector to fit your charge lead of your charger. Rick |
So I charge it as 3S battery at the capacity of one battery or capacity of all three?
If I am correct you would charge as a 1S battery. You would add the milliamps of the batteries connected. You may or may not need the balance connector. That would depend on your charger. But I think probably not. You can charge at whatever C rate your batteries and charger can handle. However I personally would not use the equipment you have. There are very good and relatively inexpensive chargers available with the balancer built in. In my opinion now is a good time to upgrade to newer equipment. Glen |
The image shows 4 wires. The two middle wires are white on a white background. Click on image and then again on image to view full sized. It is a JST-XH 4 pin connector with 4 wires in it.
I stand behind my original post but unless the OP opens up the shrink or links to where he/she bought the harness we will not know for sure. Rick |
Thanks Rick. I knew it was a 4 pin connector but just could not see the wires in the middle.
Glen |
So, I can charge through the JST connector without balancing or charge through the balancing tap with my equinox/3S charge plug/Triton?
Then, is the milliamps per cell or total of all three cells combined? Thanks Guys! Pete |
For example: three 1S 150mah batteries the voltage is 12.6 and the charge current is 150ma. Glen |
Thread Tools | |
Similar Threads | |||||
Wanted | Charge adapters to charge 1s 200mah Eflite batteries in parallel | MolokaiBoy | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Aug 15, 2012 09:36 PM |
EOS 0606I parallel charging 1s batteries, will not charge fully have to restart over | mescalinedream | Batteries and Chargers | 5 | Apr 25, 2012 02:12 PM | |
For Sale | Blade mCP X 6X Parallel Charge Lead | motorbro1470 | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Feb 26, 2012 10:51 PM |
Sold | 3s balance charge lead for 1s packs | ohsnap | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Feb 10, 2011 08:39 AM |
For Sale | Special sale!! multi charge lead and ec3 charge lead | taildragger21 | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Feb 07, 2011 09:34 PM |
