Jan 07, 2013, 01:46 AM
old4570's Avatar
Mini-Review
Dual Push tail rotor [ Ebay ]
Got a dual push tail rotor from icemodel2009
One of these : http://www.ebay.com/itm/New-dual-pus...item41693646ee
Now the dual push assembly costs $ , and overall I thought it cheaper to buy an entire Tail rotor assembly ..
I havent used this one as yet , just consider it a very close examination ..
Over all it seems fairly good , the dual push assembly has minimal play , and the only complaint for the assembly is the tail rotor shaft play . There is an excessive amount of it , that would most likely result in tail rotor vibration .
After dis assembly , I found the bearings to be good , but the bearing housings in the side panels [ assemblies ] to be oversize . The the play was the bearing moving in the housing .. There is a spreader bar at the very end , I shortened this a little , and it helped to tighten up the tail rotor , to much and the bearings would be a crush fit , and destroy themselves in short order .
The cure would be to remove the slop fit in the housing ..
But I was able to halve the play ..
Overall a very nice tail rotor , just a shame about the oversize bearing housings .
If the bearing housing issue was fixed , this would be a brilliant upgrade for the money , but as is , I rate this Buyer Beware !
As time permits , I will swap this tail rotor assembly into one of my 450's and see if it has vibration issues ..
For Sale Tail Control Guide for T-rex 600,550 Tail Push Rod (Blue) ucusclub Aircraft - Fuel - Helis (FS/W) 3 Jul 25, 2012 06:15 AM
For Sale Metal Tail Control Guide for T-rex 700 , Tail Push Rod ucusclub Aircraft - Electric - Helis (FS/W) 0 Apr 09, 2012 03:20 AM
Mini-HowTo Mod:DIY a dual push tail pitch control for Trex. iceman33 Mini Helis 11 Sep 19, 2007 11:39 PM
Discussion dual FP tail rotors ? not motors.. ROTORS! PLATINUM Micro Helis 11 Jul 06, 2007 07:13 PM
