Jul 07, 2013, 09:42 PM
There is a lot of good information in this thread about this engine; ways around the goofy ignition curve, tuning, etc.
http://www.theprofilebrotherhood.com...hp?f=2&t=31620
I can't thank you enough for posting about the range problem. I did a range check with my Spektrum. I should be able to get 30 meters out of my radio on the range check mode. I wasn't getting 15. With the engine off, it passed. That ain't good. I'll be reading your thread in detail to see what I can pick up.
Honestly, I think it's a lesser receiver I'm using. I had borrowed a receiver out of an electric plane while I was waiting on the one I ordered to come in. Now I'm 800 miles from home on vacation and the nearest hobby shop is 100 miles away.
Thanks again. This likely saved a crash.
Jul 07, 2013, 10:15 PM
team sleprock
whiskykid's Avatar
that's what it is all about, that's great you saved your plane, sounds like it is gonna "rock,"when you do get the bugs worked out!
oh and P.s. someone posted a sweet video on timing these lil 2 strokes, I think I have it some where!
Jul 07, 2013, 10:22 PM
I'm on a similar path. I'm trying to get the plane up and running to see if I like the airframe. If I like it, I'm going to strip it and recover with a different scheme. I might mod some surfaces as well.
Jul 07, 2013, 10:24 PM
team sleprock
whiskykid's Avatar
oh and the first thing I would do, is if it's not now, then mount your ignition battery, on the engine box, as far away from any other radio gear as possible! I found that the battery gives off the most interference!
Jul 08, 2013, 08:03 AM
I use lipos and regulators on everything. I know there is a lot of debate on the subject of batteries. Personally, I trust lipos more because I can do a voltage check and see how much I have left. With life and nihm the voltage stays about the same through the charge, then it drops.
I use separate regulators off the same battery. I've had an electrical engineer friend checked that setup on my other plane with an oscilloscope. It created minimal interference. However, I'm not using the same regulators and I have capacitor on my other plane.
Jul 08, 2013, 10:17 AM
team sleprock
whiskykid's Avatar
I just lost my 27% EXTRA 260, because of what looks too be, a faulty castle voltage regulator! was my first attempt at using lipo's as my flight pack! was unable too check voltage in the lipo after crash, but with a 6v nimh and a 4.8 NiCad, the receiver was fine, but with the castle, neither would keep the receiver powerd!
and almost lost my E-Flite EXTRA 260 yesterday, with a life battery, do too what I figure was over voltage! don't think them EXI 9 gram mg digital servo's are rated for 6v's!
luckily it pancaked, and only broke the rib where it bolts too fuse. did a field repair, and tried again, only too completely loose all my servo's, so gonna hafta try again on that one!
just more reasons too stick with what works! it really is hard too teach this old dog new tricks!
Jul 08, 2013, 12:39 PM
I called Horizon Hobby this morning. They gave some good advice. One suggestion was get the ignition battery away from the receiver (same thing you suggested).
I also called my EE buddy. He suggested a .1mf and 470mf capacitor before the receiver to clean up any spikes.
Jul 08, 2013, 03:23 PM
team sleprock
whiskykid's Avatar
right now I am running a 1700ma life battery in my 1/4 scale Pitts, with a 1600ma nimh for my ignition!
I have them both sitting side by side above the main gear, and haven't had any issues yet, but as mentioned earlier, my ignition box is as far away from the receiver as physically possible! and I just make sure the wries are on opposite sides of the plane!
Discussion H9 Katana 50 power options - need more power! SEMiller 3D / Fun Fly Fuel Planes 1 Jun 08, 2012 08:41 PM
Question How do I get more power out of my Wing? Please read Bonestockz06 Foamies (Scratchbuilt) 11 Apr 27, 2012 11:31 AM
Discussion More Disgusting Consequences From Democrats Being in Power Highflight Life, The Universe, and Politics 89 Mar 19, 2012 04:33 PM
Discussion MORE POWER! I need more power! Hepdog Pusher Prop Jet Models 42 Aug 30, 2010 10:02 PM
More Power! More Power!! Little Black Duck Electric Sailplanes 9 Dec 27, 2002 06:44 AM
