Jan 02, 2013, 10:13 PM
trimble95's Avatar
Help!
Evolution .46 trainer keeps dying
Hello!
I have the Alpha 40 Trainer RTF that has the Evolution .46 Trainer engine and without any hesitation at all it completely just shuts off after about 10 seconds after start. The fuel line that runs from the mixture adjustment knob to the carburetor seems to have plenty of fuel going through it, even after it shuts off. Put brand new fuel in the tank and the problem still exists. Could this be a glow plug related issue? It starts beautifully, but after a few seconds it just shuts right off. Any ideas? Thanks
Jan 02, 2013, 10:31 PM
Gas Only
Fokker DII's Avatar
Sounds way too lean. Like it runs out the prime then dies. Start over with the needle setting. If you don't have the manual begin at 1 1/2 turns open. It should run from there.
IF it quits only when you remove the glow ignitor then it is a bad glow plug.
Jan 02, 2013, 10:35 PM
trimble95's Avatar
Ok I will try that tomorrow. She runs fine once the glow plug igniter is removed so it must be to lean! Thanks a lot
Jan 03, 2013, 09:47 AM
DarZeelon's Avatar
If an engine keeps running with the glow-ignitor connected, yet shuts down when it is removed; it is too rich on the low-end.
Your trainer engine has limiters on both the high-speed needle (it is not a knob!); and on the low-speed needle.
The low-speed needle is in the center of the throttle arm. Its proper adjustment is crucial, since it controls the behavior of your engine from idle through ~75% throttle.
The high-speed needle only controls the engine's top-end and has virtually no effect at part-throttle settings (unless it is closed way too far).
If the low-speed needle is too open (i.e. the setting is too rich), it may need the ignitor to run, will load-up with excess fuel and stumble sputtering when the throttle is advanced.
Jan 03, 2013, 03:56 PM
trimble95's Avatar
Thank you, I will mess around with it!
Jan 03, 2013, 06:32 PM
fiery's Avatar
Hotter plug and richer main needle setting.
Re-tune and fly.
I assume obvious culprits (air leaks, pinholes in fuel tubing, compression leaks) have been checked and eliminated.
Sold Evolution .46 Trainer System NIB Alien_Tech Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 24, 2012 03:19 PM
Sold Evolution .46 Alpha trainer engine, $40 wing881 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 07, 2012 06:09 PM
Help! Evolution Trainer Power System dies in flight themadhatter196 Engines 7 Jun 06, 2011 07:19 PM
Discussion Evolution .46 dies at full throttle rc2xs Engines 7 Dec 29, 2008 06:21 PM
Sold Evolution Trainer Power System (.46) Nate129 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 06, 2005 06:56 PM
