Aug 30, 2014, 01:56 AM
If I build it, it will fly
Originally Posted by Heli Pad View Post
D'oh! That's terrible (storing at full charge). Who's the seller?
Amazon - Seattle Puzzles. Since they are drop shipped from a China supplier it isn't really their fault.... but be ware, the standard shipping is listed as 17-28days (which I didn't notice). They are drop shipped from china, the supplier is the naughty one.
I'm hoping that round two will show better flight times. If not there will be much diplomatic dispute between S.P. & myself.
~psguardian
Aug 30, 2014, 08:32 AM
Childlike Activity for Adults
jbrumberg's Avatar
2.5 - 4 minutes/battery is poor.
Good luck with round two psguardian. I hope that you get better flight times.
JB
Aug 30, 2014, 10:55 AM
Against Helicopter Cruelty
Heli Pad's Avatar
Can't wait to hear back from ya, PSG. Round 2.
Aug 30, 2014, 11:19 AM
That picture really sparks my patriotism.
Aug 30, 2014, 11:49 AM
jbrumberg's Avatar
I bet that pic can charge a "battery" or two as well
A fine example of physical fitness
JB
Aug 30, 2014, 06:10 PM
Quoth the raven, "Nevermore"
Originally Posted by Jmel View Post
I do have video on the cams original usb cable but not on the one I made... 4 and 5 you say? Can you show me?
How's this?
Aug 30, 2014, 06:56 PM
~psguardian
I retract my previous statements about Seattle Puzzle & the drop ship supplier they use.
The wall charger I got from 'Super Power Supply' is to blame. It has a faulty connection within the wall-wart is faulty, Tapping the wal-wart makes/breaks the connection to the battery & changes the led color.
One battery that honestly got a full charge few full play ground aerobatics for 7min.
I am now using my Turnigy Accucell 6 to charge each of the new packs on a known good charger.
I am waiting on an RMA.
~psguardian
Aug 30, 2014, 08:26 PM
s'like freakin' NASA in there.
Jmel's Avatar
Originally Posted by Rob215 View Post
How's this?
Thanks man. Any chance I could see the usb connector with the black and yellow cable close up? Just to be able to see how those were soldered? Trying to figure out where the 2 in 1 ground connection takes place. Also do you have the switch settings on the rc305/channel frequency? This is a HUGE help... thanks so much.
Aug 30, 2014, 11:53 PM
Well, it wouldn't do much good to show the USB connector up close because its completely covered in a blob of glue. But since pins 4 and 5 are right next to each other, I just run the stripped end of the black wire across both pins and solder them all together. =)
On my RC305, switches 1,2,3 are up and 4 is down, so its set to channel 1 according to the diagram on the RC305.
Aug 31, 2014, 12:45 AM
I made some improvements to my diagram...
Aug 31, 2014, 10:32 AM
Jmel's Avatar
Thanks. I think I have a different style usb connector... Mine has 3 pins on the bottom, and 2 up top.
Like this: http://forum.flitetest.com/showthrea...ll=1#post91434
And judging by this diagram here:
https://www.rcgroups.com/forums/show...ostcount=16522
I was using the wrong pinout... Looks like for MY usb plug, I'd have to have it like this...
with the plug end that goes into the camera facing AWAY as in the first link, I'd have ground going to the first bottom and first top pins on the left, and then video on the 2nd pin up top.
Description:
Aug 31, 2014, 05:57 PM
Attachment 7062272
Yes, your picture looks correct! That IS how you should wire it =)
I posted a newer version of my diagram, specifying that I'm showing the REAR view of the USB plug. Its really the same pinout, except your USB plug has those nice, staggered tabs that are easier to solder to. I have some of those for future projects.
Aug 31, 2014, 08:10 PM
Jmel's Avatar
Thanks for the info. I wish I would have paid closer attention to what was out on the web before following that diagram I first went from... I have another tx that should be here in a week or two. I think mine is salvageable, but the voltage regulator (or whatever it is) has a dimple in it. I'm sure it's toast. It's too tiny for me to solder. I think having it wired up wrong caused some stray voltage to go down the wrong pins. At least the cam still works.
Sep 01, 2014, 03:46 AM
dragonblade's Avatar
Ive just received my third Syma X1. The first one was defective and had to be sent back. The second one flew off out of sight after only having it for a week. Hopefully, I'll have more positive and long lasting experiences with this one.
Sep 01, 2014, 04:12 AM
Good luck!
Discussion Syma 2012 new publish, syma X1, S800G, S107C,S036G,what's better wjh041 Coaxial Helicopters 9 Jun 20, 2013 03:07 AM
New Product Syma X1 Quadcopter Spare Parts wjh041 Beginner Training Area (Aircraft-Electric) 1 Nov 03, 2012 05:55 PM
