This thread is privately moderated by AussieHoppy, who may elect to delete unwanted replies.
Dec 23, 2012, 03:08 AM
what goes up, must come down..
AussieHoppy's Avatar
Pan & Tilt setups
Pan & Tilt setups
I've had a lot of peeps asking how I set up my P&T's, here's a handful of the many...
I use hot glue a lot, but please be aware I do not use the cheap art/hobby hot melt glue gun.
I use Bosch hot glue gun and genuine Bosch hot glue sticks.
Bosch hot glue not only is hotter, but it literally adheres better and is very resilient to hot summer sun.
The quality is night and day.
The Hitec servos are modded to rotate 180 degrees.
The difference in quality between the Henge type 260 degree servos is very obvious in the goggles, the cheap Henge servo steps with slow head tracker movements, where-as the Hitec servos are very smooth, no matter how slow the tracker movement registered.
ARC/ Thunder Tiger 1500mm Jupiter
~ Runcam Swift mini CCD cam, stock supplied camera bracket used for tilt.
~ Hitec HS5055MG tilt servo
~ Hitec HS225MG pan servo
ANZAC Day 2018 "Jupiter in Motion" to classical piano [scale fpv] (4 min 43 sec)
Hobbyking 1/8 electric Buggy
I needed something that was as sturdy a set up as possible while ground pounding. I bought the pan setup from ServoCity. Works very well.
~ SN555 cam, aircraft control horns used for tilt brackets mounted on ally plate.
~ Hitec MG pan servo
~ Hitec MG tilt servo
Boobs n buggy! XB Trailblazer (14 min 46 sec)
FMS 1450mm P-51
Formation Practise scale fpv cockpit 05082018 (10 min 53 sec)
FMS 1500mm P-47 Razorback
~ DJI HD Ocusync, stock supplied camera bracket used for tilt.
https://www.youtube.com/watch?v=1JBCkuc6u4M
Freewing 1200mm CTLS
CTLS and J-3 Cub Bay Play .1. scale fpv March 2019 (17 min 29 sec)
Hobbyking 1500mm Bixler
~ Surveilzone CCD cam, DuBro control surface flat pinned hinge bastardised for tilt.
~ Henge 260 degree pan servo
Flying Fun Dec, Cub, & Bix's 25062017 (6 min 26 sec)
Taft Hobby 90mm edf Viper Jet
~ Random CCD cam
~ Henge 260 degree pan servo (too cool looking back to the swept wings lol)
Taft Hobby Viper fpv maiden 15122016 (9 min 26 sec)
X-UAV 1800mm Decathlon
~ SN555 cam
FPV what I did today 05082018 (7 min 11 sec)
Sold Scorpion Y650 folding frame Y6 kit with camera Gimble $90.00 shipped Chad2323 Aircraft - Electric - Multirotor (FS/W) 0 Jun 19, 2012 03:16 PM
Sold Scorpion Y650 folding frame Y6 kit with camera Gimble $100.00 shipped Chad2323 Aircraft - Electric - Multirotor (FS/W) 0 Jun 14, 2012 02:23 PM
Wanted landing gear and camera gimble for up to 9lbs hexa ROCKY2 Aircraft - Electric - Multirotor (FS/W) 1 May 27, 2012 02:22 PM
For Sale XAiarcraft CM130C-TPS Camera Gimble Fotophanatic Aircraft - Electric - Multirotor (FS/W) 1 May 22, 2012 09:23 AM
Question Camera Gimble/Yaw Fastlane66 Aerial Photography 2 Apr 01, 2012 12:08 AM
