Dec 20, 2012, 01:03 AM
Good Better Best quest.
olmod's Avatar
Hobby King big stick
Just recieved today ,parts quality good, a few tags need cutting that the laser missed but no problems, should make up into a nice lightweight . https://www.hobbyking.com/hobbyking/s...dProduct=29648
Dec 20, 2012, 05:47 AM
Fugbucker's Avatar
Looks like fun... Nice to see some one else uses 123 blocks.... I use them every chance I get... Wish I could afford some more...
Dec 20, 2012, 11:08 PM
olmod's Avatar
A nail board or small file is handy to clear notches, you must check each piece against the parts pix and label them ,some are a bit obscure,once I got into the wing ribs I found plenty of cuts to be made, good quality wood tho'.
Dec 21, 2012, 08:45 PM
I am a sucker for some kits to go on the shelf for a rainy day, and the price is right for these. Bought 3 -should be enough parts to keep two flying for many years.
As the grandkids get interested in flying models, they are great to give em and show em how to build and fly.
Dec 22, 2012, 12:03 AM
olmod's Avatar
There are a couple of puzling things with this kit .like you build the wing panels but there does not seem to be any provision for joining the 2 halves together ie joiners ect. so I have improvised a plywood brace for the main spar .
Dec 22, 2012, 01:08 AM
Wouldn't be a hk kit if you didn't have to work it out for yourself. Usually the 'plans' are close but not quite right for the bits.
The ministik kit was an exercise in establishing the best way to build it using the plans as a guide only. Doubt it was even for the same plane!
Dec 22, 2012, 06:33 AM
olmod's Avatar
Must admit I have had my share of adventure builds up to the stage of how the @%$#t do the allerons go together
Dec 22, 2012, 10:31 AM
What is the setup you plan to use? Motor, Esc, Prop, Battery?
Dec 22, 2012, 05:43 PM
olmod's Avatar
For the power plant I will wait until I have a near complete airframe and check out then but I am not going to use no 7x5 prop as suggested on the plan , probably 9x6.
The top cap of the wing I used the narrower of the 2 size sheets and cut some 12mm strips of the wider sheets for top and bottom caps on the trailing edge, allerons built up as I have pictured, I bought some ultra light 2mm pin hinges from HK to use with this kit and find them good to use.
Dec 25, 2012, 06:47 AM
olmod's Avatar
Some more pix of the progress, I ended up using 1mm sheet for covering the fuselage ,I did not fancy the open structure if it was warren girder that would have been fine.imho. non of the control horns had the right size holes for the size wire supplied , yer I know par for the course.
Dec 25, 2012, 06:14 PM
olmod's Avatar
Ready for maiden.
All up weight using a 1550 mah pack just under 700grams. I dont think a 2200mah pack would fit btw.
I have used an old HET Typhoon 15/10 -1190kv motor fitted a APCe 9x6to start with but this motor can run to 10" with a 30amp esc under the battery floor I also opened up the lower holes in the firwall to gain cooling and access, I would not recomend this as a beginners kit but if undertaken it will be character building. oops I have forgotten to put some exhaust holes behind the esc in the floor that could have cut the maiden short.
Hope this thread is helpfull in some way cheers Lez. and seasons greeting to all.
Dec 27, 2012, 08:22 PM
olmod's Avatar
Weather is not good so here is a pix showing cg @3 1/4" for a 9 1/4" chord and the amount of downthrust I have used . btw am I the only one building this? not much input from others.
Dec 28, 2012, 10:48 PM
olmod's Avatar
maiden completed
I would suggest lowering the battery floor as low as possible ,that way you will be able to fit 2200 mah packs.the old 1560mah packs that I used were not the best I would also suggest this motor for a more spirited performance
HK NTM 2826-1350kv.
Performance was good requiring quite a bit of downtrim,that will change as the 2200mah pack will move the cg further forward wich it needs.
Dec 29, 2012, 12:27 AM
Hi Olmod,
How would you rate this kit in terms of quality, ease of build, flying ability, and value? I'm laying in a stock of kits for retirement and am wondering if this one is worth a buy.
Thanks, Mickydee
Dec 29, 2012, 12:58 AM
olmod's Avatar
Originally Posted by mickydee
Hi Olmod,
Thanks, Mickydee
If you are prepared to replace spars with full length ones ,the kits are 1/2 length and take the time to mark all the parts so you can work out where they go ,then there is value in the kit, the materials are ok its the instructions that will confuse novice builders. I would give it a 6 out of ten.
Discussion Big, Big, Big..Hobby King P-40N 1700mm SteveR3750 Electric Warbirds 11745 Apr 23, 2020 06:06 AM
Discussion Hobby Kings big price increase!??! hidaven Batteries and Chargers 16 Mar 15, 2012 08:55 PM
New Product Big (1075mm) mono kit from Hobby King bill34207 Racing Boats - Electric 51 Mar 04, 2011 10:49 PM
